Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Black not printing
This was working fine prior to changing the black ink cartridge on my Canon MP390 multipass scanner/printer, then it stopped printing. I have tried all the cleaning techniques and have changed the black cartridge 3 times to no avail. It prints in color fine, it just won't print from the black cartridge. HELP. Thanks, Elle
  • 25 more comments
  • Henry Smith Nov 10, 2007
    I have a similar problem. But how do you take out the printhead in order to soak it in rubbing alcohol?
  • Anonymous Jan 01, 2008
    have the same problem. the black cartridge stopped printing would print nothing. cleaned it out using the straw method and the alcohol but when i now print many of the lines are missing. any idea on how to solve this problem.
  • Anonymous Jan 07, 2008
    Same problem. My printer is not printing black, but it prints color. I have change the ink two times thinking it was the ink. Do I have to order a printer head.
  • happychazz May 23, 2008
    black cartridge will not pring
  • Anonymous May 27, 2008
    Oh Yeah! Did the combination of soaking in alcohol and then blowing down the little holes and my printer prints better and cleaner than ever! Thank you!
  • Anonymous Jun 18, 2008
    My printer does not print "black"
    I've changed the cartridge twice.
    For instance; a print out of this page the "printer" itself comes out pink & grey!
  • Anonymous Jul 04, 2008
    My Canon will not even attempt to print in black. It's like it doesn't recognise it. Colour is fine however....
    My MP 390 will not even try to print black, it's liek it doesn't recogise it. Colour is fine, however.....
  • vantage2000 Jul 04, 2008
    My MP 390 will not even try to print black, it's like it doesn't recogise it. Colour is fine, however.....
  • violetyoung Jul 26, 2008
    After changing the black ink (Office Max brand), paper comes out blank, color is o.k. I soaked the ink head in isopropyl alcohol.
  • deanwed Jul 26, 2008
    Tried cleaning and deep cleaning Aligning print head.
  • drsmashem Aug 31, 2008
    I see you have the same problem as me. I've been very happy with the Canon Smartbase MP390 for the last 2+ years - until it stopped printing
    black! I've replaced the black cartridge twice and reset counters, gone
    through the troubleshooting steps and still no luck in resolving this.
    Let's hope someone can help us.
  • highergoals Sep 08, 2008
    on my cannon mp390 the alarm light wont stop blinking, change cartdrige on display show wont print
  • westy02343 Sep 10, 2008
    The black ink will not print even after changing the ink cartridge.
  • Anonymous Sep 23, 2008
    will print color and copy color but wont print in black
  • hammer_kris Sep 23, 2008
    Just changed out the black ink cartridge twice with new cartridges. The machine will not print or make copies using either black or color ink. How do I solve this?
  • Anonymous Sep 24, 2008
  • meyeh37 Sep 24, 2008
  • llttsmth Sep 27, 2008
    after changing the ink cartrages the black does not print Help
  • srivastjunk Sep 27, 2008
    I have the same problem, black not printing even after cartidge changes and following "self clean" guide from Canon.
  • jburt2 Sep 30, 2008
    Same problem. Can anyone help?
  • eileenibean Oct 03, 2008
    When I print only some of one line prints....
  • Fpmazzone Oct 21, 2008
    Same problem, printing is very faint and none existent. Tried changing cartridges still didn't work.
  • Anonymous Oct 21, 2008
    it works when i scan and print. but when i print off the internet and on the microsoft word it doesnt print at all. it is so weird i thought it was the ink but when i scan and then print it works so do you think it is a driver missing or some cheap ink.
  • Anonymous Feb 16, 2009
    I replaced the printer cartridges and now it won't print in black.
  • Anonymous Mar 15, 2014
    my black prints but there is missing parts though it prints but only half of the letter the upper part of a letter only ex. an o only a semi circle prints the upper part of a letter it only happens in black ink but my colored ink works fine. thank you!
