Question about Maytag Atlantis MDE7400AY Electric Dryer
Which wa does the belt on a Maytag Atlantis dryer run around the motor and idler pulley. I have the belt groove side down, which is the way it goes in the Atlantis, but I couldn't find a schematic for the belt route on this model and each way I've tried the belt is too loose.
  • 20 Answers
Hi you're correct in putting it groove side down. Now make a loop, like when you first started tying your shoes with the slack around the drum. Push the entire loop just beneath the idler pulley through the metal channel and apply pressure to the idler pulley assembly. pushing it towards the motor pulley until you can get the loop you are holding over the motor pulley and Waa Laa you've installed your new belt. Good Luck!
Posted on Dec 10, 2008
I have a Maytag SE-1000 stacking washer dryer setup. I am trying to replace a broken dryer belt, and have the disassembly done, and the replacement belt in place. My problem is trying to understand how the...
Most dryers are tension idler pulley directed but must first go around the grooved pulley on the motor shaft. make sure the idler goes on the smooth side of the belt and the grooved side of the belt is in the grooves on the motor shaft.
Oct 13, 2013 | Maytag Dryers
Loud sqeeling noises when running. Sounded like a belt slipping. Dryer died all together and smells of burning rubber. Suspect a loose or broken belt. How do I change it?? --Dave
Check and see if the belt slipped off the motor pulley broke or wrapped around motor pulley. Check the idler pulley (large white wheel end of motor) Loose?
Oct 16, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
What is the correct belt routing for a maytag MDE6000AYW dryer and should the groove side or smooth side be on the drum? Thanks. dave
groove down. around the drum. near the motor you will find a tensioner. Through the tensioner then around the pulley on the motor. Have your assistnnt hold the drum up while you get up and prepare to put the front back on. You know the rest.
They call it a tensioner for good reason ... you may want to lift it using the length of a screw driver against the floor of the machine.
Watch your fingers.
If you are happy with this answer, please leave positive comments
thanks
a
Oct 14, 2009 | Maytag MDE6000 Dryer
How to install belt on Maytag dryer
The motor pulley usually has grooves and the gooves must match on that pulley. The belt goes around the drum gooves down thur the tensioner and on the motor pulley.
Sep 20, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
The belt fell off of the drum, i have the front off but i dont know where the disconnected pulley goes.
Unplug dryer or disconnect power.
Locate mounting slots in front of motor. (In some cabinets, there are two sets of slots for mounting the idler assembly. In this case, mount the idler assembly in the slots that line up under the grooves in the motor pulley.)
Install idler assembly into cabinet base by hooking mounting tab (A) into 1⁄4" wide mounting slots and setting mounting tabs (B) into the 3⁄16" wide mounting slot.
Make sure belt is around drum, with grooves down.
Route belt through the idler and around the motor pulley.
Sep 12, 2009 | Whirlpool Dryers
I replaced the idler pulley and pulley arm on my Maytag Dryer model#SDG2606AWW, and now I don't have enough tension for the drum to turn.
http://www.pcappliancerepair.com/model-display.php This site shows your belt going around the motor a half turn, grooves to the pulley. Then you have to wind up the spring-pulley and put the belt over the roller a half turn. That should take up the slack. The packaging of a new belt should show how it goes.
May 12, 2009 | Maytag Dryers
Belt too big?
Sometimes instructions are on the new belt package. You can google your unit for support. Check Repairclinic.com. Keep in mind the belt must go at least a half turn around the motor pulley( grooves down on the pulley), then the tensioner is pulled toward the motor and the belt goes a half turn around that pulley, with the grooves up. That should take up all the slack.
Apr 19, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Replace dryer belt
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
Apr 07, 2009 | Maytag PYE2300AY Electric Dryer
Samsung dv4006 dryer belt
Possible replacement belt quality problem for the Samsung DV4006 / DV4006J / DV4015J / DV665JW and the Maytag MDE2400AZW dryers:
The original belt for the Samsung DV4006 / DV4006J / DV4015J / DV665JW dryers is a Megadyne 1975 H7. The part number is DC66-00121A, but when ordered, a Dongil 7PH1975 belt may be shipped instead of the original Megadyne. The Maytag MDE2400AZW dryer uses the same belt. The part number is 35001010, but when ordered, a Dongil 7PH1975 belt may be shipped. It seems that the Dongil belts are inadequate for these dryers. They delaminate and may fail prematurely. Even new, they cause a thumping sound each time the seam goes over the motor pulley. Other than Megadyne, another good belt is the Hutchinson 1975H7. The appliance part number is 1258288107.
Where to get an original Megadyne 1975 H7 belt:
eBay member 'appliance-parts' in Colorado, USA has emailed me that their Samsung DC66-00121A belts are Megadyne. Website: http://appliancefactory.com Email address: partsonline@appliancefactory.com
eBay member 'ladydi1975' in Ohio, USA has emailed me that their Maytag 35001010 belts are Megadyne. eBay store: Discount Appliance Parts.
Where to get a Hutchinson 1975H7 belt:
eBay member: 'zodiac300_0' in Brighton, United Kingdom. I have ordered a 1975H7 belt from them and received a Hutchinson.
Other possible causes for belt failure:
--Motor pulley designed too small. The belt may be flexed beyond it's minimum rated radius.
--Excessive heat in the dryer due to lint in the vent line or vent line too long. The Dongil belt may be less heat resistant than the Megadyne.
--Worn drum bushing DC66-00062A.
--Metal burrs on the steel motor pulley. Deburr by inserting a small screwdriver in each groove while the motor is turning without the belt.
--Belt on the wrong track. The motor pulley has nine grooves and the belt has seven ribs. The belt must be in the middle. It's easy to place it one groove forward or backward by error.
--Small scratches on the drum where the belt contacts it. The scratches may be like small knives and damage the belt. Sand with a fine sandpaper.
--Idler pulley damaged or bearing worn.
How to replace the belt:
--Remove top cover.
--Remove vent panel (in back).
--Unclip door switch from front panel.
--Disconnect wire harness from door switch.
--Unscrew panel left of control console (from behind the panel).
--Unclip panel left of control console (from behind the panel).
--Unscrew control console.
--Unclip plastic panel on bottom, front
--Remove screws behind door. Remove door.
--Unscrew large front panel, remove.
--Inspect vent line for lint buildup, drum bushing (back of dryer) for wear, motor pulley for burrs and debris, drum for scratches, and idler pulley/bearing for damage.
--Vacuum all lint.
--Install belt around drum, idler pulley, and motor pulley. The ribbed side of the belt contacts the drum. The flat side of the belt contacts the idler pulley. Press on idler pulley to stretch the spring, and line up the seven belt ribs in the center of the nine motor pulley grooves.
--Reassemble.
Nov 06, 2008 | Samsung 7.3 Cu. Ft. Electric Dryer
Dryer belt snapped bought new one and will not reach the pulley by a 1/2 inch this is a maytag dryer thought these belts were all the same length are they not ....
make sure the belt is in the groove on back of drum for belt then run belt from left side of drum over and around pulley on motor shaft going clockwise then continue around pulley and run belt toward belt tension pulley the one with the spring on it go counterclockwise around it at this point you will have to pull up on tension pulley to get belt on then realease that should take care of it ed
Nov 01, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
174 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
