Question about Mitsubishi WD-52725 52". Rear Projection HDTV
TV remote will not work properly
My TV remote will turn the TV on and off but it will not perform any other funcions. I can not get to the device menu to connect to the DVD player. I have checked the DVD player and it works properly in other TV in the house and i have PIPed devices and it showes the picture for the DVD player but only on half of the screen. After several tries of the remote not responding, the TV will just turn off by itself. Please Help.
I have a Mitsubishi WD-52725 TV, too, and have experienced the same problems with it. My solution to the remote not responding is to push the reset button on the front of the TV (to the left of the Power button) with a paper clip and wait for the green light to stop blinking (about 1 minute). Then, turn it back on and try the remote again. Recently, my remote stopped responding when pushing certain buttons on it. I removed the batteries, and all of the little screws including the one inside the battery compartment and gently cleaned the contacts inside the remote and the circuit board with a cotton swab dipped in alcohol. After putting it back together, it works fine now.
Posted on May 29, 2007
My samsung tv does not power on ln32b360c5dxza
To troubleshoot a Samsung television that cannot connect to a network or particular apps, check to make sure there is a network connection. Use the remote control or buttons on the television to navigate to Menu, Network and then Network Status. If there is no connection, ensure the Internet router is properly connected to the television. If there is a connection and the problem persists, contact your Internet service provider.
If a Samsung television is experiencing distorted picture or sound with an external device, make sure the device is connected to the television correctly. If the connection is fine, perform a TV Self Diagnosis test by navigating to the menu, selecting Support, Self Diagnosis and Sound or Picture Test. It is also worth trying to change the picture size using the P. Size button on the remote.
To troubleshoot problems with lost settings, change the television to Home Mode by selecting Tools on the remote and changing Store Demo to the Off setting. Issues with the signal can be solved by selecting Source on the remote and running the Auto Program function to search for channels.
To access the on-screen manual for a Samsung television, press the Menu/123 key on the remote, and select Support from the menu. From the Support menu, select E-Manual. This opens the user guide on the television screen. From the screen, select the issue that the television is having.
Sometimes, the television simply needs a reset. To allow the TV to rest, turn it off, unplug it for 10 minutes, and then plug it back in, and turn it back on.
Apr 30, 2018 | Samsung Televison & Video
How do I get the remote codes to make dish tv remote working?
Method 2 of 3: Scan for Code
  1. Use the remote to scan your device for the proper code. If the direct-entry method does not work, or your device is not listed in the back of the manual or online, you can try this procedure to find your device's code.
  2. Turn on your remote device. Use either the device's power-on button, or use its remote control to turn it on.
  3. Press and hold the mode button for the target device. Hold the button down for about 3 seconds, then release it. It should now be flashing.
  4. Press the remote's power button. Note: use the generic power button, not the TV power button.
  5. Press the Up or Down arrow button until the device turns off. You will have to do this repeatedly to scan through all codes.
    • Do not press the arrow buttons too quickly, or you might skip over the correct code.
    • The mode button for the device will flash rapidly 8 times when you have scanned all the codes for that device.
  6. Lock in the code. When your device successfully powers off, press the Pound sign (#) to store that code in the remote.
  7. Test the connection. Turn on the device with the power button, then test the other buttons such as Play, Fast Forward, etc. If those work too, you're set. If not, repeat the process again until you find a code that does.
Method 3 of 3: By Menu
  1. Turn on your TV. Make sure it's connected to your Dish Network, then press the MENU button.
    • The menu screen should show on your television screen:
    • Select Settings. Locate and select the Remote Control button.
      • The Remote Manager screen should display on your screen:
      • Select the device you want to learn. From the buttons on the right, select TV, DVD, or AUX.
      • Select the Lookup Code button:
      • Select the sort criteria and device brand. Then click the Next button:
        • Test the device at this point. If the remote works as expected, select the "Yes" button; otherwise, select "No" to try the next code in the list.
        • Repeat this process until a working code is found, or continue by selecting "Enter Model" to find the device code.
      • Enter your model number in the search field. You can enter all, or part of the number.
        • Select the device model number from the list, then select Next. Test the device. If it works, you're good to go! If not, and you've tried all the other methods, your device is not supported with the Dish Network remote.
Sep 09, 2014 | Televison & Video
Everytime ichange the channel ; a big black box pops onthe screen and the only way it can be removed is by clicking a volume button ; what can i do?