    Problem Solver:
  • 8 Answers
I just ran into a similar issue with my MP390. Actually both the color and black inks were not printing very well. I would get very inconsistent printing. Fixed the problem very easily and quickly as follows: On the top of each print cartridge, there is a small hole. Remove the print head (lift the gray bar at the front of the print head and lift out the print head) with the cartridges still in place. Holding the print head over a piece of paper/paper towel, blow into the holes on the top of the cartridges (either directly or using a straw/tube of some kind). You should get ink coming out of the botton of the print head, both color and black. Replace and print head and test print.
Posted on Jun 08, 2007
Excellent solution. May want to run the maintenance clean head action from the printer menu on the printer and also print a horizontal line test page to make sure the heads are aligned properly.
Posted on Dec 26, 2007
What a trick, even Canon does not know about the straw system, it WORKED and appreciate.
Posted on Nov 09, 2008
    Problem Solver:
Wow! If only I'd read this solution before trying all the other methods to clean the printhead and then buying a new one (which subsequently didn't work anyway). Thanks for a brilliant hint, you're a star!
Posted on Jan 19, 2008
Thank you - I had tried everything I the book said. Was looking into a new printer
Posted on Dec 01, 2007
Thank you!  I'd tried all my 'tricks' and was researching buying a new printer.
Posted on Oct 29, 2007
The straw trick worked brilliantly and so simple - thanks a million for the solution to a very frustrating problem.
Posted on Oct 16, 2007
Thanks a million! It fixed my MP390 which wasn't printing or black photocopying.
Posted on Sep 22, 2007
Thank you very much iy worked
Take out the printhead---remove both cartriges---cover the whole printhead for 15 minutes in rubbing alcohol---be sure it is 100% clean and dry---reinstall with good cartrigee---Mine now works!
Posted on Sep 20, 2007
Same here id been surfing the net looking for an answer to this problem for 2 hours and i tried this and it worked waheyyyyyyyyyyyy
Posted on Sep 19, 2007
It worked! That was wonderful. I've been working on this for an hour. Thank you!
Posted on Sep 12, 2007
I HAD THE SAME PROBLEM WITH MY CANON MULTIPASS C530. TRIED YOU METHOD AND IT WORKED GREAT. MANY THANKS.AMAZING WHAT YOU CAN DO WITH A STRAW.
Posted on Aug 09, 2007
Black will print properly only on "High" Print setting
After all the trouble shooting you have done their most likely a hardware issues causing the problem.
Please Contact Canon for repair service or replacement.
1-800-828-4040
Nov 14, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
My printer doesn't print anything
Head problem COPY many black text pages 50 or so run head clean if still white pages repeat up to 200 or so pages..see how you go
Apr 22, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
My Canon mp390 printer doesn't print
I had this problem several times, had to buy new print head until I found that to clean it you should use ammonia. It really worked for me. You should really try ammonia it does work.
Black ink will not print
Try this: Take out the black one, or all. Clean ink outlet(s) with  rubbing alcohol and Q-tips. Reinstall . Lacking that working ,obtain a new black cartridge
Dec 11, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Can't print the black ink
I spoke with technical support at Canon and they determined that the printer has died. There is no solution to this problem, other than getting a new printer. Thanks anyway.
Dec 02, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Nov 16, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
PRINT IN BLACK WITH COLOR CARTRIDGE?
Yes, you can print out in black from a color cartridge, however it is not advised as you will run out of colored ink twice as fast as it combines all the colors to get black.However it works great when your in a pinch and need black ink.
Just go to your printer properties when you print and the option will be in there someware.
Dec 26, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
Canon printer MP390
My MP390 wasn't printing black, despite the cartridge(s) being new. I reinstalled CD and then it worked. The next time, it did not print again. I, then d/l driver from online...same thing. worked once and then not. Also, it doesn't copy anything in black
Dec 16, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
Canon multipass 390
alarm is flashing and flashing put in cartridge even though I've put in both black and color new cartridges and reset both still won't print
Mar 25, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
604 people viewed this question
Clive
Clive
old marine
old marine
