Question about Toshiba 36A43 36" TV
Power surge I think
The TV will not turn on after an electrical storm. The power button still shows a "red" light when plugged in. But TV will not turn on. No clicks, nothing. Tried the "hard" reset. But still nothing. Is the TV salvagable? Could it be a fuse or something that needs replacing? The TV is relatively new but out of warranty and extended warranty. Thanks for your help.
  • Melvin Rice Feb 28, 2007
    TV is too heavy to "take" to a repair station.
    President:
  • 3,130 Answers
If you do not get any clicking or sound when trying to turn on the TV set, most likely the main fuse went out. This is almost always due to something else blowing out along or making the fuse to blow out. DO NOT SIMPLY REPLCE THE BLOWN FUSE! If there is other shorts inside the set, and you replace the blown fuse, you can cause more damage to the TV set. The best way to test this set if the fuse is blown would be to hook up a 100 to 150 watt light bulb across the blown fuse, and if there is a short in the TV set the light bulb will glow bright and stay bright. If the bulb lights up and goes dim maybe just maybe you got luck so replace the fuse and see what happens. If the light bulkb stays bright, there is a short in the set somewhere and if you do not have a service manual and a good multimeter and a knowledge of how the TV power supply works, you really should call in a pro to assist you in the repair of this TV. there is just too much High Voltage inside these TV sets to be experieenting around inside of it. Good Luck.
Posted on Mar 16, 2007
My 32 LED TV won't turn on and there is a dim light that comes on and off as it is on the off position
There may have been a voltage surge that affected the electronics. You might try unplugging the set and while so holding the power button . Than after about 30 seconds release the power button plug it in and turn on. If still no go, then the surge damaged probably the power supply section of tv. That is the first component to receive the hit of the surge and the most likely to be adversely affected.
Aug 30, 2015 | Televison & Video
LN55C750R2FXZA Samsung LCD
What your describing is symptoms of a power surge, Many LCD Tv's are sensative to Slight fluctuation in power during rain, thunder and lightning storms, i myself was happily watching Tv through such a storm at one time, and when i went to bed the TV would not respond remotely or manually, i also disconnected the power from the wall waited for the ready light to disolve and try to turn on, unfortunatley the damage was done, a Tv Repair was nessecary and since then i now use a belkin power surge protector board for my TV and appliances......one question to you is i would guarantee you do not use a surge protection my friend......and your set will need a Tv Repair, it is not major as what is neccesary is a firmware dump on the internal memory and replace the BIOS Battery as well.
Aug 17, 2014 | Samsung UN55B8000 55 in. LCD HDTV
My sharp LC-46SV50U wont turn on
get the service manual and then open it up and do a voltage check on the 5v standby.
if it's not showing anything, then you need to hunt down if it's the ic, cap, or diode or a combination thereof.
Nov 24, 2013 | Sharp LC46SV50U - Lc46sv50u 46in Lcd Ccfl...
My printer will not turn on. We had a storm
Solution one: Press and quickly release the Power button Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold down the button . Figure 1: Press and quickly release the Power buttonc01896071.gif c01733891.gif If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution two: Check the electrical connections and outlet
  1. Unplug the power cord from the electrical outlet, or the power strip or surge suppressor. Power module Power cord c00745315.gif c00057913.jpg
    NOTE: The power cord detaches from the power module. The term power supply refers to both the power module and the power cord.
  2. Carefully inspect the power cord for visible damage. c01733891.gif If the power cord or power module shows any damage, contact HP to replace the power supply.
  3. Disconnect the power supply from the back of the product.
  4. Wait at least 30 seconds, and then plug the disconnected power supply into an electrical outlet. Do not use a power strip or surge suppressor. c01733891.gif If the green light (LED) on the power supply does not light up, contact HP to replace the power supply.
  5. Reconnect the power module to the product.
  6. Press and quickly release the Power button (c01602202.gif ) to turn the product on.
  7. If the product still does not turn on, connect the product to an electrical outlet in another room, and then quickly press and release the Power button (c01602202.gif ) to turn on the product.
    • If the product turns on , the electrical outlet in the original room caused the issue.
    • If the product still does not turn on , continue with the next solution.
Solution three: Check the USB cable
  1. Disconnect the USB cable from the back of the product. Figure 2: Disconnect the USB cable from the HP productc01896072.gif
  2. Press the Power button (c01602202.gif ) to turn on the product.
    • If the product turns on with the USB cable disconnected , replace the USB cable.
    • If the product still does not turn on , continue to the next solution.
Solution four: Check the batteryIf your HP product has a battery, follow these steps:
  1. Check the battery light. If the light is red, recharge the battery.
  2. If the battery light is still red after recharge, replace the battery. Figure 3: Removing a battery (example only)c01468528.jpg 1 - Slide the battery release slider in the direction of the arrow 2 - Remove the battery
Instructions for recharging and replacing a battery are available on the HP Web site. Solution five: Replace the power supplyIf you have completed all of the troubleshooting steps and are still experiencing a problem, contact HP to replace the power supply for your product. Solution six: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product.
Nov 25, 2009 | HP OfficeJet 7410 All-In-One InkJet...
TV LOCKED
the red button is just a standby mode on most models, there is a possibility that a capacitor blew inside or is leaking that is why the power that is supposed to turn your tv ON is not working. did you have any power surge in your place, or a storm perhaps?
Aug 13, 2008 | Televison & Video
Hitachi 60UX58B will not turn on
I think there could have been a power surge... ask the repairman if the power supply is blown. :)
Jun 18, 2008 | Hitachi 60UX58B 60" Rear Projection...
Blinking light wont turn on Toshiba TV CE19H15
Yes, it's quite possible that you indeed may have sufferd from a Power Spike, induced by lightning during the storm, esspecially if plugged in during said storm. I have had quite a few customers ova the years with this exact problem. I always advise my clients to unplug ALL devices during a storm, and for ones that simply cannot be unplugged then some sort of Spike/Surge Protection device MUST be used. As a matter of interest, I have written many a report to insurance companies to support a claim for a replacement.
Aug 08, 2007 | Toshiba 19A26 19" TV
Toshiba 36A43 36" TV Logo
416 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
