Question about Ovens
Frigidaire oven is too hot by 50 deg.
Frigidaire model # CFEF 368 CES-3 is too hot by 50 deg or more. Is there a thermostat to replace? Were would I get the parts?
  • Ovens Master
  • 3,463 Answers
Yes, I would say that the main oven thermostat is faulty and in need of replacing.
If you are in u/k then try the followinw.
www.espares.co.uk.
Hope this helps.
Plz leave feedback.
Thanks.
Posted on Dec 10, 2008
Cfef 372ec4 Frigidaire f 30 problem
Hi - Typically error code F30 for Frigidaire range indicates an issue with the sensor probe or the wiring harness between sensor probe and EOC. If you have already changed the sensor, I suggest checking the wiring or contacting a professional to move forward accurately. You can try resetting the unit and see if the error code will clear. You can either unplug the unit or flip the household circuit breaker off. Wait approximately ten minutes and turn on the range. If issue continues, once again contact a professional to properly diagnose the unit.
Oct 14, 2012 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
Oven will not reach proper temperature
Hello Cynthia, contact a professional that your manufacturer suggests. Sounds like the mechanical thermostat, oven sensor or EOC needs to be diagnosed for replacement.
Sep 15, 2012 | Frigidaire FGB24S5A Gas Single Oven
On my frigidaire 30 self cleaning stove i set the temp at say 350 deg and it will start but will only heat to 280 max no matter what it is set to is there fuses to look at
There is a chance that either the thermostat probe is faulty,if you have an ohm meter the probe should measure about 500 ohms at room temp.if the ohms are good then you will need to replace the electronic contol board
Dec 11, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven does not get hot unless turned up to 550 degrees (Frigidaire ES200/300)
This could be a problem with the temperature sensor. It can be tested with an ohmeter. Should be about 1080 ohms at 70F, add 2 ohms per deg F from that point. If the sensor is ok then most likely you have a control board issue. We can repair that for you if you like. Here is an article that discusses common oven control failures:
http://www.fixyourboard.com/techzone/ovens/f1_error/f1_error.html
Regards,
Bruce
Jun 21, 2010 | Frigidaire Ovens
GE Gas built in oven Model JRS14 will not heat up
The bake ignitor has failed.Turn off the gas supply. Remove the racks. Then remove the bottom pan cover in the oven to access the ignitor. Place a amp meter on one wire of the ignitor.Turn the BAKE switch on. If it reads less than 3 amps,replace the ignitor.
Oct 30, 2009 | GE 24" Built-In Single Gas Wall Oven
Oven won't heat
I have EXACTLY the same problem, occured today 9/25/07. Model RBS305PDQ16. At least I know I am not crazy... You know when Ronald Regan was President the CIA analysts assured him that the Soviet Bloc was ready to crumble because the people were constatly complaining that "nothing seened to work anymore." ...must have included ovens...
Sep 20, 2007 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
225 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
