Question about Cameras
Sigma Lens Problems
I have a Sigma 28-70mm f2.8 lens. I bought it used. When I put it on my Canon xsi it takes beautiful shots for about 20-25 minutes then I get a message on the screen of the camera that says, "Err 01 Communications between the camera a lens is faulty. Clean the lens contacts. When I turn the camera off and back on again I find it took the picture but gives me the message. I took it to a camera repair shop. Got it back home, worked for about 30 minutes, started doing it again. I'm wondering if it can be fixed. I don't want to spend any more money on it if it can't. Any suggestion?
  • 1sooner Dec 10, 2008
    I've already read the posts at sportshooter. I really don't understand all that they are talking about. I'll go ahead and leave the fixing up to the repairman. I guess what I want to know is if this a common problem with Sigma lenses on Canon cameras and if this is a problem that will demand that I discard it and get another lens? Should I keep attempting to fix it or move on?
    I think I will move on. I just wanted to hear it from someone who isn't trying to sell the repair to me. Thanks.
  • Cameras Master
  • 19,396 Answers
The error can be fixed by taking apart the lens assembly and cleaning the contacts.
Take the camera back to the repair shop, complain, and get the job done properly, if the camera did not receive any shock after the repair, then you are entitled to a proper repair.
Posted on Dec 10, 2008
  • Cameras Master
  • 6,487 Answers
Some user also has the same problem that you have and they end up changing the reaplacing the lens eventhough there's really no clear issue about this two..I suggest you go ahead and replace it so you can move on...
    Genius:
  • 1,269 Answers
I suggests you to just move on. Lens error is definitely the hardest part to fix. It can be replaced but it will fail again for short period of time due to compatibility issue.
    Genius:
  • 3,422 Answers
The only solution to this problem is to
remove the lens, reattach it, and check to see if the error message reappears. If you see the error code again, you’ll need to clean the lens contact.
If you still face the problem then you will have to get it repaired as the fault is with lens mechanism.
  • Priya darshan Dec 10, 2008
    The cost of repair can be go upto $100.I strongly recommend you to get this repaired if it is under warranty.If not then please switch to a new camera.
    Genius:
  • 1,847 Answers
What is the model no# of this camera?
Does my Sigma 28-105 mm Aspherical for film camera work on my Canon 5D Mark III?
If the Sigma lens mount is a Canon FD fitting then you can get an adapter FD to EF that will allow you to use the old lens in manual mode. If your camera isn't designed to take EF-s lenses then they will not fit on the camera. My EF-s lenses will not fit on my 6D.
Jul 24, 2012 | Canon Cameras
I am trying to use an older SIGMA 28 - 200 mm f3.5 - 5.6 UC Aspherical AF lens with a Canon Rebel Xsi and am getting a communication error (Err 01).I have already cleaned the lens contacts but still get...
From working with third party lenses in the past what I've found is that Canon doesn't give up the "chip" technology so the older lens can not talk to the newer cameras. I suspect that Canon does this to promote their lenses over the competition. You might be able to send the lens to Sigma and have them re-chip it and have a great lens again.
Dec 26, 2010 | Sigma 28-200mm f/3.5-5.6 DL Aspherical...
Does a sigma 70-300mm dl macro fits on a canon 500d camera?
Yes, if you get one with a Canon mount. Sigma makes their lenses available with a variety of mounts; a lens with a Nikon mount, for example, will not fit on a Canon camera.
Jul 12, 2010 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Does the Sigma 70-300AF APO Micro Super lens fit
Please visit to:
http://www.sigmaphoto.com/sigma-lens-finder
Mar 30, 2010 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Sigma 120-300mm f/2.8 EX HSM APO adapted to digital Canon
Hi The 120-300 f2.8 is a full frame lens so it works on all canons with a eos fitting
Jul 14, 2009 | Sigma Zoom Telephoto 120-300mm f/2.8 EX...
Sigma 28-300mm autofocus problem
You will need the interupter replaced the iris is closed down so the a/f will not lock on
Jun 16, 2009 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
I am trying to use an older SIGMA 28 - 200 mm f3.5 - 5.6 DL Hyperzoom macro Aspherical AF lens with a Canon Rebel Xsi and am getting a communication error (Err 01).I have already cleaned the lens contacts...
To NOT get that error you need to use in AV mode. It's the only way that old Sigmas work with the new Canons. It's an aperture bug that old Sigma lens have and some the only way to fix it is to rechip it. The problem is that Sigma no longer rechips the lens.
May 19, 2009 | Sigma 28-200mm f/3.5-5.6 DL Aspherical...
Matching 2 brands
Simga makes lenses to fit several different makes of camera bodies including Canon and Nikon. I'm assuming your Sigma lens has a Nikon mount, if so there are some adapters, but they may not work like you want - not all functions may work properly thru the adapter. For best results you should return or sell the lens and get one with the Canon mount.
Dec 26, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Sigma 70-300 AF lense
if the lens is the older type with a macro switch which has 2 screws holding it on to the lens it will not work.If it a super 70-300 you can put the camer on AV set iris to F22 if you have a stopdown button see if the lens stops down it ok if noe it will need a rechip or a new interuper
Sep 27, 2008 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Cameras Logo
70 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