Tv still have it Closed Caption functions is on.U have the tv original remote wright?Yes.Look at ur tv remote control look for a button that said CC,push that button a couple times make sure like all CC1,2,3.. all to off.Closed Caption functions will turn off should have no more black boxes pops up onto the tv screen.Also used the tv remote control go into the tv menu go into Closed Caption funcions look for functions like Text 1,2,3... turn it all to off too.Should stop it for good,if Text also on too.If u don't have the tv original remote.Try website like Remotes.com to buy the tv original remote.
Jul 09, 2011 | TruTech T2000D TV
NEED TO PROGRAM MY RCA TV WITH A HUGHES HRMC-13 REMOTE
Hello
Codes for RCA tv with Hughes remote are:
160 161 156 165 065 070 004 023 024
056 074 081 152 167 145
Code Entry
Use the REMOTE pane under the System Setup menu tab to program your
HRMC-11, HRMC-12, or HRMC-13 remote control to operate your TV, VCR,
SAT, AUX device, or DVD (HRMC-11 and HRMC-12 only). The AUX menu
button can be used to control a CATV box or other type of device. Use the menu
buttons to choose the desired type of device and display a brand name menu list
from which you can select the manufacturer of your device.
Code scanning
To use the Code Scanning method:
1. Repeatedly tap the top part of the CHANNEL (CH) button.
2. Continue to step through the codes until the component turns off, indicating
you have found the correct component code. If you accidentally pass a code
that responds or realize you may not have been aiming the remote control at
the component, tap the lower part of the CHANNEL (CH) button to step
backward through the codes.
3. Press the remote control POWER button to verify the proper code by
turning the device on and off.
4. Press the device button (in this example, TV) again to lock in the code.
OK
Feb 20, 2011 | Televison & Video
Black rectangle at lower center of screen that blocks most of the tv. adjusting volume takes it away temporarily and then it reappears. don't know if we inadvertently turned on a funcion from the remote.
Take your remote, go into menu, scroll down to captions, right arrow to 1,2,3,off, when cursor is over off press enter on the remote, that should clear the black box and give normal tv viewing.
Feb 02, 2011 | JVC AV-27D302 27" TV
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
Other room remote changes channels on BOTH TVs
turn off the uhf from you reciver in main menu set up funcion remoto control
Apr 07, 2010 | Toys
W2606c lcd tv
Nothing appears on my LCD TV display
1 Ensure the LCD TV display is turned on.
2 Verify that all the cables are properly connected to the LCD TV
display, including the power cable.
3 Check to see if there is a blue or amber light on the lower,
right-hand corner of the LCD TV display. A blue light indicates
the LCD TV display is on. An amber light means the LCD TV
display is in power save mode.
4 Ensure the proper source is selected in the Input Select menu.
See "Input Select Menu" on page 24 for more information.
5 Reconnect any devices that are currently connected to the LCD
TV display. If you are using multiple devices, connect and test
one device at a time.
6 Connect another device that you know is working properly.
7 Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset.
Problem Possible Solution No sound
1 Ensure mute is not turned on. Pressing the Mute button on
the remote control turns the mute function on and off.
2 If only certain LCD TV channels do not have sound, then you
need to correct the Input Select menu in the TV Menu (see
"Input Select Menu" on page 24).
3 Verify that the audio cables are firmly connected to both the
audio input connectors on your LCD TV display and audio
output connectors on your devices. Ensure that the cable colors
match the connectors colors.
4 Also, ensure that the audio cables are connected to the same
row as the video cables. See "About Your LCD TV Display" on
page 5 for the location of the connectors.
5 Reconnect the device using the same type of connector. For
example, if you are using the composite connector on the
bottom, try connecting the device to the composite connector
on the side of the LCD TV display. See "About Your LCD TV
Display" on page 5 for the location of the connectors.
After you connect the device, change the input source in the TV
Menu. See "Input Select Menu" on page 24 for more
information.
6 Connect the device using a different connector. For example,
if you are experiencing the problem using a composite
connector, try using the component connector.
NOTE: To connect to a different connector, you need the
appropriate cables for that connector. See your device
documentation for a list of supported connections.
information.
7 Test the device on a different TV.
Jan 05, 2009 | Dell Televison & Video
TV Remote will not work
I was told that there is a short in the power supply, which needs to be built back up. The estimate for repair is $450. Is this reasonable? Thanks.
Hank
Feb 28, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Universal remote
the universal remotes work fine in any tv, but limited to basic funcion, if you whant full funcion one, go to, www.remotes.com or call 1-800-remotes..good luck
Aug 10, 2006 | Jensen TS2050J 20" TV
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
182 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
