Question about Jacques Lemans Stainless Steel Swarovski Crystal Watch for Women
Jacques Leman F1 Crystal needs replacement
Where can I get a new crystal installed in my Jacques Leman F1 watch?
  • hroark62 Jan 07, 2009
    I appreciate you assistance but have been unable to act upon it yet.
  • Anonymous Mar 25, 2014
    i need a stainless steal strap for jacquse lemans f1 watch model number f5011f can you help
    Champion:
  • 203 Answers
Look up horologists in your local area. some of them can cut a new one. joe
Posted on Dec 10, 2008
How can I changw the glass for this watch?
In order to replace the crystal on your watch you are going to have to remove the entire movement and use a watch press to remove the crystal.
this is not an easy job and should be done by a professional
First you will need to get a watch back opener to unscrew the back of your Tag. The three slots should fit into the back of the watch. tighten the opener until it is firmly on. then turn counter close wise until back of case comes off.
Next you will need to remove the watch hand and crown. Becareful doing this for pressing to hard will break your set leveler. You will need a thin pin pusher and look on the back of the movement for an arrow pointing toward a hole in the movement. Push down and at the same time pull the stem and crown out of movement. turn the watch right side up and the watch movement should fall out. Place movement on a very safe spot so not to damage movement or dial
now you will you be ready to remove crystal Since it is a friction crystal you will need to do use a watch case press . find two die that fit exactly the watch and crystal use a scooped side and place it on the bottom side of the watch press. Next use a flat die to place on top of the case press. place the watch face down. you will be pushing the watch crystal out from the top. Press down on the level and check to see if the crystal came loose, keep doing so till the crystal comes out.
finally you will need to measure the thickness and diameter of the crystal and find the exact size. I believe this watch has a sapphire crystal so you will need a sapphire crystal too.
Once you buy the proper crystal it is time to put the it in the watch. Place the watch face up in your watch press. and slip the crystal in through the top making sure its perfectly even all around. Slowly push down on the leveler until proper pressure is applied and the crystal snaps in.
Now you have new crystal . Clean crystal thoroughly and the inside of the case. Place watch upside down carefully place movement back in. slide spacer in . Now slide watch stem and crown back in push down again on the set leveler with pin pusher.
Place case cover on back and tighten properly to prevent water or moisture from entering and you are done.
This repair should be done by a professional especially on such a nice watch. Any watchmaker can do this job and will have the tools to do it properly
Jan 27, 2012 | Tag Heuer Carrera GMT WV2113.FC6169 Wrist...
The crystal of my wife's skagen watch popped out and the nylon ring surrounding the crystal seems too big to get back in, or perhaps I just don't have the right tools. Help!
Watch crystals are pressure fitted to their cases so that they are resistant to popping out. Think of a champagne cork, and how it expands when it comes out of its bottle.
Crystals are set into cases in one of several basic methods. First, a crystal may be installed from the back--watch cases are commonly assembled before the movement is installed. So, one potential way of reinstalling your crystal is to remove the watch movement from the case (if it isn't already) and try pushing the crystal from the back forwards. If this is indeed the way it was installed, the crystal should pop into position with a noticeable click or light thump to let you know that the other edge of the crystal has found the shallow groove in which it's supposed to sit.
Second, some crystals can be installed from the front using a tool called a "crystal lift." This tool has many little fingers that compress the edge of the watch crystal so that it can be slid into the case. Pressure is then gradually removed from the crystal, permitting it to expand into the shallow groove into which it's supposed to sit. Crystal lifts are easy to use in theory but somewhat finicky in real life; the crystal must be grabbed equally by all the lift prongs or else the crystal will have a tendency to squirt out of the tool before it's been completely set.
Looking at pictures of your wife's watch, it doesn't look to me like a crystal lift would do any good. I think instead that your crystal might have been installed using a third method. Looking at the pictures, it looks like the bezel--the metal top of the watch--separates from the watch body. If this is the case, gently pop off the bezel and push the crystal into it from behind. Then, push the bezel back onto the watch movement. It's possible that the crystal is kept in place by being squeezed between the bezel and the rest of the watch case.
