Soyo DYLT032C 32 in. LCD Television Logo
Posted on Dec 10, 2008
Problems with Soyo DYLT032C 32 in. LCD Television. The TV will not turn on, I have un-plugged it and plugged it back in, in hopes it would re-set the tv. Do you have any suggestions?
  • 1 more comment
  • ripchic16 Dec 12, 2008
    I am having the same problem, I brought mine to a repair shop, and it's the power supply. It's fried, I need a new one... he said that this model has had that problem. I called SOYO, and the part is back-ordered, they said to call back in January, and hopefully they will have a ship date.
  • Anonymous Apr 18, 2009
    Blue light comes on but power wont start tv
  • SERRANO-D Apr 24, 2009
    BLUE LIGHT STAYS ON AND THATS IT,NO PICTURE OR SOUND,HAVE TO UNPLUG IT TO TURN OFF BLUE LIGHT.REALLY SUCKS.
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Jan 20, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3977
Points
19
Long story short:
Had the same problem with my Soyo.
Thought it was the power supply board problem that everyone else was reporting.
ordered one.  Plugged it in.  Did not work.
Inspected the Main/Logic board and found what looked like a black button that could be depressed.  It is located to the right of main processor on the board.  You can't really miss it.
With the TV plugged in, I pressed the suspect button.  The TV made a buzzing/clicking noise for a few moments and the stuck blue illuminated power button faded away.
Curious by this, I pressed the power button and low and behold the TV comes to life!
Looks like I found a "reset" button which seems to have fixed my problem.
Thanks Soyo for not bothering to mention that such a button exists.
I hope the rest of you have the same good luck.  In the event you are still in need of a power supply board, email me.  I have a spare now it seems.  ;)
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 04, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1204
Points
Hey Pogie, I'll buy that power board from you for my otherwise dead Soyo 32 inch...how much and what city are you located in...I'm in Canada.
Thx Glenn
Anonymous
Level 1:
New Friend:
  • Posted on Jan 22, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1204
Points
I do have a picture but the tv remote receiver will not respond to any comand
What does a power cord for at 32"flat screen TV look like for Soyo digital TV
This cord looks like a regular 3 pin cord used for things like computers, etc. You can get them from home center stores, hardware stores, computer stores etc.
I ahve a SOYO LCD model DYLT032c, the set will not power on and the power led does not light
1. This may be a fuse blown in the start up circuit or a rectifier diode at the AC input ( the primary side ) side of the main board.
2. In any case this will require a testing of components at the power supply of the main board by a qualified tech. A schematic is require to trace all defective components and replace them about 1 to 2 hours to isolate and repair.
Where do I get a cable to connect my laptop pc to the DVI input jack on the Soyo 32" LCD TV?
You will need either a DVI-I to DVI-I cable or a DVI-I to HDMI cable. Your computer should have a DVI-I output or HDMI. You can not directly connect a VGA output to the TV. If needed, you can purchase a VGA to component (Y/Pb/Pr) converter.
Blank tv but has sound
A couple of questions,
What make and model TV.
Are you using a external Digital receiver for digital cable or satellite.
Are you using a surround sound receiver.
I will have a better answer for you after you answer these questions.
My Soyo DYLT032 has power but no picture or sound
I HAVE FOUND 2 2200uf CAPS ON THE POWER SUPPLY BOARD THAT ARE PUFFED UP. CHANGING THEM USUALLY SOLVES THE PROBLEM. THERE'S ALSO A RESET BUTTON ON THE MAIN BOARD YOU MAY NEED TO RESET AFTER CHANGING THE CAPS.
5helpful
Long story short:
Soyo dylto32c
The DVI input on this set is meant for picture only.. ex. to display computer picture.
if you want audio with your picture. you must connect to either inputs YCBCr or YPbPr which both of those inputs has audio inputs.
Top Soyo Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
