Question about Microsoft Xbox 360 Console
Samsung, xbox problem
I have a samsung series 4, 42" plasma and have my xbox 360 plugged in to it. The colour has darkened a lot but only when i use the xbox. The xbox is OK as i have used it on another TV and called xbox support to reset any settings. i have also reset the settings on the TV. the xbox has been OK for the first few months but now unusable. I have also checked all connections!!
  • 148 Answers
Try to change the hdmi cable...
set your plasma hdmi input...
Good Luck
Posted on Dec 10, 2008
Had the box 360 60gb for 3 weeks. Been running it via the tv scart option with yellow wire and audio red & white. Worked for 3 weeks until during playing Assassins Creed Brotherhood the screen went...
Maybe someone stepped on your cables try getting different cables.
For example if your tv is hd get a hdmi cable or buy another set of those cables.
Maybe it will help.
Jan 04, 2011 | Microsoft Xbox 360 Console
Ive plugged my xbox into a plasma using the rgb cables, but when i turn my system on the screen only shows thin lines of colour, i tried just using the normal video cable, but the same thing happened....
XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console...
click here to download repair guide
Jan 03, 2011 | Microsoft Xbox 360 Console
My controller wont sync to my xbox even when i use plug n play cord. it just flashes and im not sure if it is an electrical problem or not
there are series of problem in xbox 360 which can be solved without much technical knowledge ........ your problem belong to that so dont worry i will give you the link to download the ps3 repair guide that will help you a lot
all the best
Dec 08, 2010 | Microsoft Xbox 360 Wireless Controller
My xbox headset will not shut off when i put into a new xbox 360 wired controller
there are series of problem in xbox 360 which can be solved without much technical knowledge ........ your problem belong to that so dont worry i will give you the link to download the xbox 360 repair guide that will help you a lot Click Here
Aug 20, 2010 | Microsoft Xbox 360 Controller
Hooking up an xbox 360 console to a 50 '' plasma tv hd need a diagram
A few questions.........what model are you using and what kind of connection??
I have a PN50A450 from Samsung and use HDMI. I also need to know what kind of 360 have(newer or older,HDMI out of none)
Jul 08, 2010 | Microsoft Xbox 360 Console
How to put input on a samsung plasma? I have a samsung plasma and I am trying to connect an Xbox, can someone help?
you will have to use component cables with rca's
from xbox plug to rca to plasmas component input
use your plasmas remote to locate a channel to tune int channel o your xbox,when you turn on xbox the start screen should show,dont need a disk for tuning just playing
go forth and have fun .
Cheers MISTERDJ
Apr 11, 2010 | Samsung (TN-RBNG10) TV Input
No output to plasma
My Xbox 360 Do a Red light of Death
NOTE: If you are getting the three red lights and you have not opened your console by all means call Microsoft first at 1-800-4MY-XBOX this will get you in touch with customer support.
For the rest of us who have opened their console for one of many reasons like adding a suped-up case or even a well overdue cleaning for that matter, there is a viable solution; the "x-clamp fix".
For most consoles only the GPU x-clamp needs to be replaced, but some also require the processor clamp be replaced as well. For this tutorial we will be doing both clamps at the same time. We suggest you do both right away since even if yours does not require the processor clamp replacement it will not hurt to do it and it only takes slightly longer to complete the fix.
Dec 18, 2009 | Microsoft Xbox 360 Console
Xbox 360 plays movies fine but colour is wrong on games
i will suggest if you new tv has more inputs, just try a different imput, and make sure the plugs are in all the way. this is a new tv so it will be tight.
same with the video connection on the back of xbox well plugged and straigt.
hope this woks. and remember to rate me if i helped you
Oct 09, 2009 | Microsoft Xbox 360 Console
Samsung plasma hpt5450
This set is a 1080i at best or internally 720P and X BOX 360 may not run on that set. Or maybe you can change the settings in the xbox when it is first turned on and match up format of tv and the xbox. Good luck and let me know how it all turns out. Thank you Jay
Dec 24, 2007 | Samsung HP-R5072 50 in. Plasma HDTV
XBOX 360/SAMSUNG PLASMA TV
If you have an Xbox 360 Elite or a newer Xbox 360 Premium, you should use an HDMI cable if your TV supports it. Otherwise use a component cable.
Nov 25, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
163 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
