Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
External Harddrive Won't turn on
I came home and my harddrive wasn't on. The light was off. When I plug the AC adaptor into the wall its light turns on but when flip the on switch on for the harddrive it flashes and turns both lights off.
  • dspurr Dec 13, 2008
    I am having the same problem. It is only 2 months old. Turned it on and nothing happened. I am using the correct AC adapter too. What do I do?
I need to replace my ac adapter what is the voltage
6 volts or 12 volts
Posted on Dec 13, 2009
SONY VAIO PCV R53 39 DS WON'T BOOT UP
Pull the harddrive out, install in an economical external enclosure.
The external enclosure has a USB cable.
Plug the USB cable into any available USB port, on a working computer.
Go to My Computer, or Computer; and double-click on the drive letter, that corresponds with the external enclosure.
(Actually with the harddrive in that external enclosure, it is now an external harddrive)
http://esupport.sony.com/US/p/model-home.pl?mdl=PCVR539DS&LOC=3#/howtoTab
It's an IDE harddrive. Also known as a PATA harddrive.
A harddrive is measured across it's width.
2-1/2 inches across is a laptop harddrive.
3.5 inches across is a desktop harddrive. (3-1/2 inches)
So you need a 3.5 IDE (PATA) external enclosure.
One example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
Regards,
joecoolvette
Mar 26, 2013 | Sony VAIO Computers & Internet
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
http://www.xbitlabs.com/misc/picture/?src=/images/storage/wd-passport-250gb/p3.jpg&1=1
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
http://www.xbitlabs.com/articles/storage/display/wd-passport-250gb_2.html
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
WD500H1U-00 Western Digital 500GB MY BOOK external hard drive does not turn on power. There are two cables, one goes from external hard drive to computer and then another one is a power cable. It does not...
Believe it or not, unplug the AC adapter (Power Adapter) from the surge protector, and plug it directly into the wall socket.
Try this first.
1) I believe the power adapter is rated at 12 Volts DC, and 2 Amps, for the output voltage, and amperage.
(12 Volts times 2 Amps = 24 Watts.
12V X 2A = 24W)
Use a multimeter, and test the voltage coming out.
You can buy an economical multimeter for around $8 to $12. A lot of stores carry them. An auto parts store is but one place.
The plug end that plugs into the laptop, is cylindrical in shape, and has a hole in the center.
This is DC voltage you are testing.
The metal center of the plug is Positive. The outside shield surrounding the plug is Negative.
The Function Knob should be turned to DC Voltage.
(If it is a symbol, it will be a dotted line above a solid line.
NOT a curved line on a dotted line. This is for AC voltage)
If there is more than one scale, set the Function Knob to DC voltage 0-50 Volts.
The Red probe lead of the multimeter is the Positive lead.
The Black probe lead of the multimeter is the Negative lead.
AC adapter plugged into power, the Positive probe lead is inserted into the center of the plug.
Be SURE it doesn't touch the outside metal shell at any time.
The Negative probe lead is touched to the outside metal shell.
See if the voltage reads 12 Volts.
AC adapter (Power Adapter) checks out OK?
Suggest there is a problem with the small circuit board inside the MyBook.
Inside the MyBook WD500H1U-00 is an ordinary harddrive.
It is a desktop sized harddrive. 3.5 inches across in width.
(3 and a half inches, or 8.9cm)
It is a SATA harddrive.
http://www.youtube.com/watch?v=6FlySnyJ0CQ
Inside that plastic MyBook case is also a small circuit board. An interface circuit board.
The harddrive plugs into the interface circuit board directly, or there is a cable, or cables, that plug into the harddrive from the interface circuit board.
It is this interface circuit board that goes bad most of the time.
You can remove the harddrive out of the MyBook case, and put it inside a desktop computer that uses SATA harddrives, as a Slave drive.
Retrieve your information, and burn to disk/s, or flash drive/s.
{DO NOT move any jumpers on the back of a SATA harddrive. These are for the factory ONLY}
Or you can buy an adapter that the harddrive plugs into, and it has a USB cable.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2583340&CatId=3770
Or you can put it into a 3.5 SATA external enclosure, and use it as an external harddrive again.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
Regards,
joecoolvette
Oct 03, 2011 | Computers & Internet
It's boots up and show the acer home screen then turns black and says t press f2 but nothing happens
It's having problems looking for a bootable media ( like optical drive, harddrive, bootable flash drive).
Try these steps:
  1. Unplug any external devices, including memory cards.
  2. Turn of the computer, remove the ac adapter & battery, then hold down the power button for 10 seconds. Reconnect the ac adapter and battery. Turn it back on.
