Want power supply for my studio 540 650 watts
Want to put a ati 4870 x 2 into my dell studio 540, need a compatiable power supply that will work. best buy doesnt sell them and dell i cant get a person that knows anything about upgrading rather than trying to sell me a hard drive when i want a power supply ??????????
  • Anonymous Mar 21, 2009
    Did you install a new power supply and has the computer worked fine since then. I bought the Best Buy equivalent of the Dell 540 in mid January and had BestBuy install a more powerful power supply because sales person pointed out standard 350 watt unit was not adequate. Computer worked fine and then about 2 weeks after purchase began to have occasional problems booting (error loading operating system) and rapidly developed many more problems (stating that product key for windows was invalid, later finding key to be valid, stating file system on drive C corrupt, file system fixed, file system corrupt, various window components crash, frequent blue screens of death.) BestBuy replaced hard drives but that did not help. Now BestBuy will next week replace mother board and memory. I wonder if the 650 watt Antec power supply damaged t hings. There seems to be confusion over whether it is safe to put a different power supply into the Studion 540.
  • 104 Answers
You can order a power supply online extremely cheap at this website
http://microcenter.com/
Posted on Dec 12, 2008
Hp 7900 usp make problems when i connect ati radeon hd 5450
your hp only has a 350 watt power supply, you need at least 400 watt, preferably 450 - 500 watt.
Jul 19, 2013 | Computers & Internet
I have dell optiplex 755. Does my system support ati radeon 3650?. Also recommend me any else card which is suitable for my computer
what model is this small form factor ? mini tower?anyhow, here are the things that you may consider .
if its a small form factor unit then you may need to get a video card that is Low Profile
and also consider the power supply :
The ATI Radeon HD 4650 512MB Low Profile PCIe x16 graphics card should work fine with the 275w PSU.
Max power draw is 48 watts
Oct 13, 2012 | Dell Optiplex 755 Minitower Desktop...
My ati radeon 5450 when i am putting it in my computer my PC won't boot,... it shows power but will restart automatically,.. i have 500w morrLogic power supply,.. i also tried my old gt 7300 ddr-2,.....
Many flavors of this video card from various manufacturers have different configurations - most important is the auxiliary power connector that appears on the edge of many of these cards. If your ATI has such a connector, it must be connected to the PSU. The MoBo bus can not supply the required power via traces on the board. If connected and it doesn't work - it may be a power supply problem.
While your 500 Watt power supply unit (PSU) is more than the 400 Watt minimum requirement, but depending on its efficiency and your system configuration, may still be on the "weak" side. Your particular PSU is not a certified type. ATI recommends using certified PSU's on this list. You could probably get away without using one of those expensive PSU if you got one with a little more "umpph" to it, say a 600 watt or more rated type. The 500 watts unit you currently have may be "just a little too close" with your PC's configuration.
I hope this helps & good luck!
Sep 13, 2011 | Computers & Internet
Can i use a ATI 9700TX in a dell dimension 4500 cpu? I was just wondering if the 250 watt power supply will handle the 9700TX or anything bigger for that matter. I can't seem to find the wattage needed...
It needs about 100 watts supplied thru the power connector situated on it so no, it will not work in the current situation: you will need a new power source, of at least 400 watts.
Jan 20, 2011 | ATI (128 MB) Dell / ATI RADEON 9700TX DDR...
I have a problem with my dell studio 1535 lcd.i guess the problem is with the inverter.how t check whether the inverter is working by using an ammeter
1 check if the battery is still good by switching the meter to DC and test it if it is still reading the correct voltage.if not the batteries may be bad
2. switch it to AC and check the out put if it is supplying a voltage output.if not the transistors may be bad
Mar 04, 2010 | Dell Studio 15, Studio 17 175-Watt Power...
I there a replacement for a gx280 SFF powersupply?
Your best bet is to take the power supply out and take it to a good electronics store that has decent computer hardware. That way, you can compare the connections available and also its mounting style to make sure it will work.
Sep 11, 2009 | Dell OptiPlex GX280 PC Desktop
How much ATI Radeon HD 4350 512MB needs power to work?
Go for more watts here. 500 watts or more here. Make sure your power supply has graphics card power supply. Good luck!!
Aug 04, 2009 | Dell 1505FP 15" LCD Monitor
Dell Optiplex GX280 Video Card Install Problem
You hit that one right on the dot.  ATI website showed the specs for that graphics card you installed as needing a 300 Watt power supply.  Good news though... I researched newegg.com and I believe I found your 300W power supply.  There are 4 different Optiplex gx280 designs with 4 completely different power supplies.  Since you bought the low-profile video card, I believe you have the slim computer case and this power supply should work for you...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817374002
Good Luck
Jun 10, 2009 | Dell OptiPlex GX280 PC Desktop
I need help choosing a Graphic card ...
Man, trast me, the GTS 250 is way better than the hd 4870 one. on each section of the measures of performance factor, 250 beats the 4870. PhysX is the hardware utility for making the real world effects like the gravity , air factors, sea waves more realictic easily .
Apr 18, 2009 | HEC Group ACE 580UB 580-Watt Power Supply
Computers & Internet Logo
1,709 people viewed this question
David Payne
David Payne
