Question about Toshiba Satellite P35-S611 Notebook
Probem booting P35-S611
P35-S611
Error on screen; For Realtek RTL 8139(x)18138/810x PCI PXE-E61: Media Test Failure Check Cable PXE-MOF: Exiting PXE ROM Invalid partition table. Then trying to boot in bios the computer screen says loading windows 95 and warns to back up data because all files will be erased...press F1 to continue press F2 to abort.....I press F1...a large alert comes on screen that looks hacked in WRONG MACHINE! I should mention that I purchased this computer from the US government with the hard drive erased....should I start with a new hard drive? Or should I look for a bad cable to cd rom? ....Can anyone point me in the right direction?. Thanks alot. marteanee
  • Toshiba Master
  • 6,487 Answers
It will be better if you use a new hard drive since this problem is related to a bad hard drive and install a new operating system and that will make the computer work fine....
Posted on Dec 10, 2008
  • Toshiba Master
  • 13,433 Answers
Go into bios / setup it says on the bottom or top of the screen what button to press, make sure hard drive or HDD is set to boot first or after CD. the hdd might not be detected and so its trying to startup from the lan adapter.
You may have a faulty hard drive yes.
    Genius:
  • 1,269 Answers
Use a new Hard Drive that's the most easiest way and will save your time.
PXE-E61 Media test fail, PXE-MOF Exiting Broadcom PXE ROM
Disable PXE in the Boot Sequence in the BIOS setup [F2]
Aug 10, 2012 | Dell Computers & Internet
PXE-E61 : media test failure, check For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.06 (080222) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE ROM.
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
Jun 17, 2011 | Computers & Internet
Booting problem, screen message: Intel (R) Boot Agent FE v4.1.18 Copyright (C) 1997-2005, Intel Corporation PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating...
HI there,
The "Error" texts saying:
Are completely normal. This simply states that there is no external cables plugged into the specialty inputs on your toshiba laptop.
The "operating system not found" is stating that your existing hard drive is either A) dead or B) been erased.
Try to re-install your operating system, if it finds no hard drive, you'll need a new one!
May 04, 2011 | Toshiba Satellite M105-S3041Notebook
Pxe e61 check cable message
"Intel UNDI, PXE-2.1 (build 082)
Copyright (C) 1997-2000 Intel Corporation
For Realtek RTL8101E/8102E PCI-E Ethernet Controller v.105 (071227)
No bootable device -- insert boot disk and press any key"
sounds like a driver issue try to go to toshiba's website and download the latest drivers for the NIC card.
Nov 02, 2010 | Toshiba Qosmio G15 Notebook
When trying to reboot I'm getting this pxe-e61: media failure
install new NIC drivers from your laptop manufacture's site.
Nov 02, 2010 | Computers & Internet
Wile I am trying to boot it up it goes in to a loop
Hello.
That error message usually refers to a hard disk failure. Your hard disk cable could be loose or faulty. Or, your hard drive would need to be replaced.
I'd suggest to check the cable and run your system's hardware diagnostics (often F2 or F12) when your system boots.
Hope this helps.
Nov 26, 2009 | Compaq Presario M2000 Notebook
Sony vaio pcg-fxa36 will not boot get error realtek RTL8139(A/B/C
ok, what is happening is the laptop is trying to boot from the ethernet port, what you have to do is go into the bios (this is usually F2 on boot) and change the boot order to hard drive, save settings and exit the bois screen, the pc should now boot to windows
kind regards and please don't forget to rate us
Dec 03, 2008 | Sony VAIO FXA36 Notebook
P35-S611
When you get this error, it is because the notebook is trying to boot from a server or from a network, which unfortunately means that your hd took a bath. When you start up your notebook, do you hear the hd spinning up? Do you see the icon on the front of the notebook for the hd light up? If you answer no to both of those questions, you will need a new hard drive.
Aug 31, 2008 | Toshiba Satellite P35-S611 Notebook
Toshiba satellite p20, pxe-e61, pxe-mof
cable plug possible defective, if possible plug into another computer and see if error occurs. since you did not state OS go into the Device Manager and insure 'network adapter' has driver installed and working. Is there an external media hooked up?
Jun 16, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
Toshiba Satellite P35-S611 Notebook Logo
26 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
