Question about Cell Phones
My cell phone doesn't turn on. it's fully charged and everything is intact, but it won't turn on
    Problem Solver:
  • 11 Answers
Have you tried removing the battery from the phone and leaving it out for a little bit??
Posted on Dec 10, 2008
Phone won't come on
my name is Larry and i have the exact same phone. If ur lg isnt turning on and wont charge it could be couple things . either the charging port on ur phone needs replaced and or ur charger has gone bad i would take it to a cell phone repair shop close to you.
Mar 25, 2013 | Net10 LG Optimus Logic Cell Phone
Phone is charged and won't turn on, also reset doesn't work
your battery is probably broken, try replacing it (ifixit.com), or let someone else fix it for you.
Dec 02, 2012 | Apple iPhone 4S
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
My 8520 turns on but won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jul 30, 2012 | RIM BlackBerry Curve 8520 Smartphone
My battery indicator won't turn green when it is fully charged.what is this issue?
It is possible one of the battery cells has degraded enough the battery is not showing a full charge, or there is an issue with the green light, but this is minor provided everything is working.
Mar 07, 2012 | Acer Aspire One D250 16GHz Intel Atom...
Motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
May 13, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
62 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
