Question about Canon imageRUNNER 5000 Copier
Canon Imagerunner 500i finisher problem
Cleared a paper jam shut all doors and keep geting a message of (please attach the finisher) what is this???
    President:
  • Canon Master
  • 990 Answers
Between the copier and finisher there have a atuacter to atuact the door sensor, therefor just push finisher perfect contact the machine will resolve your problem.
Posted on Dec 10, 2008
I have shut the printer off and turned it back on and it still gives me the error message that it has a paper jam - how clear if there is a jam - I can't see any paper jammed up inside the printer - is...
Did U remove whole paper,or there's a small piece left in machine.That may be one of the reasons for still having a jam message,or maybe one of photointerruptors is faulty
Mar 01, 2015 | Canon imageRUNNER 2800 Black and White...
Canon imageRUNNER 2020i left door paper jam error.how to reset Tried to clean everthying,and there is nor paper jam.
I have a Canon ImageRunner I seem to have a paper jam. The red light is coming on showing the jam in the upper section of the machine but I have cleared all the sections I know to clear. I have turned the machine off and back on the jam light is still on. I can't find the Manuel to see what the problem is. What should I do?
Nov 29, 2010 | Canon imageRUNNER 2020i Black and White...
Canon imagerunner 11025iF. Cleared a paper jam,
there is a possibilty that one of the jam sensors is stuck and needs freed and or a piece of paper is blocking the sensor.
Jun 02, 2010 | Canon Office Equipment & Supplies
Remove a paper jam under the fuser unit on a canon image runner 5070
Hello sir; I believe You have to detacth finisher unit then open the side door to reach the fusing unit see is there have jamming paper over there ,the paper under the fusing unit just open front door turn the knob clockwise on the fusing unit paper will coming out.
Aug 17, 2009 | Canon imageRUNNER 5000 Copier
Consant paper Jam - Canon 1600 photocopier
Try to clean the rubber parts. Probably these are filled with paper dust.
Jul 22, 2009 | Canon ImageRunner 1600 Copier
Error code E584 and paper jams
• Feeder motor , • Shutter closed sensor • The shutter closed detecting switch does not turn on even when the feeder motor has been driven in reverse for 1 sec or more.
clear dust from the finisher sensor
Feb 23, 2009 | Canon imageRUNNER 400S Copier
Error message on Cannon IR 3300
that is a stack delivery error could be one of the motors or a board do you have the internal finisher or external
Jan 13, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Open Door. Clear carriage jam, and then press Enter
Sounds like you have a jam. Open the back of the printer and checl for any paper large or small. If there is no paper, just opening the door and closing it may get rid of the message. All it takes is a piece of paper the diameter of a pea to send a signal that there is a paper jam. After yuou have finished close the door and push enter to let the printer know you are finished. See if this helps. I don't think it has anything to do with the ink cartridges. It sounds more like something stuck causing the jam. Be sure not to have anything like a staple attached to the paper you are printing on to. A speck of dirt could casue a jam message too.
Aug 28, 2008 | HP PSC 750 All-In-One InkJet Printer
Canon iR8500 with Error E000583-0001
Hello Jeremy,
This error code has to do with your finisher. The auxillary tray is not finding its home position or does not leave the home position within the alotted time. Check for binds. I have limited exposure to the K4/3 finisher but try this. Turn the copier off, and open one of the finisher doors. Now turn the copier back on with the finisher door open so it cannot initialize. Once the copier is basically ready except the finisher door is open, close the finisher door and observe all the **** (and theres alot) initialize. This may help determine the problem. I hope this helps...........................SPINAL
Mar 12, 2008 | Canon imageRUNNER 8500 Copier
I860 False Paper Jam Message
Check the back of the printer. There should be door at the bottom. Your paper jam could be there.
If this helps you, please rate me. Thanks, Patty
Nov 06, 2007 | Canon i860 InkJet Photo Printer
Canon imageRUNNER 5000 Copier Logo
234 people viewed this question
old marine
old marine
