Question about Apex Digital Televison & Video
Rolling picture I set up the player using the remote and screwed it up. How can I reset it to factory default?
    Scholar:
  • 107 Answers
What is brand your DVD and model
Do you have component input on your TV, use it you may see the picture
Cheers
Posted on Dec 10, 2008
My Vizio E320i-A0 tv, has barley any picture when i pug in and turn on, VERY faint logo on screen, How do I fix it?
The picture settings may have been set very low. You can reset to the factory default settings using the steps below. You may also try selecting different inputs to see if the brightness is the same on all of them.
1. From the Picture Settings menu, use the
Arrow buttons to highlight 'More' , then press OK.
2 . Use the Arrow buttons on the remote to highlight 'Reset Picture Mode', then press OK. The TV displays, "Are you sure
you want to RESET Picture Settings to the factory defaults?"
3 . Highlight Yes and press OK.
4 .Press the EXIT button on the remote.
A manual is available here:
http://cdn.vizio.com/documents/downloads/hdtv/E320iA0/UM_E320iA0.pdf
Jan 17, 2015 | Vizio E320i-A0 32 Class LED Smart TV
Pioneer dvd recorder dvr 310
Resetting the Recorder to Factory Settings
1. Make sure that the recorder is on
2. Press and hold the STOP button and STANDBY/ON button.
The recorder turns off with all settings reset.
Try this and let me know if it works.
Mar 27, 2008 | Pioneer DVR-3100 DVD DVD Recorder
Factory reset
Use Default Settings If you want to return the initial language setting such as Language, Video, Audio and etc. to the factory default, do the following: 1) Press SETUP button. 2) Press / button to select Misc. 3) Press button to select Use Default Settings, then press ENTER button. 4) Press / button to select "Yes", then press ENTER button. The original setting will be restored. Screen saver : On Do you want to use default setting? Note When you reset the DVD player to the factory default, the DVD player will take 3-5 seconds to reset.
Oct 15, 2014 | Toshiba SDK990 Player
THT - 160B DVD player
Contact the mfg of the player for the hidden code or sequence that will restore your unit to factory defaults.
Sep 10, 2017 | Televison & Video
I have a (cyberhome ch-dvd 300) dvd player and changed setup menu now lost video cant see to change back is there a reset code or something
I wish I could find the website that gave all the repair hints for this DVD player, but I downloaded the info, and can no longer find the site. Here is what it says with regard to your symptoms. I hope this helps. I have done all the mods the site suggested, but continue to have difficulty with the remote, tray opening, etc. I have 2 machines and used to love them, but frustration has taken it's toll. Recovering from a condition with no TV picture
Accidentally switching to PAL and getting a rolling black & white picture happens all the time to baffle users, especially on models with a System or P/N key on the remote. To get back your color and sound just switch to the proper system in the menu or put in a movie of the correct type and it can switch automatically or try the procedure below for resetting to the defaults.
Sometimes owners will accidentally switch to Progressive Scan in the menu then get no picture at all. You can fix the no picture condition on the CH-300 by resetting the defaults to interlaced as mentioned in the users manual:
"To reset the VIDEO OUTPUT, turn Off the player, turn back On, open the disc tray and press and hold the Stop button on the player for 10 seconds to reset the scan mode."
The Reset procedure doesn't seem to work on all versions but you can sometimes get a usable B&W picture allowing you to get to the menu and change the settings by connecting the composite video input of your display to the Red Pr/Cr or Green Y component output jacks on the rear of the cabinet.
You can also go into the Menu and set it blind with the following key presses on the Remote:
1. With the unit Stopped, press Setup.
2. Press Enter.
3. Press the Down Arrow 3 times.
4. Press the Right Arrow Once.
5. Press Enter.
On 300Z & 300ZS models if the video is set to Progressive Scan and you can't get a viewable picture on the Red or Green jacks try going into the Menu blind and changing it back with the following key presses on the Remote:
1. With the unit stopped, press Setup on the remote.
2. Press the Right Arrow Once.
3. Press Enter.
4. Press the Down Arrow 2 times.
5. Press Enter.
6. Press the Up Arrow 2 Times.
7. Press Enter. This should switch it back to Interlaced scan with S-Video and Composite output.
To change the Parental Control setting on the CH-300 use the factory password of 3351. For the CH-400 use 1379.
Nov 02, 2009 | Televison & Video
Sony blue ray bdp_350 no picture or sound
press and hold stop button returns player to factory reset which solved my problem.
Sep 29, 2009 | Sony BDP-S350 Blu-Ray Player
Wuz n menu settings, hit wrong button, now only hve rolling pix!
you pressed the color system format button/settings.on the remote press the P/N which means pal/secam and ntsc.press it several times or until you get a steady picture.when its black and white then you can press the set-up or menu button to correct your settings.
May 18, 2009 | Cyberhome CH-DVD 300 DVD Player
How to reset my Denon DN-V210 DVD Player to factory default?
Hi Jason,
I have just bought this unit and have been using the menu recently. The only ways i can see to do it would be to either, (as you say) plug it into a HDTV, or navigate the menu blind and hope for the best.
If you press SETUP on your remote once to get to the menu setup screen and then push the RIGHT navigation button 3 times this should take you to the system setup screen. Then push the DOWN navigation button 4 times and then push ENTER. At this point it asks you for a 4 digit password to reset the unit which is a factory preset, 5555, so type that in. This should then reset the DVD player to factory settings.
Hope it helps,
Nick
Nov 14, 2008 | Denon DN-V210 Player
No picture how do i re set nothing works
This might be a case of the player being in the PAL system. Your player is supposed to employ both PAL and NTSC systems. Just look for a key listed N/P on the remote.Press that key once, and you are supposed to be ok.
Jul 23, 2008 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
66 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
