Question about Gateway MX6124 Notebook
Computer freezes, and locks up
I have a Gateway MX6124 with anIntel Celeron M 1.5GHz processer. every so often it locks up and you can't do anything with it. then when you unplug it and remove that battery and replace them and try to restart the computer the blue power light will com on and will not boot up, no image on the screen and you can't hear the hard drive booting up and after a while of messing with it you can get it to boot up but it will lock up again when you least expect it it can go for a few minutes to working for hours before it happens again
  • Greg Skelton May 11, 2010
    Is this truly random or does it happen when a specific program is run?
  • David Cates May 11, 2010
    When it locks up does it shut down or just freeze?
I have an old compaq laptop 15 inches. I dont have its driver know, no sound, wifi, ethernet, vga.. i need all . Can u help from where i can get these driver's. intel celeron m 1.50 ghz 512 mb ram 40...
Download all drivers off this page onto a Pen drive, memory card or DVD
http://support.gateway.com/product/default.aspx?partNumber=5386
and install.These are all the drivers for the laptop. Hopefully you have not changed the os to VISTA as these drivers seem to be for Windows XP. These may also work in vista.
Jan 25, 2011 | Gateway MX6124 Notebook
Gateway MX6124 laptop: some keys on the right side of the keyboard display numbers instead of letters. Keys involved and actual display are: Row Starting with q: u=4, i=5, o=6, p=*, Row Starting with a:...
Your computer is in keypad mode. To check, turn off your Num Lock. On my system that disables the embedded keypad. To fix, go into setup (usually F1, F2 or delete when booting). Somewhere you should find a setting for using the embedded keypad. Mine has two options, Fn Key Only and By Num Lock. Yours may be different. One activates the embedded keypad, which you are seeing. Try the other setting.
Apr 25, 2010 | Gateway MX6124 Notebook
I have a Gateway MX6124 and cannot get my wireless to work. I have tried turning the wireless on (Fn and F2 together) but all that does is turn the wireless light on, and still does not bring up the...
You should check device manager to ensure that your wireless device is working properly. If it is, once turned on, you have to double click on the wireless icon on your taskbar usually next to the clock to chose your preferred network. If you need further assistance, please give us a call day or night at 800-595-3564.
Jan 18, 2010 | Gateway MX6124 Notebook
Missing drivers for "other devices"
Go to Control Panel - System - Device Manager and right-click on each of the hardware components where you need drivers. There will be a description of each item, so then you can download the drivers. Good luck
Jul 04, 2009 | Gateway Computers & Internet
Gateway mx6124 the back hinge is broken
lost my recovery disk, upon boot system VGN-N130G laptop, informs me that Windows XP failed to load because sustem registry file is missing or corrupt.
can I creat a boot dist and where can I downlosd this form?
bwbnh1
Jan 05, 2009 | Gateway MX6124 Notebook
MX6124 WINDOWS XP PRO FRESH LOAD
Go to your computer manufacturer's website and locate the software/driver page that specifically pertains to your system. locate and download the software/drivers that you are in need of. You should also see a notebook system software option to download as well. Be sure you download and install that as well.
Sep 04, 2008 | Gateway MX6124 Notebook
Keyboard Stuck in Function (Fn) Mode
To unlock number lock (numlk):
Depend on comp, but try pressing (at same time)
fn + f11
or
fn + Scroll/numlk (next to f12)
or
f12 + Scroll
or
f12 + Scroll + fn
or
ctrl + Shift + Scroll
or in BIOS there is a numlk option
Aug 12, 2008 | Gateway MX6124 Notebook
No sound from my laptop
I couldn't download it either until i tried a different approach
Go to your hardware update wizard
Choose Don't search I will choose the driver to install
Scroll down and choose sound video and game controllers
Choose the manufacturer which should be Conexant Audio
and follow the steps to install that way.......
This was the only way it finally got installed and if it says it can't find the "camc6aud" sys file, under browse choose the directory where you downloaded the driver
Example: C:cabs/Conexant Audio/camc6aud
Good luck!!
Mar 05, 2008 | Gateway MX6124 Notebook
Mx6124 problems with distorted sound.
The problem is your processor here.
If u use dual core processor for this, it will not use 100% of ur CPU usage.
Oct 14, 2007 | Gateway MX6124 Notebook
Gateway MX6124 Notebook Logo
82 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
