Heating & Cooling Logo
Posted on Dec 10, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to locate the wiring schematic for an Intertherm electric furnace, Can you tell me where i can get it
Anonymous
Level 2:
  • Expert 96 Answers
  • Posted on Dec 10, 2008
Anonymous
Expert
Level 2:
Answers
96
Questions
Helped
68213
Points
181
Take the bottom silver cover off on bottom left side in unit it covers electical and on back side of cover turn breakers off
I need a wiring schematic for a intertherm 15kw electric furnace.To show where each individual wire goes.
Are you sure the limit and sequencer were the problem in the first place? Why replace both? First need to verify you have low voltage getting to the sequencer.
How to remove Heat strips from intertherm furnace to make an air handler? Wiring schematics
WHAT??? Removing heat strips does not make an air handler. Air handlers have heat strips, please explain
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
2answers
I have an old Intertherm gas-fired furnace, Model MGH-055AB which ceased operating last night. It was quite warm when I arrived home, and when I set the heat up a little, began to hum, but the fan would...
Tom P's answer is generally correct: The motor start capacitor is usually not the problem. However, in some cases, particularly on older furnaces, where there were capacitors of certain make and production run will prematurely fail. This happened in March on a mobile home HVAC unit where both the blower fan and condenser fan motor capacitors failed open circuit. Both caps were of the same Mfg, and production lot.
Here is a suggestion (for you or an electrically inclined friend): Locate a substitute motor capacitor having similar Mfd (or MF) and Voltage ratings. Remove power from the unit. Reach into the blower squirrel cage and spin it to verify that the shaft is not frozen. Pull the wires from the existing capacitor noting color and location. Connect the wires to the substitute capacitor and secure it place. Apply power and turn on the blower. A no start? Motor replacement time.
Wiring heat only thermostat to inter therm central electric furnace had to replace fuze block, limiter, and sequencer thermostat only has one red wire and one white wire
I am trying to install a Honeywell VisionPro 8000 thermostat for my Intertherm Central Electric Furnace but I am having trouble getting to work any suggestions?
1helpful
Intertherm Heat Pump
Some of the old heat pumps made the reversing valve in the heating mode. On your new thermostat the orange wire will need to be on the B terminal. If it was color coded? I hope you made notes of how it was.
Weed eater pulled out red & white wires from thermostat at a/c unit. Red went to yellow and white to ?. Unit is an intertherm unit, model unknown but schematic #703909b
White will usually go to white or blue, you can go to your furnace to verify which wire is connect to the common terminal (c)
Adding a Condensing unit to an Intertherm electric furnace
you have the motor connected on more than one speed in heat mode. make sure inly one mode is connected
Elec. intertherm FURNACE
It would help if I knew what type of system you have, lets start with the thermostat. If you disconnect the wires to it, does the heat turn off? I have seen thermostat wires pinched inside the wall, thus bypassing the thermostat controls altogether and it would run constantly. If you send a reply, tell the type. Wall furnace, central unit, heat & cool, gas, electric or heat pump. If you dont know tell me how many wires you have at the thermostat and the colors. You should know this, as you have changed it.
Top Heating & Cooling Experts
Paul Carew
john h
