With my monitor turned on it stays white whith computer power on or off. However when the monitor is turned off it goes black. I have checked all cables and connections, they are fine. What should I do? It is a HP wq1907 and is only three months old.
-   i have the same problem, my monitor stays white when it's on doesn't matter if it is hooked up to a cpu or not, have tried cables that work with another monitor but it doesn't matter, I can even change the brightness but no picture just a white screen.
-   Guest
Feb 13, 2009
-   I have, more or less, the same problem with my two year old 22'' LCD Samsung monitor. When I turn on the monitor, a white screen comes up. I then have to wait 2-3 minutes and turn the monitor off and on to get the picture up from the CPU. The screen flickers then for about 10-15 seconds and the brightness is lowered on the screen. After about another 60 seconds the picture becomes clear and all aspects seem normal. It seems like it is taking the monitor 4-5 minutes to warm up each time it is turned on or is awaken from sleep mode. I have tried my other monitor on the CPU and it seems to work fine so I believe it is the monitor, not the CPU. Is there anything I can do to end this problem or would it be better to simply buy a new monitor?
-   RevengeYuri
ok here could be 2 problem
1 your computer done send video signal
2 cable it is bad
you should try first to other computer to see if work , if yes that means your computer it is with problem , if not work that mean your monitors dont receive signals
Ladies and Gentlemen, I have the Sony Monitor SDM-S75A. For several months are seen in the upper...
(More)
Ladies and Gentlemen, I have the Sony Monitor SDM-S75A. For several months are seen in the upper left corner of several bright stripes with up to 14 cm in length. How can this error can be eliminated? It would be nice if you could help me. Many greetings from Bernd Dietrich bdgrafik@gmx.de
the monitor led starts a beep a soon as i start my pc n after a lot of adjastment of power cable the...
(More)
the monitor led starts a beep a soon as i start my pc n after a lot of adjastment of power cable the pc starts
My Acer AL2423W Monitor worked great for the last year or so. Suddenly this morning it shows a black...
(More)
My Acer AL2423W Monitor worked great for the last year or so. Suddenly this morning it shows a black screen on start up. The Acer logo flashes dimly and the screen returns black. Windows is powering on in the background - but no start up scripts or anything. If I turn it off and on - same thing - Acer logo flash then black screen. Unable to get to menu or any usable buttons. Any suggestions?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
