Question about Dryers
Dryer off balance.
My dryer makes bad screecing noises. It is off balanced and rollers are intact. If I put clothes in it it will quit spinning but not turn off. How do I fix the problem?
    Genius:
  • 1,122 Answers
Motor is to weak to turn drum(bad motor)sorry-mike
Posted on Dec 10, 2008
A knocking noise during agitation wash cycle
could be a bad counter balance , u can remove the front panel and run a spin or wash cycle and listen to where its coming from so u don't have to replace all the balancers. on some models theres a heavy ceramic weight at bottom that at times goes bad and throws it off balance, just run it and look where noise is coming from
Jul 25, 2014 | Maytag Performa PAV2200
Lg dryer noise
the drum rides on rollers. I am thinking you have a bad roller.
Jan 03, 2012 | LG IS 250 Dryers
My Frigidaire Gallery front loading dryer seems to be out of balance. It has become louder and makes a rhythmic grinding noise as it spins. Sometimes it starts with grinding noise that stops after a...
YOUR DRYER DEFINITELY HAS A BEARING RUNOUT PROBLEM (THATS THE GRINDING NOISE YOU HEAR - THE DRUM RUNNING ON THE SIDE OF THE CABINET ) . IT WOULD ALSO GRAB CLOTHES AS YOU SUGGEST . COST TOO MUCH TO FIX = GO AND SHOUT YOURSELF A NEW ONE IF U CAN .
Jul 26, 2011 | Dryers
Washer is shaking really bad making bad noise sound as though it off balance but its level.
may be the drum rollers/glides:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Jan 11, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Very loud banging and clanking when the drum is spinning
If the dryer is making this noise the roller on the belt tensioner has a flat spot causing this to happen. The roller and belt are replaced as a unit. If it is the washer unit the spring has fallen off on one side of the drum which is one of two that balances the drun while spinning
Apr 28, 2010 | Kenmore 98702 Stacked Washer/Dryer
Machine makes a thumping noise when spinning
If its thumping you have the maching overloaded and the clothes (very easy to do with heavy jeans or sweaters) are all on one side causing an out of balance situation. Try relocating some of the clothes to the other side of the unit and if that doesn't seem to help remove some of the clothes to eas the load on the machine otherwise it will never reach maximum spin speeds needed to rinse your clothes.
Aug 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Off-Balance Duet Washer
spin basket surport is defective..put unit in spin without clothes do it bang and clang,,sound like train ,or airplane,,if so contact whirlpool your under warrranty for spin basket..onthejob
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryer thumping
It sounds like the rollers have gone bad. Its an easy fix. If you like the dryer a repair man can fix it cheaper than buying a new one. you may even be able to fix it. if you go sears.com and go to the parts section and put in your model number you can pull up a diagram to see how to take the dryer apart. you can also order the parts from there too. Good Luck.
Jan 29, 2009 | Dryers
Zanussi washer/dryer
Hi, Sorry but this sounds very much like the drums bearings have failed. It's quite a big job and unless the machine is still under warranty maybe uneconomical to repair.
How old is it and which country are you in?
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills.
If they do not, please hold off on the rating and add a comment with more details so I can try to help you further. Cheers, D
Jul 12, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Dryers Logo
175 people viewed this question
Top Dryers Experts
