Question about HP iPAQ RX3715 Pocket PC
Hp ipaq seems dead
I cant get my ipaq rx3715 to power on
  • MRSWISHA Dec 16, 2008
    I plug the usb charger/sync cable in and the power will not turn on
    Novelist:
  • 164 Answers
Without know exactly what already you tried to powered it on, I can only especulate on all the possible reasons, so let go one by one throuh them and their possible solutions:
1. The RX3000 Ipaq family has a known mechanical issue on the switch that senses when the back cover lid is properly closed.
When the switch is nor properly depressed, the PDA won't charge the battery if plugged on the cradle or to the USB sync cable, or won't turn on.
Remove the back cover lid and the battery, put them back again. Check the cover lid is placed flush and that there is not any gap between the cover and the PDA body.
Try again in power it on and/or charge the battery, confirming the orange LED light is turning on.
2. Either the cradle/USB sync cable or the AC wall adapter are defective.
The PDA won't power on if the battery is not charged to the minimum voltage for it. If the AC wall adapter or the cable/Cradle are defective, won't power on.
Put to charge the battery and confirm the orange LED light is turning on. If so, the you can discard that the cradle/USB cable or AC wall adapter are defective.
It the orange LED light won't turn on, it may be either one of these three parts that are defective, or that the back cover lid is not properly closed.
3. The battery dried out. If the battery is defective or won't accept charge, the pda won't power on.
To discard a defective battery, put the PDA to charge it, and it will power on when plugged to the USB cable or to the charger, and check in the settings screen, on the power icon, if the battery is charging.
If the back cover lid is properly placed, and the PDA won't power on when plugged to the USB cable or AC wall adapter, then the battery is not the problem.
4. Discarding that the battery or the USB cable or cradle or the back cover lid are the problem for this problem, the only option that is left is that the main board is defective.
Such failure on the mainboard could be caused for several reasons (moisture or humidity or water damage, or a electronic component that is worn out, or a integrated circuit that is shorted, etc) but it can be only verified and confirmed by an electronics technician.
You have the option of send it to be repaired, or try it yourself, which will require to buy a PDA with working mainboard (or the mainboard alone) and swap the parts. It requires a minimum of technical skills to do it.
Best regards,
Posted on Jul 24, 2009
Manual for RX3715 I paq
Hi,here is the link that you can download the manual..
Take care and thanks in advance for rating me.
HP iPAQ rx3715 PDA
Supplementary Guide for HP rx3000 / rx3100 / rx3400 / rx3700 / rx3715 http://h20000.www2.hp.com/...Fc00264003.pdf
http://www.retrevo.com/support/HP-rx3715-PDAs-and-Handhelds-manual/id/393ag912/t/2/
Oct 22, 2010 | Computers & Internet
My Ipaq rx3715 won't charge. "AC only"
its obsolete now, why use this thing?
wait for battery? then post?
or go to HP and ask them,
we are not HP, this is chat bs boxes here.
ever heard of HP? this is the official HP forum, try it?
If HP cant help you who can,
learn this ,when compelled to mess with obsolete products
buy 2 of them for like $3 on fleabay (most are in the trash now)
then mix and match parts, all day.
its obsolete, so doing tests on it lacking full spares is impossible.
why not buy a $3 used smart phone from same place,
https://h30434.www3.hp.com/
Aug 04, 2017 | HP iPAQ RX3715 Pocket PC
How to switch off my hp ipaq
On most HP pocket PC's, holding the power button momentarily will turn it off.
If you hold it too long, it will only turn off the backlight, but the unit will remain on.
Apr 27, 2008 | HP iPAQ RX3715 Pocket PC
Does not turn on
There are some known issues with the included charging equipment. Personally, I ordered a relatively inexpensive charger from Amazon.com that works wonderfully. All you really need is a device that turns a standard wall plug into a USB charger. You can then plug your base that the ipaq stands on into that and it should begin charging. The old battery is probably dead (mine was), but try to charge it anyway.
Note: The actual cord that came with my charger DID NOT WORK. It is sitting in a box somewhere, and if its the same thing I had (it probably is), then you just need the wall-to-USB converter.
This is what I bought:
http://www.amazon.com/iPAQ-rx3715-Sync-Charge-Cable/dp/B000DT8F0A/ref=sr_1_4?ie=UTF8&s=electronics&qid=1204335733&sr=8-4
It is only $10. Again, the cord didnt work for me. Maybe it will for you, but if you manage to find just that converter for less money, more power to you!
Feb 14, 2008 | HP iPAQ RX3715 Pocket PC
Hp ipaq rx3715 universal keyboard driver
Get in the PalmOne web site, and ion products support, find and get the driver of the specific model of the universal IR keyboard you are tryng to use with the Pocket PC.
Also, you can google in internet per the specific model of universal keyboard, and you will find several sites with such driver.
Best regards,
Sep 02, 2007 | HP iPAQ RX3715 Pocket PC
Is there any device(sim card) that can be attach to my ipaq rx3715
The ipaq has no phone-capable speaker system. The speakers in a phone are designed to allow the user, but no others, to hear the conversation. ipaq speakers do not have this capability. Also, the speaker and microphone are on the same end of the system. If HP had intended the ipaq for phone use, they would be higher quality, and on opposite ends of the device.
Aug 24, 2007 | HP iPAQ RX3715 Pocket PC
After reset, the screen is locked and i cant do anything
I had this happen and I had to get a new screen fitted.
Jun 15, 2007 | HP iPAQ RX3715 Pocket PC
Ipaq RX3715 hard reset
hard reset: Button 1 and 4 and press reset button with stylus
Jul 11, 2006 | HP iPAQ RX3715 Pocket PC
RX3115 Remains on
Calendar appointments will wake up the unit. You can change the power settings so that the unit will turn off after a certain amount of time. On my iPAQ rx3715, it's Start>Settings>Power>Advanced tab.
Sep 11, 2005 | HP iPAQ RX3115 Pocket PC
Rx3715 battery power trouble
Did you check if the PDA was hot? My battery was totally dead one day when I picked my 3715 up, just to found out it was blistering hot (was turned off) and even the backup battery was empty. Running fine now after hardresetting it, but still...
Sep 08, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ RX3715 Pocket PC Logo
154 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
