Question about GE Profile Spectra JGBP85 Gas Kitchen Range
Ge gas kitchen range 2 igniters work and 2 don't
Left side igniters do not spark, right side works fine. ??
  • Anonymous Mar 13, 2014
    on a gas range the ignite continues to spark
  • 6,674 Answers
Lift top upward & look under, you'll probably see small wire(s) running to ingnitors, see if perhaps wire fell off side not working.
Posted on Dec 10, 2008
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
Igniter clicks on the wrong burner
The spark supposes to go to all burners. The spark igniter of the non working burner needs to be replaced.
Sep 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Tappan MGF500PBWH right side won't ignite
Helpful when people chime back in once a solution is achieved.
"bad igniter" above was incorrect terminology. "spark module" would be correct.
Problem was the 3 wires on the spark module. They all look the same, but must be seated correctly onto the proper connection. Failure to do so will result in the issue I first described. Seated all 3 correctly and now all burners (and oven) have spark.
Aug 27, 2009 | Tappan MGF500PBW Gas Kitchen Range
GE gas range igniter continues to spark, won't shut off.
Often times, just leaving the range unplugged for a time will solve the problem, which is most often caused by water or a cleaning agent getting into an igniter switch behind a burner knob. After the switch drys out it usually starts working again. In the mean time, you can still use the burners by lighting them manually with one of those long lighters, but you will not be able to use the oven or broiler without electricity. If the range continues to spark after being left unplugged for more than a day or two, you will have to determine which switch behind the burner knobs is causing the problem. Please don't bother rating, as anything but a Fix-Ya will lower my score. Thanks.
Feb 18, 2009 | GE JGBP28 Gas Kitchen Range
GE Gas Kitchen sealed burner
I unplugged the wires from each end and re-attached the wires. Stove working great, no more clicking.
Dec 29, 2008 | GE Kitchen Ranges
Burner will not ignite.
facing the spark ignition, the burner has small holes that need to be clean, those holes are going down on the side of the burners, take a look a the ones that are working so that you can see the small flames going down facing the electronic pilot call the spark ignitiong, you can take a safety pin or a paper clip and clean them. many times the ignition is between the front and rear burners, it's where the spark ignite the burners.
Dec 13, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Only one burner of four not working
sounds like a bad switch in the knob, turn on the defective side, turn on the one that works and keep the clicking going then turn on the defective burner while "other" is clicking if this lights then it means you have a bad switch or loose connections
May 31, 2008 | GE JGBC20 Gas Kitchen Range
Ignition on gas hob fails sometimes on certains burners
open the hob covers with a screw driver and check the wires that carry the spark are intact and haven't been chewed by a rodent ie (RAT/MOUSE) like my one had been :-)
Apr 28, 2008 | Rangemaster Proffessional 110 Gas Kitchen...
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP85 Gas Kitchen Range Logo
158 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
