Question about RCA P46924 46" Rear Projection Television
High pitch noise..from TV
Hello I had an issue a while back with the picture bowing at top and bottom well I fixed that problem. Now everytime I turn on the TV there is an annoying high pitch sound coming from it. Sometimes it will always be there and other times it will fade in and out.....here is what is on the back of tv. service no. = P46924YX5 MODEL = P46924 SERIAL NO = 051441559 CHASSIS NO = PTK195M2A I hope this will help ...what is causing this and how can I fix it.....If info is needed that I didnt provide just let me know I will get it for you..... thanks so much in advance..... erbossman81
    Novelist:
  • 192 Answers
The high pitch squeal you hear is usually caused by a coil vibrating, normally in the horizontal circuit. I've also seen the ferrite bead on the horizontal output transistor do this, but, it is rare. I normally will repair this by finding the coil and "tightening" it. To tighten a coil, technicians use different chemicals, such as, a hot glue gun, rubber silicone or even finger nail polish. I will find the coil that screams by starting with the usual suspects and using a wooden dowel, barely touch the coil and if the pitch of the noise changes, then, thats the coil that needs repaired. If you do not know your way around the inside of a television, I never recommend you do so, since, this procedure must be done with the set turned on and you poke your hands around the inside of the set by the high voltage circuit. Hope this helps your decision.
Posted on Mar 04, 2007
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
High pitch noise
Sorry to hear about your issue, let me see if I can help.
What type of tv is this? tube or flat panel? If tube, have you recently moved it and shook it up a little?
If panel, are you using an hdmi hookup or just regular cable from a cable box?
Be sure that your hookups are on tightly and that your cables are not tangled as well especially hdmi cable. Let me know if any of this is helpful in solving your issue or if I can be of more assistance. Once you respond I can help more, just need more information..
Thanks,
d
Feb 26, 2008 | Sanyo DS31520 31" TV
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
TV picture compressed top and bottom, then turned itself off
hi i think you have trouble on the power supply section.
Aug 24, 2009 | Televison & Video
High pitched noise from inside the TV when picture comes on
Hello randapaint,
This might be from the IHVT (Integrated High Voltage Transformer), or more specifically a short in the IHVT causing it to arc, producing the high pitched whine, you are hearing. Take the back off of the TV and try to detect where the sound is coming from, more then likely you will notice it coming from the section that contains a large component with a large red cable coming from it, to the top of the CRT (picture tube). Replace the IHVT (with the exact same model) if it is bad.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 07, 2009 | Televison & Video
High pitched noise
I am about to post a in depth guide about how to fix this problem. It's because a capacitor inside the TV has blown which causes the buzzing high pitched noise. It's really easy to fix however and only costs about £1 / $2 to sort out.
You can read a similar guide here http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen but I will shortly be uploading a guide on the buzzing problem!
Dec 22, 2008 | Polaroid FLM-3732 Television
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
High pitch sound and fuzzy
The high pitched sound, probably not, unless you open this TV set and find out what is making the noise and replace the part. Most likely a coil or transformer is vibrating so fast that the frequency is very high. On the focus, possibly can be adjusted. Now when you take off the back of this TV set, i must warn you, follow my instructions to the letter as there is enough High Voltage in this set to make a grown man cry! After you take out all of the screws off the rear cover,carefully lift up the cover straight up. Oh by the way the TV should be face down. Opps! Not stand back up the TV set and there will be a Grey or black block like looking thing with a large red wire going to the top of the picture tube. on this block you will find two controls, one will say screen, and the other will say focus. DO NOT ADJUST ANYTHING ELSE WHEN YOU ARE IN THIS TV SET!!! No slowly rock the focus control back and forth till you get the sharpest picture. Put back on the back cover and enjoy!!! Good Luck
Jun 13, 2007 | Samsung TXJ2879 28" TV
High Pitched Noise
most high pitch noise comes from the anode conection on the picture tube thats connected to the flyback anode cap thats mean there is a high voltage leak,to stop the noise you can discharge the high voltage take off the cap and clean with alcohol.if the noise continue.you will have to put some red or clear silicone both the cap and tube stick together leave to dry for about 2 to 4 hrs.this will eliminate the leaking.good luck.
Jun 11, 2007 | Toshiba 27A41 27" TV
NO PICTURE, JUST A HIGH PITCH NOISE, SMELLS LIKE SOMETHING BURNING
Very common problem with these sets. The High Voltage transformer and the horizontal output transistor is most likly the problem.. If you know the saftey issues involved and know how to solder and unsolder, you can repair this set but theres a possibility you could also have a fault in the horizontal driver circuit, such as l401. if your not a tech its best to have this set fixed by a trained tech, if you wnt to spend between 175 to 225.00 Good Luck
Aug 13, 2006 | RCA F36665 36" TV
RCA P46924 46" Rear Projection Television Logo
91 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
