Question about HP Pavilion dv6000z Notebook
Problem with web cam
Hi
I have hp with in buiid web cam I can't use it
kindly help
I installed the latest version of quick play and now my web cam will not open? It says it won't open because it is being used by another program. I have HP built in on my laptop
Help
The issue is really easy to fix. All you need to do is go to this web site and down load the SERVICE PACKAGE 1. This could take a little time to download, but after word it work just fine.
http://www.microsoft.com/downloads/details.aspx?familyid=B0C7136D-5EBB-413B-89C9-CB3D06D12674&displaylang=en
what happen is when you downloaded Quickplay it putted out the build in settings for web cam.
Posted on Dec 11, 2008
Skype wouldn't accept my web cam
Try the latest downloadable version of Skype and make sure the web cam has been installed with the latest driver from the manufacturer or the Internet.
Oct 08, 2010 | Cameras
When im using yahoo messenger i cant use my web cam..how to install the web cam?
Latest Webcams are just plug and play, no need for a driver so ensure that ur usb port is enabled.
Oct 05, 2010 | HP MINI 2133 NOTEBOOK PC - 1.6GHZ PC...
I have problems with my hp web camara it freeze it a lot on messanger any help
If your web camera freezes check your Windows Device Manager and see if the hardware is recognized and installed properly. It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem. If the device is not recognized in Windows XP, it will be listed under Other Devices
In either case you can try to update the drivers. Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers. In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer. After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.
If the drivers and web cam software are correctly installed, and you still it freezes, there can be a problem with the program settings. Most chat and meeting software have a configuration option to select the video source for the web cam feature. If you have multiple devices that qualify for video, you might need to select your web cam device as the source for the web cam feature in that program. Some web cams and programs require additional software, although that should be installed with the web cam if things are right. But is does not harm to check if your Java, Flash and Quick time software are installed and up to date. But certainly check your DirectX software, since all video applications, including web cams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c – Windows Vista: DirectX 10).
Thank you !!
May 30, 2010 | HP EW192AA Webcam
Hi im just wondfering if you can help me i just purchased a Logitech Quick Cam Pro 5000 and have installed it and it is working beautifully but now when i open up windows media player my music is not...
Try a clean install of the software as outlined below. (It is different from a regular install):
For XP
For Vista
Make sure you have the latest version of the software. Select your OS and proceed to download from this link.
(Dont worry if the XP articles is meant for mice, the procedure is the same.)
Jun 25, 2009 | Logitech QuickCam Pro 5000 Webcam
Horrible
The problem is not with your web cam its with your aim software. If you do not wish to go in deep settings of aim then I'd recommend you to uninstall your current version of aim and install an older version under circumstances you are using the latest version or else get the latest version. Version 6.9 is the latest. If you wish to configure your current aim software then here is the link kindly visit and correct your settings. http://help.aol.com/help/microsites/search.do?cmd=displayKC&docType=kc&externalId=223350&sliceId=1&docTypeID=DT_AOLHOW_TO_1_1&dialogID=42119422&stateId=1%200%2040842282
Jun 15, 2009 | Microsoft LifeCam VX-3000 Web Camera
Plese help me
Hi, my name is LEX,
with my knowledge you have to install latest DirectX to install your Web cam. you can download latest DirectX Version at http://www.microsoft.com/downloads/details.aspx?FamilyID=2da43d38-db71-4c1b-bc6a-9b6652cd92a3&DisplayLang=en
i also have a it-104wc webcam and i lost my Driver cd. if you can send me windows xp driver to suncomsl@hotmail.com
Thanks.
Oct 28, 2008 | Logitech QuickCam Messenger 50-Pack...
ok go to webpage http://welcome.hp.com/country/uk/en/support.html?pageDisplay=drivers
and den give ur model number and download the camera drivers and install it in ur laptop inshallah it works.........
Feb 25, 2008 | Computers & Internet
Hp quickplay button issues - dv9000
Ok the problem lies within the software. You may need to update the driver. Yes drivers tell this device added what to do. So log onto HPs website, download the updated version. This should help, if this does not help it then becomes hardware, which is better off leaving alone do to the expense.
Nov 26, 2007 | HP Pavilion dv9000z Notebook
I lost my installer cd
what kind of quick cam do you have try to use this page http://www.logitech.com/index.cfm/support_downloads/downloads/&cl=us,en
Sep 02, 2007 | Logitech QuickCam Express Web Camera
HP Pavilion dv6000z Notebook Logo
169 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
