Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Kenmore Gas Range - 2 knobs don't activate ignitor
I have a Kenmore gas range. Two of the four burner knobs do not activate the igniter, but all four burners have spark. You can light the burner by activating the igniter with one of the 2 other knobs that work. Is this a simple fix?
  • paul lounsbury Oct 15, 2011
    what specifically do you do to use the igniter that works to light the other burners?
    Scholar:
  • 162 Answers
There is a switch that is broken behind the knobs they cost no more than $15.00. remove the knob so that you can see it it's white in color.
Posted on Dec 10, 2008
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
Oven turns off while baking
There is a service flash, W10622771, for gas ranges of your model number--the bake burner ignitor is not lighting the gas--it's a direct spark ignition type. The ignitor is sparking but no ignition. Possible causes are (1) Wiring harness might be pinched between the bake/broil ignitors and the DSI board. (2) DSI mounting bracket may be contacting a solder joint on the back of the board. (3) Positioning of the ignitor and gas burner ignitor ports may be out of adjustment. (4) Ignitor electrode deterioration
Facing the range, the DSI board is behind the control panel on the left side, mounted in the bracket.You'll have to remove the back cover to expose the boards. BE SURE TO UNPLUG THE RANGE BEFORE DOING THIS. I can provide diagnostic mode if you want to proceed further.
Aug 09, 2015 | Maytag MGR8700DH MGR8700DH 5.8 cu. ft....
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Igniters always on with a fridgedaire duel fuel range?
You should have a professional diagnose this. This unit should not have any clicking or ignitors on while not in use.
Dec 28, 2012 | Frigidaire FPGS3085KF Stainless Steel Gas...
How to use kenmore gas range during power outage
just use a match to light top burners, the oven will not work or pass gas if you have a electronic ignition range
Feb 06, 2010 | Kitchen Ranges
When I turn on a burner, all the other burners click like they are trying to turn on as well. The clicking is continuous and really annoying! Thanks for your help! Tammie
Anytime you turn on a gas range all burners click for safety reasons. If a knob has been turned by mistake the gas lights to prevent gas from escaping into the room. If you turn the control knob past the LITE position after the burner lights you should be OK and stop the clicking. If the clicking continues regardless you have a defective ignitor switch that must be replaced.
Aug 26, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Only one burner of four not working
sounds like a bad switch in the knob, turn on the defective side, turn on the one that works and keep the clicking going then turn on the defective burner while "other" is clicking if this lights then it means you have a bad switch or loose connections
May 31, 2008 | GE JGBC20 Gas Kitchen Range
Maytag Kitchen Gas range
First of all- when you turn any ONE of the burner knobs to "ignite" all FOUR burners will spark/click. This is normal. If you're getting a spark from the ignitors when all knobs are set to "off" then you most likely either got some moisture into one or more of the switches below the knobs (sometimes they will dry out and be fine after a while, but I have seen them burn-up/melt/arc too) OR one or more of the switches is stuck/shorted. Good luck and hope this helps.
Unplug the range before working on it and don't attempt anything you're unfamiliar or uncomfortable with.
Dec 21, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Electric start gas range
You either have a short in your electronic ignition or the ignition board is defective. Check the wiring to the ignition board for shorts. also check and make sure you ignitors are well grounded.
Dec 08, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kenmore Gas Range - burners won't ignite
its possible your gas regulator is bad or the gas line to the ignitor is stopped up look at the line and see if some type of food has blocked the outlet
Dec 06, 2007 | Kitchen Ranges
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
312 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
