Question about KitchenAid KEYS750LQ Electric Dryer
Heating Element no longer working
I have a KitchenAid Electric Dryer KEYS650LQ which I bought brand new approximately a year & a half ago.
The lint collector has always been an issue as it seems the lint never goes up that way. I could do several loads of laundry without the filter becoming full. Come to find out, it was because it was all getting caught in the tube the runs inside the house.
About a month ago, it began to lose heat until finally there was no heat coming from it at all.
I moved the dryer out, disconnected it and removed a ton of lint. Now the heating element won't come back on.
Is this a part that I can buy and Install myself or will I need to have a technician look at it.
If it IS a part that I can buy, about how much do they run and what is the difficulty level on installing it?
Thank you so much for your help
Paige Gray.
  • 20 Answers
Hi Paige
Expect to pay $30 for the kit. it's a 279816 and will take some level of mechanical and technical ability to locate it and affect the repair. This kit addresses 2 issues and should be installed by a certified technician. Your owners manual has a big WARNING!!! block saying what not to do, like Don't use plastic or foil venting. But nobody reads manuals anyway. Most likely you have an aluminum foil colored accordian style vent pipe. That's what caused your thermostats to burn out. Get your drier checked out by a certified tech for safety. Afterwards, keep that vent, clean clean clean and install a sure vent from Whirlpool 4396028. 16,000 homes each year have fires from improperly vented driers according to the U.S. Dept of Consumer Safety.
Posted on Dec 10, 2008
Clothes dryer shorts every time I turn it on
I assume this is electric dryer vs gas. You most likely have a electric heating element that has broken, and the wire is shorted to cabinet. If you can see inside element, you can often spot the broken wire. Don't try to fix element, you can't splice heating wire, it wont work. Buy a new element.
Jan 08, 2015 | Dryers
Electric dryer runs shuts off then starts again on its own
This could be a bunch of different things. #1 detach dryer vent and clean out. Try running dryer with vent not attached for 10 seconds. (Warning, lint and sand will likely come blasting out the back. Reattach and try. #2 Likely is that you have lint buildup inside. Unplug dryer. Remove back cover. Clean air path from exhaust through lint trap. Look inside or remove heater as well. You are likely overheating the dryer and the sensor is shutting it down. #3. Unplug the heating element and then run dryer. Does it shut off still? No Then the sensor on the heating element is bad. Yes then the timer is bad.
Jan 13, 2014 | KitchenAid KEYS750LQ Electric Dryer
Dryer heats up, but does not dry clothes. Vent is clean
As you can see, your heating element has 5 heating coils. If one or more of these coils have opened you dryer will still work and heat but not at well as it would if all coils worked together. You can check each coil with an ohm meter to verify if one or more is open.
Jan 01, 2012 | Kenmore 64742 Electric Dryer
Turns on but wont get hot
The first thing to check is the fuses or breakers in your homes fuse box. If this fuse is blown, it is possible for your dryer to spin but not produce heat. If you've checked the fuses and they are not blown, the next possible cause is the heating element.
To check the heating element, move the back panel of the dryer. You'll need a volt/ohmmeter to check the element terminal. Locate the element and set the volt/ohmmeter on the RX-1 scale. Remove one lead from the element and then place one probe of the volt/ohmmeter on the terminal of the element. Place the other probe of the volt/ohmmeter on the remaining terminal of the element. Look for a continuity reading of the volt/ohmmeter of approximately 2-5 ohms. If there is no continuity reading, the heating element is defective and should be replaced.
Also clean the lint filter every time you use the dryer. Even if the lint filter is cleaned after every load, lint will still accumulate around the dryer's moving parts, the exhaust duct and vent. Each year inspect the vent pipe and vent cover operation. Disconnect the exhaust duct and remove lint from the internal exhaust pipe, the duct and the vent. Make sure the duct has no kinks, where lint and moisture can build-up.
Turn off the power; remove the front and rear panels and vacuum out the lint from around the motor and idler. Poor air flow uses more energy and can cause lint build-up in the internal ducting, leading to a fire hazard.
Please check the bellow links to get a detailed idea as to why a dryer is not heating up, you can trouble shoot your problem after going through the article therein:-
Please get back to us if you have further query else please accept the suggestion.
Feb 02, 2011 | Roper REX4634KQ Electric Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly.
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
I have an similar problem with my Amana Dryer LEA30AW.
First Clean out your filter, Assuming the element is okay and cut-out are fine it should run okay, you could also try running it on low heat will take a bit longer but hey if it works great..Good luck
Oct 01, 2009 | Dryers
LG DLE2512W Will not heat even after replacing Heating element.
there are a couple of thermal fuses also that could be blown inside the back check these also
Aug 25, 2009 | LG DLE2512W Electric Dryer
Brand new dryer heating element burned out.
If air flow is restricted this can cause it. Or if your voltage is high or if you have received an element that has been stretched and is loose this could cause it. You say immediate and how long in loads or time is this? Are you sure the element still has full voltage (220V aprox) to the element?
Mar 16, 2009 | Hotpoint NVL333EY Electric Dryer
Dryer wont heat up!!
where are fuses on kenmore dryer
Oct 25, 2007 | Kenmore 62872 Electric Dryer
KitchenAid KEYS750LQ Electric Dryer Logo
125 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Oloyede Monsuru
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
