Question about NEC MultiSync VT45 Multimedia Projector
NEC VT45: Blue pixels onscreen
Hi, This projector get regular use, 2-3 times weekly and recently started to exhibit a blue haze throughout the screen which eventually developed into seemingly random blue pixels. The blue pixels do not display on the screen when there is no input (the VGA input is all that is used) and the white NEC logo is onscreen. There is also a large area in the lower middle of the screen which when the unit is running without any input displays as a large yellow blotch. This blotch is also visible when there is video signal, and the blotch moves when the screen orientation is changed. I will be testing the svideo on the unit later today to see if the issue is related purely to the VGA. If anyone else has experienced these issues some suggestion to fix or what to repair would be greatly appreciated. Thanks
SOURCE: VT45 Projector: Blue pixels throughout screen
If the problem is what I describe as a blue haze over the entire image projected, I was told this is a defect in the cable - we have a Dell Video Projector 2300 - and it takes only a dell VGA cable.
So, the problem is in the cable - solution is replace cable.
Posted on Oct 10, 2007
SOURCE: Flashing red status light on NEC VT45 projector
Press and hold down the help button on the remote pointing it towards the projector for at least 10 secs.
Posted on Mar 03, 2008
SOURCE: random dots and no picture
Okay, I had the same problem exactly.
You can't fix it yourself. I took it to the NEC lab and they changed a card. luckily it was covered by the warranty.
danielmarks@walla.com
Posted on Apr 30, 2008
SOURCE: I am using a NEC
its a common problem of the video hardware in the laptop - it hasnt the ability to split the video "overlay" (often its decoded by something in the video chip, or at least a seperate bit of software and output seperate from the usual, slower windows & images data stream) off to the second screen & you just see the frame of the player.
if you set the external output to be the main/primary, or sometimes only active screen, it should work. you might also have a chance if you make it an extended desktop rather than a cloned one, then moving the player window entirely onto the projector's "screen"
Posted on Jul 02, 2008
projdoc
  • 2237 Answers
SOURCE: blue haze in top right of screen from NEC mt1075 projector
the light filter on the blue lcd panel is fried due to excessive dust and heat. clean out the projector with canned air. unfortunately, you cannot buy individual parts of the optical engine- you'll have to replace the whole thing. or live with it.
Posted on Nov 17, 2009
How can I stop the colorful spotting in the display of my NEC NP410 Projector?
Its the dlp/dmd chip going and soon will look like the star screen saver on windows 98. it will need replacing. they start with one or two dead pixels then it spreads. ref only->https://www.replaceyourlamp.co.uk/projector-lamps/nec/np-u250x/dmd-chip-1076-6439b/dlp-dmd-chip-1024x768-pixels-model-b.html
Mar 02, 2018 | NEC NP410 3LCD Projector
Blue haze/fog all over screen
As it appears from the images that the images are fine. The sanyo PLV-Z2 is a LCD projector. So basically it projects 3 R G and B lights to make the screen. Yes it is definately not a LAMP issue. Either dust could have accumulated on the R and G panels thus leading to these prominent BLUE patches or if the LCD panels are damaged, u have to get the G or R replaced.. try running a application like Displaymate from "http://www.majorgeeks.com/DisplayMate_d4189.html" and see which of the panels is exactly responsible for the problem. I think this should sort it out.
Dec 26, 2007 | Sanyo PLV-Z2 Multimedia Projector
How do you reset the lamp on a NEC VT45 projector.
holding down the "OFF" key on the remote control for 30 seconds
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jan 21, 2014 | NEC VT45LPK Projector Lamp for VT45
How you can fix blue light problem on NEC projector? Shahid
what does the blue light problem look like on the screen. is it all over the screen, or small dots, or a dim haze etc?
Apr 19, 2011 | NEC MT1075 Multimedia Projector
I have red and blue color tones to one side of my screen. And a slight blue haze at the top of the screen.
You have delamination/polarizar burn requiring factory authorized service.
Good Luck
Aug 11, 2010 | NEC MT1075 Multimedia Projector
Steady red status light on NEC VT45 projector. Would not POWER ON. LAMP was replaced with a new one
the power supply on that model seem to go bad after a while. the caps aren't properly reted it's power needs. they dry up. if you are good at soldering, replace c1 on the board (big cap) with a cap that has a slightly higher voltage rating. or replace the whole power supply. you might not be able to get one from nec, but you can try www.projectordoctor.com
Dec 16, 2009 | NEC MultiSync VT45 Multimedia Projector
Blue haze in top right of screen from NEC mt1075 projector
Nov 17, 2009 | NEC MT1075 Multimedia Projector
Blue strip (Haze) started showing up in middle of screen.
you need to chang screen or buy new tv ,cause that is not fixable its killed pixels.please leave comment,vote,note.thankyou
Sep 13, 2009 | Hitachi 50V720 Television
Feb 28, 2007 | NEC VT45LPK Projector Lamp for VT45
make sure the doors are shut all the way! there is a little button there.
Feb 13, 2007 | NEC MultiSync VT45 Multimedia Projector
NEC MultiSync VT45 Multimedia Projector Logo
51 people viewed this question
Top NEC Office Equipment & Supplies Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
