Question about GE GSH25JSRSS Stainless Steel Side by Side Refrigerator
I have a GE side by side stainless steel refrig. the water will not dispense. How can I fix it?
  • 20 Answers
Is there water to the water valve in the rear of the fridge? If yes, replace the water filter if older than 6 months or if you're on a well. You may need an inline water filter behind your fridge in addition to the one in the fridge to protect the water valve. If no, turn on the water. If you're making ice but no water dispense and you have a new water filter. Replace the water valve.
Posted on Dec 10, 2008
Ice dispenser
THere is a plastic "hub" at the back of the bucket which attaches to the auger. THE "hub" catches a "fork" like device at back of ice maker which turns. The "fork" turns and in turn is supposed to turn the auger. That plastic hub could be torn up, broken, jammed, or otherwise not working correctly. That is what is wrong with mine.
Jul 19, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ice maker stopped working. the water and ice dispense from the door, but it does not make any NEW ice...
The water tube to the icemaker inside the refrig is frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 06, 2010 | GE Profile PSW26P Stainless Steel Side by...
No water from dispenser
I had the problem with the water dispenser not working.i tried all kind things finally I figured out the water was freezing ing the door. I cut a piece of 1/2 styro foam out that covers right below where the ice is dispensed just a square and use double sided tape to stick it to the back side of the door and haven't had anymore problems.
Nov 13, 2009 | GE Refrigerators
Me GE Profile PSC23M Side by side ice maker quit making ice and water was on floor behind refrig. Is a water line frozen or clogged or do I have to replace ice maker?
It sounds like you just have a leak at the back. Try swapping the wires on the dual water inlet valve. Then try the water dispenser and watch on the back for where the water may be leaking before it gets up to the ice maker.
Oct 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
Need your opinion on buying a new GE Profile refrigerator.
no dont do it GE is just bad news . if you must by ge make suer you buy the extended warr .and keep it current YOU WILL NEED IT ! ....... what one should buy? it does not matter , there all the same refrig inside ,just just STYLE you pick DONT FORGET EXTENDED SERVICE PLAN !
Jan 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
No water from door dispenser
you have a frozen wtr line inside door turn it off for a day or 2 then try it again but this time palce a thermometer in frezeer and keep temps at 0 to 4 degrees if it drops below 0 then the line will freeze again
Oct 30, 2008 | GE Profile PSW26P Stainless Steel Side by...
Dispenser doesn't dispense
ICE AUGER IN BIN IS BROKE,REPLACE,WATER VALVE TO DOOR WATER DISPENSER IS BAD,LOCATED ON BACK BOTTOM OF REFRIG.REPLACE,THANKS-MIKE
Mar 21, 2008 | GE Profile Arctica Stainless Steel Top...
Water Dispenser
does your refrig have a built in water filter? it may need replacing. if thats ok try checking your water supply to be sure that there isnt a kinked water line. if both of those check ok you may have a bad fill valve.
Dec 11, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
the water line is frozen inside the door. very common ge problem. you can defrost the dispenser area with a hair dryer. it takes about 30 min to do. it will freeze up again. if the frig is less than 3 years old, even though it out of warranty you can argue with ge and youll get a new door to fix the problem
Nov 26, 2007 | GE GSH25JSRSS Stainless Steel Side by Side...
GE GSH25JSRSS Stainless Steel Side by Side Refrigerator Logo
153 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
