Question about Philips 60PP9352 60" Rear Projection Television
My red and green colors separated
The colors on my 60" rear projection tv have separated. I cannot locate my quick setup guide. I don't know how to do the convergance that everyone is talking about. Can anyone help?
It is right. Or set for default sane problem in my TV happened today May 28 07. But none of the above worked repair man came over $250 repair change parts. A-OK worth the money maybe you should not play Xbox I I do and breaks every year. Next year upgrade to plasma prices are coming down.
Posted on May 20, 2007
You must go into the menu on your remote, where it says picture you must move to right and then down until manual convergence appears.
Posted on May 19, 2007
You have to go into your menu and into setup then look for convergence, don't know exactly where since the TV isn't in fornt of me. But once you get there, there should be a bund of "+" all the ones thare are in color you need to change to white. Depending on the TV you would use our left or right arrow keys, enter or ok. Hope this helps.
Posted on Mar 29, 2007
Yes my 60 in phillips rear projection tv model # 60p8341a the screen is a reddish orange color and wanted to know how to fix it
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 19, 2010 | Philips 60P8341 60" Rear Projection...
The colors on my screen separate and triple the image I'm seeing.
The tv have an on going convergence problems.Just not total dead convergence effect yet.The tv convergence board require 2 STK convergence ICS,some or all it resistors to be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 06, 2010 | Philips 60PP9202 60" Rear Projection...
Bad color; everyone and everything is very orange
contact the store you bought it from. They will help you or refund you
Mar 07, 2010 | Philips Magnavox 9P6034C 60" Rear...
There are three colors on the screen all make it blurry
the three colors in your screen are off alignment due to a color convergence failure. Usually due to damaged convergence power amplifiers(mounted on heavy looking metal heat dissipators)located in the D board. Replacing them usually takes care of the problem, sometimes there is further problems that arise from this failure some pico fuses located in the G board(power supply).
Jul 29, 2009 | Sony KP-51WS500 51" Rear Projection...
Philips 60 inch rear projection screen is wacky!!
Your TV most likely has one or more possible problems.
  • Screen looks 3D
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 10, 2009 | Philips 60PP9202 60" Rear Projection...
I have A 60 philips projection tv with triple picture
Don't adjust anything from the rear of the set unless you are a TV repair tech. It can get ugly real quick.
Try adjusting the convergence using your remote...Pull up the settings menu - goto picture - convergence - etc....See if you can adjust the color alignment back to normal. If not your convergence chips are most likely going out.
Nov 10, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 9P6040C 60 in. Rear projection
Here are some of the most common symptoms.
  • Screen looks 3D
  • Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site http://www.TvRepairKits.com . They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Hope this helps,
Jul 23, 2008 | Philips 9P6040C 60" Rear Projection...
Philips model 60PP920217F
You need to replace both convergence ICs STK392-120 they are an easy repair you will also need (4) 6.8ohm Convergence resistors. You can get replacement ICs and the resistors at the following link and they will provide free installation instructions and free on line tech support so you will be able to do the repair yourself and save about 400.00 for a 45 minute repair. heres the link.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
Convergence
mammy: In the MENU when your correcting this problem in order to use your remote you must press the M button or MENU button. Once it is done then you can adjust the color convergence. I also suggest you to check the remaining 2 colors for a nicer setting. SithPitt
Jul 04, 2007 | Philips 60PP9202 60" Rear Projection...
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
93 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
