Question about Timex Sports Ironman Triathlon 100-Lap 66801 Wristwatch
Alarm Malfunction. My ironman watch alarm does not beep after changing the battery.
  • 1 more comment
  • brad047966 Dec 31, 2008
    just received this watch(black version), no sound with any function; watch was purchased new.
  • Anonymous Mar 12, 2009
    Alarm works but won't beep, only flashes.
  • SoCalJim Apr 04, 2009
    I replaced the battery and now the alarm only flashes and the "beep" does not sound. I turned the back cover of the watch 180 degrees, with no change in result.
Remove the band and the back of the watch, rotate the back 180 degrees and replace. The alarm should sound again.
Posted on Apr 03, 2009
I found the contact from the module to the back case was short, and not making contact; a little adjustment and now all is well ;-)
    Problem Solver:
  • 4 Answers
Re: Timex Ironman Triathlon 100 Lap Watch No Sound After Battery Replacement
Here's the fix. With the battery in place and the watch functioning (But the screw-on back of the watch off. Duh?) there is an instruction on the flat cap that holds the battery in place: "Press here to reset." (I just fixed mine and I'll be darned if I'm going to mess with it in case I didn't remember the instructions ver batim! ;) What you, me and everyone else has been missing is exactly where the reset "button" is located.
Don't be suckered by simply pushing the red cap. It may click like mine did, but it is not the reset button.
It's no button at all but a little flap of metal, just beside the clasp/latch of the metal cap that holds the battery in place.
Get out the magnifying glass, or the 4.0 readers, a flashlight, and a very tiny diameter (compass/pencil works) piece of metal wire. A large paper clip is too big. Maybe a large sewing needle. It's really itty ***** finiggally (Hope I'm not losing any of you with my technical language...)
Look closely and you will see a stand alone, tiny, tiny! piece of metal that if you push on it, will contact a... contact? on the watch circuit board.
Press the metal contact spring piece to make the contact and that should be it.
Make sure when you replace the screw down cap, that the cap has the circular piece of metal (that acts as the sound board to produce the beep-beep) oriented so that that the itty ***** spring that sticks up from the watch/brains/circuit board, touches it, or no beep-beep!
Hope it helps.
SweetDoug
Posted on Apr 23, 2011
How do i turn alarm off on timex tk494
THE TOP BUTTON ON THE RIGHT HAND SIDE OF THE WATCH SHOULD TURN OFF THE ALARM.JUST PUSH THE BUTTON IN.THIS SHOULD STOP IT FROM BEEPING.,
Dec 10, 2014 | Timex Ironman Triathlon 50 Lap Digital...
How do you set a timex ironman wathc and how do you use the stop watch and alarms
Hi hdirkse,
To set the digital time and date on your Timex Ironman, please follow the steps below.
1. press and hold the "set" button for two seconds.
2. Use the "advance" button to reach the correct hour.
3. Press the "mode" button, followed by the "advance" button to set the minutes on your Timex Ironman.
4. Repeat the procedure of pressing the "mode" and "advance" buttons to set the month, date, year and day of week.
5. When you are finished setting the time and date, press the "set" button to save.
Setting an Alarm
1. Begin by pressing the "mode" button until the alarm screen appears.
2. Press the "set" button and use the "advance" button to set the hour for your alarm.
3. Repeat the same procedure to set minutes and seconds for your alarm.
4. When you have finished setting the alarm, press the "set" button, followed by "advance" save and activate your alarm.
5. When you alarm sounds, you can deactivate it by pressing any button on the watch.
Hope it helps.
Thank you for using FixYa.
Sep 25, 2010 | Timex Ironman 53151 Wrist Watch
How do i set the hourly chime on the timex ironman flix watch?
Press Mode till you are in Alarm setting
Press and hold split/start button till you hear the double beep. You should also see a small clock icon above the last digit of the seconds... you are all set. Repeat to deactivate hourly chime.
Nov 12, 2009 | Timex Ironman Flix 100 Lap Unisex Watch
Help with battery problem on Timex Ironman Data Link Wrist Watch and after installing a new battery the alarm is silent.
Help with battery problem on Timex Ironman Triathlon after installing a new battery and reset, displays the message 846010 1.0 P1and the alarm is silent.
Jul 08, 2009 | Timex Ironman Triathlon 50 Lap Digital...
Beep and chime will not work
I think there would have been a minute spring coming from the back of the watch module to the backplate of the watch - this spring carried a vibration / beep which echoed off the backplate. Chances are you have damaged this spring during battery change - as i did with my gShock. Basically it's nackered!
May 31, 2009 | Timex Watches
Getting my digital watch to stop beeping every hour
i think the battery is low voltage,try to change the battery 1
Aug 25, 2008 | Timex Sports Ironman Triathlon 50-Lap...
Resetting sound
Could the jeweler have inadvertently damaged the beeper in the watch when he changed the battery? I'd tell hime the problem, ask him to restore the sound and see what he says ("oops" is a bad sign).
Lenny
Feb 15, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Old model timex compact disc digital audio
Hi catlady05,
Setting an Alarm
Hope it helps.
Oct 29, 2007 | Timex Ironman 53151 Wrist Watch
Watch isn't recognised by computer
Hi Hoffman518,
To set the alarm on your Timex Ironman, please follow the steps below.
Hope it helps.
Aug 08, 2007 | Timex Ironman 53151 Wrist Watch
Timex Sports Ironman Triathlon 100-Lap 66801 Wristwatch Logo
451 people viewed this question
Top Timex Watches Experts
Ross Keen
freddyfox
Jerry Greenberg
Jerry Greenberg
Are you a Timex Watch Expert? Answer questions, earn points and help others
