Question about Maxent MX-42VM 42 in. Plasma HDTV
Screen stays blank after turning it on.
I can hook up the power supply to it and it shows it has power and when i go to turn it on the power light turns from yellow to green as its supposed to, but the screen remains off. i have had no problems of the screen getting darker or losing color as if the tv was going out it just happen. i have had this tv for only a year, unfortally thats when the warranty goes out. i lost the manual while moving so i cant refer to it.any help would be great.
  • 2 more comments
  • isaacsilva Mar 07, 2008
    I am Having the same problem. The green light turns on and stays on, you can hear the sound for 5sec tops, no image at all, and then you hear the relay going off.
  • Anonymous Jun 08, 2008
    IT TURN OFF BY ITSELF MOST OF THE TIME WHEN YOU DO GET IT TO STAY ON NONE OF THE BUTTONS ON IT WORK YOU CAN GET INTO THE MENU OR NOTHING BUT FOR THE MOST PART IT TURN OF
  • kjh714 Oct 27, 2008
    tv will not turn on but I hear the relay clicking, I need a sch of the board to a repair manul
  • mrsenrats Jan 01, 2009
    Maxent MX-42VM 42 in. HDTV Plasma Televisionno pcture won't turn but on the standbye light comes on
    Sniper:
  • 80 Answers
Hello, The blinking pattern you're observing is a result of a heavy current load on the power supply. The power supply could be defective but more than likely the scan or sustain boards have a direct short on them causing the power supply to shut down and display the error. A technician will be able to determine where the load is coming from and replace the appropriate board or component. I hope this helps you. Joe Weibel CustomElectronics.Org
Posted on Apr 24, 2007
SOURCE:
Blue light turns on but tv screen stays blank
The blue light indicates power is getting to your TV but there may have been failure of the internal power supply
Jul 07, 2013 | Sceptre Televison & Video
Sanyo dp42848 turns on but blank screen
Replace the Main board if your not hearing any audio from the set.
Oct 27, 2012 | Sanyo DP42848 LCD TV
My Soyo monitor (DYLM1998) stays blank (black) except when it is turned on, the monitor shows a picture for 2 seconds and then goes blank again. If I turn the monitor off/on several times, it finally...
your power supply has a short in it this is comon ive seen this before try to replace cord if attatched take it to someone for repairs if not attatched its the cord most of the time loose wire..
Apr 10, 2011 | Soyo DYLM1998 Monitor
My projection television will stay on for awhile and then the screen goes blank and the projector turns off, my satelite, my reciever, my surround sound all stays on. I am left with a blank screen with no...
When you mentioned blank does it have light on. If not check the filter for cloggging as the heat build up on the lamp can trigger a stop. Use a good forced cooling to confirm.
If the picture is clear and there is no illumination issues the bulb must be good and the issue may be power based.
If the main power supply can be cooled off , does the fault apppear, if so check the soldering of the power supply.
unless all this is confirmed the problem of the suspected bulb can stay.
Sep 19, 2010 | Televison & Video
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Ps3 turns on with green light an doesn't show users screen blank
Your tv screen has problems with the video mode
that has setted up on your ps3, hold the power button till hear two beeps, this will reset the video mode of the ps3, and leavse you at a screen to set up the video mode of the ps3.
Succes.
Sep 03, 2009 | Sony Playstation 3 (PS3) Console
Blank Screen
HI there.
Try booting into safe mode by pressing F8 while the computer starts up.
If you can get it into safe mode perform a system restore.
If it won't boot into safe mode please post back.
Good luck and thanks for choosing FixYa!!
Jun 02, 2009 | Acer TravelMate 4230 Notebook
Hp1903 blank screen
power shortage maybe...try to plug your monitor on the other power supply,,be sure that your monitor is compatible on the voltage it required..
Aug 04, 2008 | HP vs19 (Silver) 19" LCD Monitor
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Philips TV model number 27PT543S37A
TV turns on but doesn't stay on goes in and out then blank screen. LED light stays on during the entire time your problem is called hunting you can check power supply of your tv .It common problem in Philips T.V. Thanks
Sep 11, 2007 | Panasonic CT-32SX12 32" TV
Maxent MX-42VM 42 in. Plasma HDTV Logo
243 people viewed this question
Top Maxent Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
