Question about Kenmore 47783 Electric Single Oven
Nothing comes on
Turned oven on this morning started baking then everything just cut off. No lights, panel, heat no power. I tried to reset breaker but still like it is not getting power. Nothing turns on.
  • Kenmore Master
  • 3,463 Answers
If the breaker won't reset, then you have a fault with your oven,probably an element blown.
If it does reset o/k, and still does not go, then I suspect that you have no power at the oven.
You will need to gain access to the cable entry at the rear of the oven and check the wiring and connections
Plz leave feedback.
Thanks.
Posted on Dec 10, 2008
GE Wall Oven - No heat (broil or bake)
On appliances like this only the heating elements use 220 volts. things like the clock, fan, etc use 110 volts. That is why some things work and other do not. Start at the breaker, sometimes a double pole breaker will have 1 side tripped, but will look perfectly fine. switch the breaker all the way to off then re-set. If nothing changes follow the power to the appliance remove the panel and look for some fuses, check to see if any are blown. Also sometimes the microwave will have a separate power source even though its built in to the same appliance. So that's not always a good symptom to follow.
Nov 10, 2007 | Ovens
Oven comes on for 5 min then shuts down everything even the keyboard
Same problem here on JKP15WOW1WW. The cycle starts like this:
1) Open circuit Breaker
2) Open oven panel and push ribbon connector to ERC. Replace planel.
3) Close circuit breaker
4) Run to oven, notice clock flashing some time but not 12:00 and start Bake. Bake button beeps and starts bake coil.
5) Within 5 minutes hear a beep and all buttons on panel are unresponsive. Bake continues. if oven light is on it continues to glow. Only button that responds with a beep (and not to clear bake or oven light) is Clear botton.
Rinse..wash..lather...repeat...
Nov 11, 2009 | GE JKP15 Electric Single Oven
Circuitry may have gotten tripped during clean cycle. Oven will open and electronics work but neither element will heat.
baked control module for heating elements. if you have a volt meter, check for power when oven on, if no juice its the control element, if you do get juice then its the elements
May 28, 2009 | Whirlpool GBS277PRS Stainless Steel...
Whirlpool Double Oven RBD305 Display doesn't show, oven wont work
Most definitely a bad control board and/or soldered components. (The part about cutting power to the oven was a dead giveaway)
There are low and high temperature solders, but usually solder melts at 370° F. If the oven is improperly insulated or ventilated you will have continued heat stress to the control board.
Mar 31, 2017 | Whirlpool RBD305PD Electric Double Oven
Top oven doesn't heat.
We had this same problem in our lower oven and found the solution the night before Thanksgiving. With 26 people coming for dinner, I desperately need both ovens. (Turn off the breaker for the oven before you do this.)
My husband took the control panel off of the upper oven and found a wiring diagram. In the text, it said there was a manual reset for each oven in the access panel for each one. He opened the access panel for the lower oven and found the reset button in the middle of that area. He said it was a black circle with a red button in the middle. After reseting, we turned the breaker back on and everything works great!!
Nov 23, 2008 | GE Profile JTP56 Electric Double Oven
F6E0
Last night I saw the lights in the house flicker momentarily... This morning, I turned the oven on, set it to Bake and within a few seconds, the control panel reported error code “F6 E0” then shut the oven off. The control panel also reported "Lost communication...". I read on another site that this code may require replacing the control panel itself. Apparently, the momentary power fluctuation wasn't large enough to damage the electronics (since the control panel still works), but was significant enough to confuse the electronics controlling the oven. To fix the oven, I simply turned the 30 AMP breaker for the oven off for about 5 minutes. When I turned it back on, the oven worked just fine. Solution #1 recommends taking off the control panel, which voids the warranty. It's more likely that it was fixed just by cycling power to the oven via the breaker.
Oct 27, 2008 | KitchenAid Architect Series KEBC107KSS...
Neither oven will come on
Hello kybattey
Welcome to Fixya.
You said, After coming on and preheating Saturday, the upper oven went off and the lower wouldn't work either. Control paned was blank, but interior lights were on and pushing control paned buttons resulted in beeps. Turned off breaker for 5 minutes to reset and upon retry, the fan came on for maybe 5 seconds and then went off. Nothing else changed. Any suggestions?
You say the ovens went on and then later cut off.
Does the clean mode work?
Try the clean mode and see if it goes on.
Assuming it will clean!
Since the Range will clean you have confirmation that the proper power is reaching the range. It also verifies that the elements are in working condition. You will need to check the high temperature limit switch and the door latch mechanism. If either of these is defective, the bake and broil function will not operate properly
Let me know how it goes.
Waiting your response.
Huuum
Please remember to leave a rating when done!
Oct 20, 2008 | Whirlpool RBD305PD Electric Double Oven
Whirlpool oven accubake system
I have a whirlpool accubake wall oven. Half-way through baking a pie ,unknown to me, the oven went to the self-clean mode , the door locked and the pie started to burn. I tried to turn the oven off but it would not cut off. I immediately ran to the house's main power and turned off the oven breaker. I waited for a short time to let the oven cool enough to open the door and get the burned pie out, then went back to turn my breaker back on and the oven (even though in the off mode) started heating again with the bottom unit turning red again. I had to then go back and pull the power. We tried this several times trying to push the off button but the oven will not go off until we throw the breaker. Help please!
Jul 01, 2008 | Whirlpool RBS245PDS Electric Single Oven
Wall Oven No Power
yes the oven thermal fuse blew when the fan went off its also called a tco switch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
Jan 30, 2008 | GE JKP30WMWW 27" Built-in Single Electric...
Kenmore 47783 Electric Single Oven Logo
100 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
