Question about Mitsubishi WD-62531 Projection Television
Mitsubishi tv model wd-62531 less than 2 years old
Today out of the blue my tv stopped working. It was on then all of a sudden "click" the tv turned off and a red light is constantly on on the front panel. I try turning it on and the green light comes on I hear a few seconds of audio (black screen) and again "click" red light. It's really driving me mad because this tv isn't that old to be having this problem.
HELP!!!! venussuperstar76@yahoo.com
It sounds to me like your bulb has burned out. Look behind your TV for where the bulb housing is and pull the bulb out to check if it's burned out or not. You'll know when you look at it if it's toast.
Posted on Jan 27, 2009
I turn on my Mitsubishi WD-73833 TV and it turns itself off
Lessing of brightness on a DLP set is a sign of imminent bulb failure.
A new bulb is in order.
Nov 23, 2013 | Mitsubishi WD-73833 73" HDTV
Need a Mitsubishi WD-62531 Lamp. I have 2 part numbers which one is right?
go to www.shopjimmy.com
when you search brand and model it will appear..
Jun 07, 2012 | Mitsubishi WD-62531 Projection Television
My Mitsubishi wd-62531 has a yellow hue over half of the screen. What do i need to do to fix it?
Not a cleaning issue.
The lamp shines into a OPTICAL LIGHT ENGINE, which has a series of lens and baffles---blue is the first part of the engine to get that light and heat---in your case the blue area is damaged from the heat----minus blue equals yellow.
The entire engine would have to be replaced--not a cheap part--Google the model number with "light engine" to get an idea of cost.
May be time to either use it as is or ?
SD TECH
May 26, 2012 | Mitsubishi WD-62531 Projection Television
Were is the lamp cover of the mitsubishi WD-62531 at so i can change the lamp
It's on the back of the tv, located on the left while facing the back. There are 2 screws holding the lamp cover and 2 more holding the lamp.
Sep 14, 2010 | Mitsubishi WD-62531 Projection Television
I HAVE A 65 INCH MITSUBISHI TV WD-62531, WAS WATCHING TV, AND ALL OF SUDDEN THERE IS A BLACK FILM ON THE BOTTOM OF THE SCREEN. CAN ANYONE HELP ME OUT WITH THE PROBLEM, PLEASE EMAIL MIKEKIMA@HOTMAIL.COM
Have a Mitsubishi 65 rear projection menu keeps fading on and off, any ideas of the problem. Bulb just replaced 2 months ago, no problems with bulb. Also a DVD works fine, but tv picture will not come on.
Dec 24, 2009 | Mitsubishi WD-62531 Projection Television
Mitsubishi WD-62531 Replaced lamp 2 weeks ago. Red light flashing again. Same problem but the lamp is fine. Sound but no picture.
You have either a bad ballast (it powers the lamp) or a bad DMD board. Either one of those will result in a no lamp fire issue. Have a technician look at it...
Oct 17, 2009 | Mitsubishi WD-62531 Projection Television
Mitsubishi Model # is WD-62531 cracked screen!
HI, there are no replacement screens available for this model unfortunately. Sorry for the bad news there...
Apr 20, 2009 | Mitsubishi WD-62531 Projection Television
I have a Mitsubishi WD-62531, it is almost three years old and has gone through 5 bulb. Is there something I can do to make this bulb last longer? Is there something that I can check that may be causing it...
The biggest enemy of bulbs like that is heat. Make sure the fans are running and are clean. Make sure the fan stays on for a while when the unit is turned off. Other than that there is little you can do without adding a fan or other modifications.
Oct 29, 2017 | Mitsubishi WD-62531 Projection Television
Mitsubishi WD-62531 Projection Television Logo
215 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
