Question about Philips Magnavox 20MS3442 20" TV
Buzzing from tv
This tv is a Crosley but that wasn't an option when chosing a make. The tv just started buzzing. It stops sometimes after awhile. What may be wrong?
    President:
  • 1,284 Answers
If the TV is working normal otherwise then most likely you have a A.C. transformer or choke that is vibrating at 60hz or what they call the deflection yoke is buzzing. Niether issue is easy to get rid of. If the buzz is comming from the speakers, make sure you have the connections to the TV are correct.
Posted on Feb 28, 2007
SOURCE:
1994amana chest freezer. Worked fine until I had
It sounds like you had a leak which sometimes happens when not used for awhile and if so you would need to get it recharged and the leakage area located and fixed.
Sep 21, 2014 | Freezers
My crosley portable turn table will start but half way into a record it stops spinning; please advise
There is a small motor under the turntable that either uses a belt to turn it or has a rubber tired roller that sets up against it and spins. You will probably be able to find a belt or rubber wheel at a TV repair shop. Some models had an adjustment on them and can be adjusted but more than likely you will need a new belt or rubber tire. The tires looj like a big square :O: Ring
Mar 12, 2014 | Crosley Audio Players & Recorders
Our Viking range is all of a sudden making a buzzing/humming noise. It comes and goes as the unit is on. It seems to start when it reaches a certain temp. then it stops for awhile. Do you know what it...
If it comes from the control panel, it may be a transformer for the control electronics or a relay coil. Sometimes a relay or transformer mounted on sheet steel will vibrate if a mounting screw works loose. That's easy to fix. Occasionally a coil inside the relay or transformer will develop a loose winding - the best repair for that is get a new one.
If the buzzing is specific to one (electric) burner, it could be arcing at a bad connection.
Oct 27, 2010 | Viking Kitchen Ranges
Pink and green lines are starting to appear that are moving up the screen TV is buzzing after being on for awhile. TV is not even a year old.
Try unplugging everything other than the TV and the cable (or whatever service you have) and while your tv is on, plug everything back in separately. I did this and found that while my ps3 was plugged in, I caught interference on my cable TV. Also, make sure that any cords behind the TV aren't all jumbled. Sometimes having a bunch of twisted up wires can cause interference.
Jan 25, 2010 | Westinghouse 26" LCD Flat-Panel HDTV
My crosley gas dryer is 10 yrs old. It tries to start, I can hear the buzz. Sometimes it takes hours of tries to get it to ''catch'' and turn on. I recently changed the belt and the (?)blower wheel. Any...
when it starts does it work
if once you get it started it seems to work fine
well then you have astart winding on the motor goin bad. or done.....
try this... empty the machine
tape the door switch closed
push start and try to spin the tumbler
if it starts right up you have confirmed it
your motor is done
Oct 08, 2009 | Crosley CDG6000 Gas Dryer
Problem in 1st gear with manual transmission
Ignition timing may be too advanced or ******
Check ignition timing first.
Check for rated idle speed
Check engine compression pressure
Oct 28, 2008 | 1996 Toyota Corolla
After tv is on for awhile it starts buzzing
I have a polaroid FLM-323B flat panel Tv. After it is on for awhile the TV starts buzzing and the picture starts to blink in and out. Can you help me with this?
Aug 19, 2008 | Polaroid FLM-323B Television
Frigidaire Freezer Buzzing
thats not a valid model number open the fridge door and look up at the top by the light bulb on a white sticker and ill try to help ok
Apr 02, 2008 | Refrigerators
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Aug 08, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Philips Magnavox 20MS3442 20" TV Logo
131 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
