Question about GE WPGT9360EPL Top Load Washer
WASHER WON´T WASH OR SPIN
DEAR SIRS,
MY MOM BOUGHT 9 MONTHS AGO A GE PROFILE WASHER, THE MODEL IS WPRE6100G0WT 32 CYCLES VARIABLE SPEED.ONE OF THOSE WITH DIGITAL CONTROL BOARD.
THE FIRST 4 TO 6 MONTHS WAS WORKING GREAT, BUT SUDDENLY THE MACHINE STOPS TO WASH AND SPIN,JUST FILL THE WATER UNTIL THE LEVEL YOU INDICATE AND THAT´S ALL.
A TECHNICIAN TOLD ME THAT PROBABLY THE MAIN CIRCUIT BOARD FRIES DUE TO VOLTAGE VARIATION. WE SHOULD BUY IT A PEEK SUPRESSOR OR REGULATOR.
SO THE MACHINE HAS A REMEDY OR WE HAVE TO BUY AN OTHER ONE
SINCERELY,
MARIO CERDA
  • 20 Answers
Hi
Sounds like a lid switch issue to me. the washer wont run if it thinks the lid is open. its a safety mechanism. Replace the lid switch. it's a cheap try and probably the right answer
Posted on Dec 10, 2008
Shaking GE Profile Washer
level the machine and make sure the floor is sturdy, you can even put a piece of plyboard under it.
Feb 05, 2014 | GE Profile WPRE6100G Top Load Washer
GE Profile WPRE6100G Top Load Washer how do you bypass lid safety switch? Unit pumps but won't spin.
worst washer I ever owned how do you bypass water level so you can wash a comforter man I am so disappointed with this GE Profile energy saver if I can't move the water level up I'm going to put it out along the road a trash day and it's only 4 months old
Dec 19, 2010 | GE Profile WPRE6100G Top Load Washer
GE Profile washing machine model 66515754000. 9
Try a cleaning detergent/descaler. some liquids do cause problems. Softner is 1, it tends to gel in the pressure chambers in machines. This in turn causes many problems.
Feb 11, 2010 | Washing Machines
GE washer Wbb4500GWW Won't spin
This is a defective board assembly. replace the entire board assembly if possible. it has become unstable and unable to initiate the proper wash sequence.
Jun 19, 2009 | GE Profile WPRE6100G Top Load Washer
GE Profile washing machine not finishing cycles
the OL error is for over load.that is when you over load the clothes in the washing machine. If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
Clutch assembly Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
May 07, 2009 | GE Profile WPRE6100G Top Load Washer
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
GE WPGT9360EPL Top Load Washer Logo
365 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