If all of this sounds daunting, putting the crystal back in--assuming it's not cracked--is a minor job for a watch repair technician. It literally might only take 5-10 minutes to complete the job. If you're concerned about the appearance of the watch, it might be safest to pay someone the small amount of money to get this done right. Replacing a watch crystal with a new one usually runs about $15-25, around where I live. Replacing an undamaged crystal that's popped out should cost appreciably less, since a new crystal costs a jeweler between $5-25 for most standard sizes (diver's watches and strange specialty shapes will cost more).
May 16, 2011 | Skagen 358SSSD Wristwatch
I am looking for a replacement crystal for a jacque Leman watch 1-1326 the crystal is pink and is on the outside. Thanks
Thank you for contacting FixYa.
I would recommend going to this link and looking for a local dealer or just contact JL at this sight,
http://www.jacques-lemans.com/site2010/?Lang=en
Best regards. Jewel
Oct 21, 2010 | Jacques Lemans 1019K Wrist Watch
I bumped and chipped the crystal. Is it possible to have a new crystal sent to me?
mcdevito75 here, That may depend on the watch and the maker of your watch, as sometimes a new crystal is only available thru the watch manufacturer, if so, the watch manufacturer may want to install the new crystal themselves. If your crystal is made by an after market company then yes you could get a new crystal sent to you. Look for a small watch repair shop in your area to find out for sure.
Aug 11, 2010 | Beverly Hills Polo Club Dress #52012 Watch...
I need to replace to a F5011E F1 style the Caoutchouc grain strap
The only thing I can suggest is that you go to their web site http://www.jacques-lemans.com/site2010/?Site=Communication&SubSite=News " and click on "dealer locator" to fond a replacement strap.
Aug 10, 2010 | Jacques Lemans F1 Gmt Watch
After a new wrist band for a Jacques lemans F1 - red
Their web site does not list any dealers in Australia.
I suggest that you go to their web site http://www.jacques-lemans.com/site2010/?Site=AboutUs&SubSite=Standort and contact them about your problem. It may be that you will end up buying direct from Germany.
May 22, 2010 | Jacques Lemans F1 Analog Digital Watch
I need to replace a crystal on an F5020A Jacques Lemans F1 GMT watch.
Go to http://www.jacques-lemans.com/site2010/?Lang=en and click on "local dealer" to find your nearest dealer, who should be able to help you.
May 18, 2010 | Jacques Lemans F1 Gmt Watch
Sceletonized dial for the timer, not returning to top (12 o'clock) on reset.
Go to the jacques leman web site "www.jacqueslemans.com/" and you will see a menu on the left. Choose "instructions/ catalogues" .
Download the PDF file for your watch and you shopuldbe able to find the method of resetting the hands.
Feb 12, 2010 | Jacques Lemans F1 Analog Digital Watch
The crystal is cracked in my Relic mens wristwatch. Can I order a crystal on-line and replace it myself?
Problably not something you should tackle by yourself. I replace them and have experience. You would need to make measurements and order from a place that has inventory. Then you would need to remove case back and movement. Then you would push out the crystal from the inside. The new crystal needs to be installed with the proper "glue". This also needs to be ordered. I suggest you take it to a local watchmaker that knows how to do this. But, best of luck
Oct 02, 2009 | Relic Multifunction Watch
Need to replace crystal on Luminox 3000
All types of crystals are available worldwide.
Visit your nearest watchmaker and he will be able to supply new crystal and fit it.
Dec 04, 2008 | Luminox Navy Seal Dive 3001 Wrist Watch
Jacques Lemans Stainless Steel Swarovski Crystal Watch for Women Logo
414 people viewed this question
Top Jacques Lemans Watches Experts
Ansel Alberto
Ansel Alberto
Tom Chichester
Are you a Jacques Lemans Watch Expert? Answer questions, earn points and help others
