Question about Motorola Mobility MD41 Expandable Handset for MD400 Series
How do you unregister a defective handset so that it can replaced
Currently have 4 handsets registered and want to replace defective handset but unable to add the new one. Base responses that "too many handsets registered" when attempt to register new handset.
1. Delete or listen to all voice mail messages, if necessary, to clear the IN USE/Voice Mail light indicator.
Note: Skip this step if it does not apply to your MD Series cordless telephone model.
2. Press OFF on the base station and each handset.
3. Press and hold down PAGE on the base station until the IN USE light flashes slowly, then release.
4. Press and hold down PAGE again until the IN USE light begins to flash quickly, then release PAGE.
5. Quickly and fully press and release PAGE again.
6. Please register handset displays. Press OK to begin the registration process, or press EXIT.
Posted on Mar 12, 2009
How to register the extra cordless handset of vtech 15250
Add and register a handset
Each newly purchased handset must be registered to the telephone base before use. When first purchased, each expansion handset shows NOT REGISTERED.
You may need to charge the phone first.
To register a handset:
    ·Place the unregistered handset in the telephone base or charger. Press Find for 4 seconds. If the headset screen doesn't light up after the 4 seconds. You will need to charge it some more.
    ·After making sure it is charged set the telephone on the main base again press and hold the Find button for 4 seconds ( until the red light IN USE comes on) Then release the find button. The headset will show PLEASE WAIT; this takes about 10 seconds to complete the registration. The hand set will show HEADSET REGISTERED and the headset number assigned, you will hear a beep when the registration is finished
    ·When the registration is complete, the newly registered handset is assigned the next available handset registration number. For instance, if you already have HANDSET 1 and HANDSET 2, the next registered handset is HANDSET 3.
    ·Makes sure no other headsets are in use at the time or the registration may fail.
    ·You cannot register a handset if any other system handset is in use. Only one handset can be registered at a time.
Aug 18, 2017 | Vtech Lands Phones
On the screen of the phone says not registered and wont allow me to make phone calls or recieve
Please try the following procedure to register the handset:
  1. Place the unregistered handset in the telephone base. If PRESS FIND HS 4 SEC ON BASE does not appear on the handset screen after a few seconds, remove the handset and place it in the telephone base again.
  2. On the telephone base, press and hold FIND HANDSET for about four seconds (until the red IN USE light on the telephone base turns on) and then release the button. The handset shows PLEASE WAIT... and it takes up to 60 seconds to complete the registration. The handset shows HANDSET X REGISTERED (X represents the handset number assigned) and you hear a beep when the registration completes.
When the registration is complete, the newly registered handset is assigned the next available handset registration number. For instance, if you already have HANDSET 1 and HANDSET 2, the next registered handset will be HANDSET 3
Mar 05, 2011 | Vtech DECT 6.0 Digital Cordless Phone
Unregistered Telstra V580a handsets
same problem here T.T really urgent
Aug 14, 2009 | Lands Phones
Wharfedale digital orb twin phone
TO REGISTER A HANDSET
[At the base]
1. Press and hold the the PAGE button on the base station for at least 3 seconds. You have 90 seconds in which to register a handset.
[At the handset]
2. Press MENU and scroll to ADVANCED SET and press MENU
3. Scroll to REGISTRATION and press MENU
4. If necessary scroll to display REGIST.BASE and press MENU
5. BASE 1 2 3 4 is displayed and the registered base number is flashing.
6. Enter the number of the base you wish to register to your handset. If you have only 1 base station, press 1. If you have 2 base stations, press 1 or 2, etc.
7. When the display shows PIN---- , enter the base pin.
8. When the handset is registered to the base it is assigned a handset number.
If you have forgotten your PIN you will need to:
Reset your ORB
1. Press MENU, scroll to ADVANCED SET and press MENU
2. Scroll to RESET UNIT and press MENU
3.CONFIRM? is displayed. Press MENU
[NOTE: Entries stored in the phonebook and new answering messages are retained. You PIN will return to the Default setting 0000]
To Set the PIN
1. Press MENU and scroll to ADVANCED SET and press MENU
2. Scroll to PIN and press MENU
3. Enter the current 4 digit master PIN and press MENU. [Default setting is 0000]
4. Enter the new PIN and press MENU
Hope this has been helpful!