  3. Set the first boot device to harddrive
If problem still persist, please revert back to me or call an authorized Acer technician
Feb 05, 2011 | Computers & Internet
My acer netbook 532h will not power on. just before problem the power on button stayed on and nothing happened; battery was pulled to turn unit off. unit has a blue light under the light bulb icon turn...
Two things to try first before we go further with the diagnosis:
1. Try to power up the netbook with the external hard drive disconnected & see if it will work.
2. Try powering up the netbook from the AC adapter only with the battery removed.
Nov 28, 2010 | Acer Computers & Internet
I have several computers at home, and none og them can recognize this portable device. Hitachi 250 GB Mod: SDM/250RW
1) Power:
It may be the problem that occurs with a lot of USB powered devices jrherrer. Not enough power provided.
The USB cable plugged into the computer, provides signal wires for transferring information back, and forth, and also provides 5 Volts DC for power. (Two D cell flashlight batteries produce 3 Volts DC)
http://en.wikipedia.org/wiki/USB
[ Below shows the Signal pins, and the Voltage pins of the USB B Mini style connector, (Male), used to connect to the SimpleDrive Mini external harddrive,
Pin 1 is for the 5 Volts DC Positive (Wire color - Red)
Pin 2 is for the D- Signal (Wire color - White)
Pin 3 is for the D+ Signal (Wire color - Green)
Pin 4 is not connected. (Or sometimes joined to Pin 5 with a Resistor)
Pin 5 is for the Ground (Wire color - Black)
Just added info in case you wanted to know ]
From what I see the SDM/250RW has a USB port on the side, and a DC Power Jack, used for an AC adapter, also.
(Round port with a pin in the center)
http://www.hitachigst.com/tech/techlib.nsf/techdocs/0C876B7AB91B23988825773F006BEA02/$file/SD_Mini_DS_final.pdf
From what I see stated from Hitachi, and sellers on the 'net, the AC adapter may not be provided.
Many of those who provide a review state that both the USB cable, and the AC adapter is needed to provide enough power. Seems to be a power hungry external harddrive
It's a 2.5 Hitachi SATA laptop harddrive inside that external case. (The Harddrive is 2 and a half inches across in Width. Common size used for laptops)
When using an external device powered by a USB cable there are general guidelines to follow,
A) The USB cable should not be more than 2 feet in length
B) Connect the device directly to your computer, instead of through a hub, or other device, unless the USB hub has it's own power.
2) USB cable:
Could be a faulty USB cable, although I imagine you have tried different ones by now.
3) Interface Circuit Board:
The Hitachi SATA 2.5 harddrive inside the SImpleDrive Mini SDM/250RW, plugs into a small circuit board located inside that external case.
Components on the circuit board may be fried, or the Harddrive may have come loose from the interface.
Loose from the interface
To explain;
The back of the harddrive has connector pins sticking out.
The interface has socket holes which the pins insert into.
Faulty circuit board
The external case of the SimpleDrive Mini SDM/250RW can be carefully opened up, and the Hitachi SATA 2.5 harddrive extracted out.
Another inexpensive external case for a 2.5 SATA harddrive can be procured, and the Hitachi harddrive put in it.
Example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3743049&CatId=2781
Nov 22, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
Dear Sir/ Madam, I have TWO Western Digital USB
first of all , you are looking at the wrong voltages. The important voltage is the DC OUTPUT, which is the voltage the external harddrives use AND the polarity of the plug attached to the harddrive end of the cable.
if both the harddrives have say 12v dc output and both have the insignia of the center conductor being + (posative) then you can interchange them. and you CAN run a 9volt unit with 12volt DC power, but not the other way around.
Look at your power adaptors again for the OUTPUT and polarity.
should be a half-circle with lines depicting the polarity(+,-) of the center and sheild connections to the hard drives printed on both the harddrives and the power adaptors . This can also be tested with a dc volt meter while the adaptors are plugged into the wall.
DO NOT try to test the AC end while plugged in!!
Regards
Aug 09, 2010 | Western Digital 250GB MyBook External USB...
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Windows XP will not recognize my WD 250GB Harddrive
Just plug your USB HDD directly into your MBoard's USB port...
Feb 09, 2009 | Western Digital 250GB MyBook External USB...
Simple tech 500gb usb hard drive
Youve damadged the harddrive, is the harddrive spinning or making any noise?
Jun 16, 2008 | SimpleTech SimpleDrive Pininfarina 500GB...
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
778 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
