Question about ViewSonic N3020W 30 in. HDTV-Ready LCD Television
View Sonic LCD TV - N3020W
My TV has a blue screen. The remote control does not communicate with TV. The butonns on the side do not work. I have taken this TV to a small repair shop but they said they could not get parts from View Sonic. They told me it was the power supply. Does any one have this problem ? Is it worth geting fixed? Where would I get a power supply if this is the problem?
  • annie99 Feb 07, 2008
    i have the same problem i phoned the tech guys and the said its the pixels a on off payment to repair it £120 but im not happy because its only 14 months old .
ginko
  • 19396 Answers
SOURCE: ViewSonic TV sound but no picture
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
Theinverter is the high voltage board that provides variable power to thebacklight lamp. This is the most common. When inverter is faulty youcan get no picture, or a very dim picture that can only be seen bypointing a torch light with a 45 degree angle on the LCD surface fromvery near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
Thisis quite uncommon, but happens. If the TV had been hit or moved the LCDcable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
Thisis the board that controls the video signal, it is difficult to test,as there is need to read determined values on IC pins. To test thisboard you need to purchase a service manual and follow thetroubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where youconnect the video and audio cables, if a signal board is defective,then you may get no picture on particular inputs located on faultyboard.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on Jul 18, 2009
  • 29 Answers
SOURCE: view sonic 32 inch lcd tv has purpleish tint where
ther is a problem in vertical area,just a capacitor only must be replace.
Posted on Jan 20, 2010
  • 35 Answers
SOURCE: View Sonic N3260W LCD TV. No action after pressing
check for fuse or could be bad power cord
Posted on Feb 25, 2010
rockmeister
  • 2047 Answers
SOURCE: i have a 20inch view sonic LCD TV and it says menu
When menu is locked this means the child lock function has been activated on the system. This is usually to stop kids from tampering the remote and adjusting settings. The procedure for doing this differs from unit to unit Refer to your user manual to determine the procedure for unlocking the unit.
Hope this solution has been helpful?
Posted on Sep 24, 2010
  • 112 Answers
SOURCE: View sonic flat LCD TV 32' turns power off.After
You will need to open it cant fix it from out side better bring it to a technical center i can give you advices what to do when you got it open but i`m not edvising you to do this if you have no soldering skills
Looking for code to a onn universal remote control for a view sonic flat screen tv
0038,0031. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Try this link too
http://remotesearch.blogspot.com/
May 03, 2014 | Televison & Video
Start view codes
NEON 0348 0364 the second one worked for me.
Apr 05, 2014 | Universal Remote Control Televison & Video
Code for huayu rm-36e+) for Sonic tv
Try code 014 and sonic blue 148
Aug 17, 2013 | Televison & Video
How u get it off the **** screen When i hook up my xbox its comes on but its on the left part of the screen & the right side stays blue
Good day!!!
Please try to input other device such as DVD player to determine which device (x-box) or (TV) need to set up full view settings..
If you play DVD and the screen is fine so you need to set up the full view of your x-box using remote..
If you play a DVD but the screen is still half..You need to set the full view of you TV using remote..
I you have more queries and clarification just add a comment..
Hope it helps..
Thanks for using fixya..
Oct 01, 2011 | Olevia LT37HVS 37 in. LCD HDTV
I have a rca universal remote and a View Sonic TV model N2750w I need the codes for that brand of tv
Hello
Setup codes for Viewsonic TV with RCA RCR311S universal remote control are:
1200, 1227, 1037, 1142
OK.
Aug 02, 2011 | RCA Televison & Video
I have a soniq 42"
Ah, the old universal remote isn't so universal anymore is it? Most "universal" remote controls were designed for the old tube type television sets. There are some seriously nice universal remotes for new flat screen TV's, but most of them are pretty pricey. The only reasonable flat screen universal remote that I've found (that actually works) is the Vizio HDTV Universal Remote. It's about $25, and believe it or not ... Wal-Mart carries it in the store.
May 16, 2011 | Televison & Video
The menu button is locked on my view sonic tv how do i unlock it????
Depends on the model of TV. Some ViewSonics will unlock the menu if you Press the Channel + and Channel - buttons at the same time. You should see a message stating the menu is unlocking. Once it clears you can use your remote control to make any necessary changes to the TV.
Sep 25, 2010 | ViewSonic N2230w 22 in. LCD TV
Harmony 880 display is backlit but menu won't display. It seems to still work (pressing the button I know to be "Watch TV" turns everything on ok). Is the LCD broken?
Sometimes the LCD screen fails on the 880/890 series. But, there are a few tricks you can try that have brought the LCD back to life.
Some LCD problems have been solved by updating the remote's firmware while the remote has been placed in 'safe mode'. To do this, launch the Logitech Remote software on your computer and click on "Downloads" (on the top menu bar). Then, take the battery out of your remote and at the same time you connect the USB cable to your remote (it should be already connected on the computer end) press and hold down the Off button at the top of the remote. This will put the remote in "safe mode". Continue to hold down the Off button until you see the message "safe mode requested" on the remote's screen and the screen starts blinking. Now, since your screen is not behaving properly, you may or may not see this message, but after about 5 seconds you can release the Off button. Now, go back to your computer and click on "Firmware". If the software is able to communicate with the remote, an update to the remote's firmware should be executed. This has solved many a 'blue screen of death' problem. Good luck!
Feb 27, 2010 | Logitech Harmony 880 LCD Remote Control
Screen is blue it operates tv cable box but nothing comes on to tell you what is what
Ah! Sound like you've run into the dreaded "blue screen of death". Well, before you take your 890 and toss it out read on:
Sometimes the LCD screen2_bing.gif fails on the 880/890 series. But, there are a few tricks you can try that have brought the LCD2_bing.gif back to life.
Feb 19, 2010 | Logitech Harmony 890 LCD Remote Control
Remote control UBRC-120 for LCD ViewSonic N3751W is not responding to commands
I have URC-100 which is similar to your remote, try these codes: Please post back waht you find.
N1700W
001
N1300
002
N1500
003
N1750W
004
N2010
005
N2010-E
006
N2700W
007
N2750W
008
N3020W
009
N3200W
010
N3200W-E
011
VPW4255
012
VPW5500
012
N2000
014
N3000W
015
Nov 12, 2009 | ViewSonic N4251w 42 in. LCD Television
ViewSonic N3020W 30 in. HDTV-Ready LCD Television Logo
44 people viewed this question
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
