Question about Kirby Vacuums
How do I attach my hose to the vacum to use the accessories
  • 35 Answers
Make sure the height adjustment is all the way up on the highest setting.(This makes it easier to remove or replace the brush head or accesories.)Turn the belt lifter knob on the brush head all the way counter clockwise.Raise the headlight assembly to expose the brush head lock.Unlock the brush head and remove,then attach the hose to the machine,and lock it down.The hose is now ready to be used.
Note:When removing the brush head,make the belt lifter knob the fist thing you turn when removing it,and the last thing you turn taking it off.
Posted on Dec 15, 2008
My vacum cleaner won't pick when attached to the parts or bottom
Hi, it's Allie from Crucial Vacuum.
It sounds like your unit may have a blockage. Checking your hose for any blockages is very easy. Remove the hose from both ends and check for blockages, any leftover debris or clog will not allow the unit to have suction.
You can purchase direct your replacement belts, filters and rollerbrush from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dirt-devil-f1-kit.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Sep 04, 2014 | Dirt Devil Breeze Bagless Cyclonic Upright...
Where do you hook up hose
Years ago I used to sell and demo kirbys up to the G-5 model,I believe you have to sit in front of your vacume,raise the wheels as high as they can go and on the logo face tun the crank one way,this loosens the belt and give a little tug and the roller sucking chamber will drop.Pull the chamber away.,now take your hose and stick it over the shaft and lock it down with the wing nut and then you can use all your vacume attachments.UNLESS YOUR TALKING - vacume bag hose- this is just a simple twist and click on the vacume exhaust chamber. Now if your hose is unhooked in your vacume bag it self,you will have to get a new bag attachment or get a repair man to look at it.
Jan 08, 2012 | Kirby G6 Bagged Upright Vacuum
My Bissell bagless vacuum does not seem to work anymore. It will start to with a suction and then instead of picking up the dirt, it appears to blow the dirt out almost in a cloud of dust and debris from...
this is caused by a dirty air filter and/or a blocked vacume hose ( most of the time the blockage is at the bend where the hose enters the floor sweeper area ) ---
remove and tap out and brush the filter ( or use a air compressor to blow out filter ).
then with the vacume on its side - remove the bottom plate ( like you were going to change the belt ) and use a coat hanger and clean out the hose between the floor sweeper and where the suction hoes attaches. this will restore your vacume to full operation.
c...
Jan 23, 2011 | Bissell 6595 Lift Off Bagless Upright...
Eureka Maxima 12 amp vaccum cleaner is not picking what can be done to make it pick up?
remove and clean the filter ( tap and brush filter or use a air compressor to blow out filter ) --- also check the vacume hose near the floor attachment for any dirt and debris that may be clogging the line. this should bring your vacume to full operation.
c...
Jan 22, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
Where you plug in hose to use attachments
Hi, Your vacuum should have complete set of accessories when you purchased the unit. Your hose has snap lock system. Just check the accessories you need to make snap connection of your hose. Unless you have the missing parts.
Regards,
Dec 17, 2010 | Fantom Vacums Cyclone XT Upright Vacuum
The vacume was plugged. Believe I unplugged it, but now it just blows air OUT, does not **** in. Everything is emptied and cleaned. Don't know what to do next. Just had new carpet installed today, and...
Even tho its empty and clean, if the hosing is blocked up then it will not **** up anything.
The hosing down below the attachment hose may still be blocked up and that will have to be cleared for it to suction again.
remove the attachment hose look down the hose at the back. you can also flip over the machine and look for the attachment hose to come to the brush roller. I assume it is blocked up there and not picking up properly.
Good luck.
Nov 06, 2010 | Hoover Elite Rewind Bagless Upright...
Dyson DC17 Found the clog-how do I unclog it?
poke it out with a screwdriver this will dislodge the hair it might take a while to get it all out
Sep 27, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacum won't ****
Do you have good suction right out of the canister without the hose attached? If so, AND your hose isn't plugged, you must have a pretty good sized hole somewhere in the hose. If you don't have suction at the canister, pull the filter cover off the top-back of the machine and remove the filter. This is where all of the air that the machine pulls in is exhausted. If something is plugged here, it will greatly reduce your suction. If you still haven't found the problem, you could have a problem with the fan assembly on the motor. But usually this is accompanied by some noise from the motor, but not always. Good Luck!!
Jan 03, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Kirby vacum cleaner
TURN THE BELT LIFTER IN THE FRONT CLOCKWISE UNTIL THE RED ARROWS LINE UP. NOW TURN THE LATCH AT THE TOP OF THE POWER NOZZLE AND TAKE THE NOZZLE OFF. HOOK THE HOSE EVENLY ON THE BAR BELOW THE FAN, LEAN IT UP AND LATCH IT ON WITH THE LATCH.
IF YOU NEED ANY MORE HELP WITH THE POWER NOZZLE, SEE MY ONLINE GUIDE...
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
HOPE THIS HELPS!
MARCI
Nov 09, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
257 people viewed this question
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Roger Potts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
