I have a gestetner 9920 fax that is giving me a check paper size when it starts to pull paper to print a incoming fax.
    Problem Solver:
You mentioned you have a kit or had a kit to repair the Toshiba 42DPC85 Plasma w/no picture but you did not respond to any inquiries. If you have this part of info. on where to get it, there are 4 interested people, including me, who would like to know. E-mail info@kevlau.com with the info. ASAP. Thank you.
Posted on Sep 01, 2009
Pitney bowe 9920, incoming faxes have black vertical columns on each side, with white or normal print in center.
Have you changed the toner cartridge? Often the disposal part of the image unit gets full and leaks out when the cartridge is reaching the end of its toner supply. This will leave black messy streaks on paper, and also make a mess inside the machine. Look inside the machine, if there is a mess, it is the cartridge.
Jan 13, 2010 | Pitney Bowes Office Equipment & Supplies
Moved my gestetner 9920 fax to a new phone line,now it just ring and does not answer .
Reception mode may have been changed. press the "reception mode" key, and make sure it is set to "automatic", rather than "manual"
Jun 13, 2009 | Gestetner Office Equipment & Supplies
Disabling the fax function
You can set the fax portion of the machine to manual receive like this:
"User tools"
"fax features" ok
"reception settings" ok
"switch reception mode" ok
"Manual reception" ok
"user tools" to exit
Thia will prevent the machine from picking uo any incoming faxes
....However, if the machine is jamming trying to print a 'fax' report, it will jam regardless of the feature you are using -they are unrelated. Depending on the cause of the jam, it could be a specific tray that is causing the problem, so you may want to remove the paper from that tray, and see how it works. The other reason, that is common for jams from one particular tray is that the size is set incorrectly. Check that the paper size dial on the tray is set for the appropriate size in the tray (including orientation).
If none of this helps, please describe the location of the jams, and I may be able to give further advice.
Apr 23, 2009 | Gestetner - DSm618d Digital Imaging System...
Machine refuses to print incoming fax. "Paper mismatch"
HP Printer 7210 or 7310 Gives Error receving faxes Load a new blank paper on paper tray.
Press * and # simultaneously, and then release both buttons.
Press 1 , 2 ,and then 3 . The Service menu appears.
Press the right arrow button (>) until the System Configuration menu appears then press OK.
Press > until Media Sense Calibration or Calibrate Spot Sensor appear and then press OK. The unit should pick the paper and eject it.
Press the Cancel button until date and hour appear on display
Mar 05, 2009 | HP Officejet 7210 All-In-One InkJet...
Canon Laser Class 3175 facsimile, incoming faxes are being saved in memory, will not print. Cannot clear error message "check paper size".
The problem is that you have a fax saved in memory that is the wrong size for the paper you have in the drawer. Probably it is a legal size, whereas you have letter size in the drawer.Just place some legal size paper in the by-pass tray to print.
May 11, 2008 | Office Equipment & Supplies
Cannot print from Tray 1 in Gestetner 6002
First make sure that the machine is reading/ seeing the paper size of the paper that is in the tray ( select tray 1 from the touch screen and see what the paper size reads). If the machine sees a different size then that in the tray, use the 'user tools' and change the paper for that tray. Also, go into your printer settings on/in your computer and make sure that the proper paper size is selected ( the size that is in the tray you want to print from). If the orientation of the paper size is different from the tray -- will not print and give you the error.
May 06, 2008 | Gestetner - 6002 Digital Imaging System...
DOES NOT PRINT INCOMING FAX- PAPER COMES OUT BLANK
Have you tried a new toner cartridge?
Did you pull the plastic tape on the cartridge?
Mar 21, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Incoming fax problem
DON'T KNOW IF THIS WILL HELP-BUT MY PROBLEM WAS SIMILAR--MINE WAS SAYING PAPER TOO NARROW WHEN I WAS TRYING TO PRINT AND COPY. I JUST KEPT MOVING THE FRONT SLIDER AND THE LEFT HAND SIDE SLIDERS BACK AND FORTH AND TOOK THE PAPER IN AND OUT --TRIED AGAIN AFTER EACH TIME--IT EVENTUALLY FIGURED OUT I DID HAVE THE RIGHT SIZE PAPER--
ALSO TRY---MENU--THEN--COPY SET-UP--THEN PAPER SIZE--SEE IF PAPER SIZE IS SET RIGHT.
Mar 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Incorrect paper size
You may have a fax in memory that requires a larger size. Try putting legal in the tray and see if it prints out anything. Also, look in the set up menu to see if there is an "auto reduction" mode. That will make any over sized incoming faxes automatically print out on the size paper you have in the tray.
Nov 17, 2007 | Canon FAX-L380 Plain Paper Laser
27 people viewed this question
jasbo
jasbo
