Question about Dell Inspiron 8600 Notebook
Dell 8600 Won't Power On
No lights come on- nothing. The previous night, I took out the keyboard just to clean out the fan etc. The screwdrivers weren't magnetized or anything. I took the battery out before hand too... just like I do every couple of months to clean it out.
Afterwards it powered on fine, and was left on all night. I turned it off (sleep/hibernate- I can't remember) in the morning, brought it to class. At class, it worked fine. At the end of the class, I put it into hibernation, and it won't come back on.
No lights, nothing of any sort.
The adapter works, the battery seems to be ok. The adapter's light comes on. I used it on other laptops, and it charges them. I tried using other adapters on the broken laptop, and nothing happens.
I also tried powering it on without the battery in.
  • 2 more comments
  • funincluded Dec 10, 2008
    I don't know if it is charging the battery or not- the battery charging light on the laptop does not come on.
    However, the lights on battery itself do come on (to test the battery). Its charge is almost full, it seems.
    No lights on the laptop itself come on no matter what adapter I use.
    so the only lights to come on are on the battery itself and on the adapter itself. I don't know how to tell if the battery is charging or not.
    The adapter does charge other laptops though.
    Also, it will not come on with any adapter.
    Let me try and re-phrase it.
    I tried using this adapter in other computers- it works.
    I tried using other adapters to charge the broken computer- no lights on the computer come on. It will not turn on.
  • funincluded Dec 14, 2008
    I tried that several times before
    The problem was actually with the cover strip (with the power button, CAPS light and num. lock light). It wasn't plugging back in when I snapped it back into place.
  • Alan Matzke
    Alan Matzke May 11, 2010
    Are you saying even when you plug it in with ac adapter power does it charge the battery but with that on ac it will not come on?
    Problem Solver:
  • 16 Answers
Try taking out the memory and put it back it. I probablly needs to be reset
Posted on Dec 14, 2008
My dell inspiron 2400 pc will not start up
If the power light doesn't come on at all, it could be the power supply is dead, or the power switch is defective.
Check to make sure the power cord and power supply cables are securely connected.
Here are some diagnostic tools for DELL computers.
http://www.dell.com/support/Article/us/en/19/SLN284978/EN#2012_to_Present
May 19, 2014 | Dell Dimension Computers & Internet
Dell Inspiron 1100 won't turn on
unplug, take out battery then hold power button for 30 seconds then plug back in and turn on
if the3 laptap gos on without the battery you need a new battery
Jun 14, 2013 | Dell Inspiron 1100 Notebook
HiI have a dell desktop and won't start. for a second the fan spin than the power button turn yellow. help
hi,
Does your desktop is making any beap sounds? Are you able to see the dell logo on the startup on the screen? Please do let me know these things.
Mar 08, 2012 | Dell OptiPlex GX280 PC Desktop
My dell vostro 2510 won't power on, when i press power button to turn on the pc , the power light turn on for about 5 sec then it turn off itself,
Try this to see if can give us some codes with it's on board diagnostics. Hold down the function button of your laptop and then the power button while still holding down the Fn/Function button on the left side of the keyboard. See if this gives you either an error message on your screen or, flashing lights above your keyboard. Pay attention, write down what lights where lit up what ones flashed, etc. This is to diagnose if the LCD isn't working. Comment back if you get either the light code or the error code on the screen. IF nothing happens try holding the Fn/Function button on the left side of keyboard and holding the F4 button, see if that makes any lights flash above your keyboard.
Jun 18, 2011 | Dell Vostro 2510 Laptop
1) How to you open the cpu case to get to the fan, etc. 2) My fan has started making noises......can it be cleaned - or is it likely to need replacement?
Things You'll Need:
  • phillips Screwdriver
  1. Shut down your Dell desktop computer.
  2. Remove all of the power and peripheral cables from your computer. There should be no cables connected to your computer when you attempt to remove the cover and open the case.
  3. Watch for the green "Power" indicator light to dim. This light is on the back of the case near where the power cable plugs in. Your computer will hold onto an excess amount of energy for a few seconds after it is unplugged. You don't want to open your Dell computer case while this light is still lit.
  4. Use a screwdriver to remove the screws holding the side of your Dell desktop computer's case. Set the screws aside.
  5. Use your hands to pull up on the side of the case, separating it from the base of the computer. This will allow you to access the inside of your Dell desktop computer.
Jan 23, 2011 | Dell Dimension 2400 PC Desktop
Fan running and in power save mode
If you are connected to a power strip, reset the power strip. Also, connect an external monitor to see if the display is the problem. Good luck.
Jun 13, 2009 | Dell Inspiron 530 Desktop Computer
Unpluging 4 pin power on mobo Pc starts but no video,keyboard etc
how do i fix the monter I tryed to put the power and rest on and motherboared comes on not the monter
Mar 13, 2009 | ASUS P4SGX-MX Motherboard
The fans won't turn off !?
THE FAN RUNS ALL THE TIME, THE CPU CAN COOK AN EGG ON IT IN A MATTER OF SECONDS.
GO ON LINE TO EBAY, OR A VENDER OF THAT PRODUCT, RECONDITION ELECTO-MECHINICAIL USED COMPUTER EQUIPMENT STORE.
ROD
Feb 05, 2009 | Dell Latitude C610 Notebook
Dell c610 fans stay on and won't turn off!
Go Here-------> http://www.diefer.de/i8kfan/index.html
and download the 18kGUI fan utility software, it runs great on dells, you can control your fans, or set it to auto, or low etc....
Feb 05, 2009 | Dell Latitude D600 Notebook
Dell Inspiron 8600 Not Powering Up
have you checked all connections to the battery, make sure the battery terminals are free of cerrosion(rust&mold) make sure alll the power cables are intact. it does not sound like the power supply due to the fact that the light is coming on for a min or so.
May 11, 2008 | Dell Inspiron 8600 Notebook
Dell Inspiron 8600 Notebook Logo
506 people viewed this question
Alun Cox
