Help calibrating I just received my Stratford Labs Digital Image Copier and it instructs me to to click "calibrate" button the first time I connect to my computer--where is the calibrate button??
  • asharon_45 Jan 01, 2009
    I clicked on the calibrate button and it doesn't seem to do anything? Does it not show a progress bar? All my slides are very overexposed and it is not the slide as it is perfect for the projector and printing? Not sure what I am doing wrong? I do make sure it is empty when I calibrate....any suggestions?
  • oldscouter Jan 03, 2009
    I have a Digital Image Copier that tells me to click on the 'Calibrate" button so where is it..Without that the photos are overexposed.
It's on one of the dialog boxes within the software. Click on the Photoimpression6 icon and then click on Get Photos at the left of the menu bar and then click on Acquire from Scanner. This brings up a dialog box and at the lower left corner is a Calibrate button. It should be pressed without any negatives or slides in the viewer.
Posted on Dec 29, 2008
How do I calibrate my windows PC monitor?
To calibrate your screen you have to open the control panel by clicking on the start button then the control panel in the right collum. Type "calibrate display" into the search bar in the top right of the control panel window. Open the calibrator by clicking on "calibrate display color" you may have to have administrator permission to calibrate the screen. Then follow the instruction on the screen.
Oct 20, 2013 | Computers & Internet
Where can I get the software for the Stratford Labs GFP-001 digital image copier for Windows 7?
The manufacturer's website advises that the GFP-001 Image Scanner is, Compatible with Vista and Windows XP systems Only. Requires USB version 2.0 Only.
Sorry, but I do not believe you will be able to find support for Windows 7, unless your scanner functions with one of the generic drivers inlcuded in Windows 7.
Jan 01, 2011 | Office Equipment & Supplies
Color calibration
now you can do a full auto gradation under the additional functions button. just follow the instructions as you run it they are self explantory.
though my experience from working on them it is never that simple. there is so much involoved on the inside of this machine that will wear the toner starter out, the developers go bad, cleaning blades and several other factors all effect the color of this particular machine.
so start with the auto gradation and if that doesn't help then i would suggest getting a tech familure with that machine to come and fix it for you.
Apr 24, 2010 | Canon imageRUNNER C6800 Copier
I have e-sky FMS simulator. I tried to calibrate
This is to easy fix.
Open FMS click on controls on the top menu.
A box will appear click on "Joystick interface" so it is hilighted blue.
Then click the button mapping and calibration.
When this box below appears put ticks in the "Inv" for the channels you wish to reverse. While you are here it may be a good time to
'Calabrate" click this button an follow the instruction. This will help your controls be more accurate. When your done click OK on each box untill you are back to the sim. Happy flying!!
Sep 01, 2009 | E Sky Flight Simulator Training Kit
Can't calibrate new Stratford Labs GFP-001
Can't calibrate the new Stratford "Digital Image Copier" GFP-001.
Followed all instalation instructions till I got to the part where it said that the unit had to be calibrated for the first time used. It said to "Click" on the "calibrate" button to perform the calibration,
but there was no calibration button shown, or no on screen desplay pop-up. Would like to know what I can do to rectify this problem. I am using an Acer Laptop with "Vista Home Premium";
which has 2.0 USB Ports which is called for. Does this device need to be calibrated, or can it be used without the required calibration?
Thank you,
Gerry Hall
Jun 07, 2009 | Logistixs Campus Media Publisher 2003...
Logitech Wingman Extreme Digital Calibration
Hello there
Usually these JS automatically calibrate when intalled, but...some like olders models, have problems, with sensors, or bad calibrations inside the rotor ans sensors area. for those fixes, you have to open carefully the JS and look for the sensors that usually are two optical sensors, and clean good, with computer air spray, sometimes that did the trick, but others, its a sensors, problem. you have to RMS the product, or use your warranty.
hope these helps!
Mar 02, 2017 | Logitech WingMan Extreme Digital 3D...
I purchased a stratford labs digital image copier model GFP-001 to convert slides to digital pics. Have it installed on my computer (windows xp) but can not get it to scan a clear image. No website...
Just found the company that actually makes "Stratford Labs" scanners. Called them very helpful, still sending this one back. They actually answer the phone when you call, that's a plus.
1-847-550-9998 Affillated is the name of the company.
Stratford Labs GFP-001.
Dowadiddy
Jan 11, 2009 | Office Equipment & Supplies
Calibration
Greetings,
Sorry to hear that you are stuck?
If and when you regain the function of the menu button, you should perform a calibration. It should be done every time you install or replace a printhead. However, you can run a calibration if you are seeing changes in the image quality. Calibration aligns the printheads and performs a nozzle health check to enable high-quality prints.
1 Load the main tray or photo tray with photo paper.  You don't have any photo paper, but it is recommended for calibrations. 2 Press Menu. 3 Scroll down until Calibrate Printer is selected. 4 Press OK. A new screen appears with Print Calibration Page selected. 5 Press Start and follow the instructions on the LCD screen to complete the calibration.
If the stuck condition presists, let us know. Best bet is to call us directly at the 800 421 6699 as our team will be able to get you running quickly.
Talk tol you soon,
Ron Baird the friendly Kodak guy
Sep 28, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
5300 printer
To calibrate the printer right click on the printer icon and open the status monitor once you open it there is 3 symbols on the top right of the box one looks like a hammer and wrench in an x configuration, next to that is an i for i for about and a ? for help. Click on the x which is Maintenance it will bring up a new box which has 2 options calibrate and printhead cleaning when you chose calibrate it will print a calibration sheet which you then need to put into the scanner portion and press the start button, these instructions will also come up on the screen when you go through the process.
Jun 14, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
196 people viewed this question
jasbo
jasbo