Rob
Dec 28, 2008 | Uniden Cordless Phone
Registering a new phone
how do i register my new samsung rant phone ?
Oct 04, 2008 | Uniden DCT648-3 Cordless Phone
Tru 9496
SOLUTION:
1. First, remove the battery cover on your unregistered TCX905 and look under the battery to confirm that you indeed purchased a TCX905 because some Uniden handsets were packaged as 905's but were not.
2. Take the fully charged unregistered 905 to the base unit TRU9496.
3. On the TRU 9496 base unit press "Menu" then select "Registration" and press OK
4. You should get the message "press the # key on the remote handset".
5. Depress the "#" key on the unregistered 905 and it should register.
Aug 07, 2008 | Uniden TCX905 Cordless Accessory Handset...
Unregistered, registering a new base, faillure....
IF YOUR HANDSET WAS WORKING AND THEN STOPPED WITH "UNREGISTERED":
If lowercase unregistered is in main display and a reg. appears under the left soft key:
Press the left soft key below REG. and then press and HOLD the button on the top of the base station until the two indicator lights on top of the base station turn off. Wait until handset signals with beeps and registered. You are done
THIS IS FOR FRESH OUT OF THE BOX REGISTRATION OF UNREGISTERED HANDSET
Press REG Register shall be highlighted.
Scroll to Register. Press Select.
Enter the system PIN (Default: 0000). Use
CLEAR to correct typing errors.
Press ENTER to confirm.
• Your handset starts searching for the base.
Press and HOLD the round button on top of the base unit until the two
indications turn off.
• If registration is successful, the signal icon
Jun 22, 2008 | Philips VOIP8411B/37 IP Phone
Deregister lost or broken phones
Some tricks from a helpful Uniden rep:
holding down end+# keys at the same time on the phone for about 10 secs (you will hear a beep) will deregister the handset. If you have a dead handset and want to deregister it from the base, you have to reset the base. unplug the phoneline and power. hold down the "delete message" key, plug power back in. about 10 secs later, you will hear a long beep (theres a short beep upon powerup as well). At this point all handsets are deregistred and you will have to reregister them with the end+# trick. this way when #1 handset is dead, you can make a working one #1 and get the broken one fixed emotion-1.gif
BTW, this is a woot warranty, not uniden warranty. however the uniden rep gave me the number to the people who refurb (rox0rz!) these. I'll post an update when I finally get ahold of them (and the number if its actually helpful)
Jun 20, 2008 | Uniden TRU8885 Cordless Phone
Phillips dect2152
If you bought the base and handset together they should already be registered. If not then the instruction manual is downloadable here: MANUAL
The relevant section is on page 16 - here is a copy:
4 handsets can be registered to the base station. A handset
can only be associated with 1 base station.
�� To register another handset
First enter registration mode by unplugging and
plugging back in the power adapter to the
electricity supply.
Handsets registering / unregistering ( )
�� To unregister the handset you use
enter the RC code*
�� To unregister all the handsets (except the handset you are using)
enter the RC code*
Once the menu is selected, enter the RC* code written under the base and press
to confirm.
Warning : If you wish to associate a non-Philips handset to the DECT 211 or DECT 215 base
stations, make sure that these handsets are GAP compliant otherwise they will not operate properly.
*RC code
(Registration
Code) is
written under
the base.
Warning : Once unregistered, the handset is no longer operational.
Please rate my assistance this should be a fixya!
Mar 29, 2008 | Philips DECT 2151 Cordless Phone
Uniden handset TCX905 with base unit TRU8866-if compatible?
I just successfully registered 4 TCX905s with my TRU8865 base - it's documented in the TCX905 manual.
Be sure the handset you want to register is fully charged.
Remove the handset you want to register from its charger.
Now unplug the AC for the main base, hold down the 'find handset' key on the base and plug the AC in again, when it beeps, you can let go of that button.
Hold down the '#' on the handset you want to register, it will show 'Registering Handset...' and when it beeps, it's done - registered, you're good to go :)
Oct 11, 2007 | Uniden TCX905 Cordless Expansion Handset
Motorola Mobility MD41 Expandable Handset for MD400 Series Logo
913 people viewed this question
Top Motorola Mobility Lands Phones Experts
John Donghia Jr.
John Donghia Jr.
Level 1 Expert
Eric Sutherland
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
