Question about Garmin GPS
How can I charge my garmin 780 not in my car?
  • Garmin Master
  • 2,130 Answers
You need to purchase an AC wall charger. Make sure it's a Garmin. There are too many after-market units out there that are not wired correctly and will cause your Nuvi to think its connected to a PC.
Posted on Dec 11, 2008
My Garmin Nuvi 780 will not stay charged. also i am unable to charge it while I drive.
The Nuvi 780 is an older GPS. Most likely, the battery needs to be replaced due to age. Many lithium-Ion batteries are only good for 2 years. More information can be found here:
Please have the battery replaced by a professional. We have repaired many units from failed battery replacements by customers. Often other things get broken in the process, sometimes beyond repair.
Apr 09, 2013 | Garmin nuvi 780 GPS
The garmin turn on them the light turn off and the touch screen does not function. the version is the nuvi 780
Possible bad battery---are you charging with the lighter plug in the vehicle or what? That plug it uses for the lighter will have a fuse inside it in most cases.........
Nov 08, 2012 | Garmin nuvi 780 GPS
Why won't my Garmin Nuvi 780 charge?
A couple part answer here. The USB pin out for the Garmin is strange. If it goes into PC mode, then the cable is got the wrong pin out for the unit. Try different cables until one works.
If you can get a full charge on the unit and the battery does not provide at least an hour + of battery use, then the battery needs to be replaced. Amazon sells replacement battery kits with instructions. You just have to make sure you order the right one.
Sep 18, 2017 | Garmin nuvi 780 GPS
My garmin 780 doesn't operate with the car charger plugged in. goes to a scenery photo that has a small picture of it plugged in to a computer at the bottom of the screen, and does not load. is that...
hi danielktx, its doing that because it thinks the charger is the USB cable and connected to the computer...either you have the wrong charger (is it factory or after market) or the charger it self is faulty.
Standing Member of G.O.T.
Please Support Our Troops
Sep 18, 2011 | Garmin nuvi 780 GPS
I purchased a garmin nuvi 780 in the Spring 2010 and within a few months the battery refused to hold a charge more than a couple of minutes when removed from the charger. Serial # 1CG154094 Is this under...
I checked your unit under Garmins recall section and your unit has not been recalled for battery issues. If you enoy your units MP3 feature and FM transmitter I would recommend sending it in for warranty. Otherwise it may be cheaper to purchase a new unit.
Hope this helps!
Feb 16, 2011 | Garmin nuvi 780 GPS
How do I charge my garmin nuvi 780 gps?
it came with a car charger that plugs into a cigar lighter or power point in the car or truck that plugs into the back of the GPS, u can also charge it with a home charger, they are avail on ebay for about $8
Sep 28, 2010 | Garmin nuvi 780 GPS
My Garmin nuvi 780 will not turn on. When I turn on, the Garmin logo shows on the screen. However, when "Loading Maps" is displayed, 1-2 seconds later the screen goes blank. This occurs when the unit is...
I had the same problem. When you have your nuvi plugged into your cigarette lighter it doesn't charge. Your battery is probaly near dead. I called Garmin and they told me to plug it into my computer via the usb cable. Turn the Garmin off and let it charge for several hours. That did the trick
Apr 03, 2010 | Garmin nuvi 780 GPS
My garmin 780 doesnt have any sound -voice. It says "none found" under language.
My Garmin 780 says the same thing. "NO VOICE FOUND" I reinstalled voiced like 5 times already. And after a little while voices dissapears again! What the heck is wrong with this unit????
Sep 23, 2009 | Garmin nuvi 780 GPS
Garmin nuvi 780-when recharging the battery should the user know when it is complete and how long should it take?
Hello skatecat,
The Garmin Nuvi 780 GPS receiver should take about four hours to fully charge. You can review the charge status by checking the battery icon in the top corner of the GPS's menu page.
Best Regards,
"Go Ahead. Use Us."
Jul 03, 2008 | GPS
Garmin nuvi won't turn on
folks, the garmins have an on-board battery that needs to be powered up (at least occasionally) via the usb port - like from your computer. just using the dc car power cord does nothing for this battery. i've had this exact same problem on both my 760 and 780 nuvi units. fixed it using the usb charge. seems to run down differently for all the various nuvi models. my regular charge will hold for 7 hours on my old 660, my 760 and 780 work about 5 hours. my 'power up' failed on the 660 after 10 months with no internal battery charge, but the 7xx models only took about 5-6 months to 'fail.' hope this helps. jack b :-) in midland, tx usa
Jan 13, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
73 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
