Question about LeadSinger LS-3222 Consumer Microphone
Karaoke microphone and wireless mic
I purchased a leadsinger karaoke 600 March 2008 and only used it a few times. Can you give me some possible repair options? There's not much to it. I wrapped the cord up when not in use and my son says he thinks the cord is damaged. There is a rolling picture and no sound.
  • msfeeley Dec 11, 2008
    Thank you. I will be more careful next time! I may try to change the wire and see what happens.
    President:
  • 373 Answers
Cord rolling might generally cause damage to the internal wiring.the only possible repair option is change the wire inside.A suggestion is to try not to wrap the cord tightly with the microphone.fold it separately and use a band to hold it.
Posted on Dec 10, 2008
    Problem Solver:
  • 7 Answers
Turn off the mic then hold and press #5 then press the power switch. when power is on, push #1. it will go back to ntsc.
Posted on Jul 30, 2009
How do I connect my wireless mic to my karaoke
Simply connect the mic-level output from your wireless mic receiver to the mic input on the karaoke system.
Oct 19, 2014 | Audio Players & Recorders
Karaoke not working
Hi, got this info from philips customer service. Was desperately trying to get the karaoke function to work for 2 weeks! Plug in your microphone. Press "KARAOKE" button until you see "MIC OFF" text, and immediately press RIGHT button. It will now shows "MIC ON"! "ECHO", "KEY" options will now shows up when pressing "KARAOKE" button repeatedly. However, microphone sound will not be available on digital output, you'll have to use the audio RCA. Happy singing!
Dec 31, 2009 | Philips Televison & Video
The green light just keeps blinking and it doesn't
Did you find the solution, I have the same issue and the Leadsinger company is not a verry serious company no one knows about this and no one can help! Thanks Cathy
Nov 18, 2009 | Magic Star Karaoke Microphone
Downloading
you could have downloaded a different format. try to read the manual of your karaoke, look what kind of format used, then download the same format.
Dec 26, 2008 | LeadSinger LS-3222 Consumer Microphone
Cable conexion is broken
I removed the cable from microphone circuit board  and shortened cable by 20 cm. to eliminate damaged wires, stripped the individual wires and soldered the pins to the new wire ends and reassembled.  Used black heat shrink tubing  [10mm dia.] to reinforce cable end at mic to prevent future damage from careless handling.
Document wire colours to pins before disassembly
Red                   Audio L
White                 Audio R
Blue                   DC Power
Shield [ground]     Ground
Yellow                 Video
Dec 13, 2008 | LeadSinger Wireless HiFi Remote Duet Mic...
Leadsinger sub mic, modle LS 3222. Green lite flashing but no sound. any help?
We had this problem too. Can you perform any functions with the duet mic? We couldn't, just had the light flashing. Turns out the light is supposed to flash (never is solid). Check the connections to the sub mic pack in the back of the main mic. Ours was loose. Once that was plugged in properly, we turned everything off and started again. All was fine.
Good luck.
Nov 29, 2008 | LeadSinger Wireless HiFi Remote Duet Mic...
Magic-Sing EG-18000 works, no sound
look and see if the RF light is coming on, if it is not then the transmitter (mic) is not on the same frequency as the receiver.
Nov 22, 2008 | LeadSinger Wireless HiFi Remote Duet Mic...
LeadSinger LS-3222 Consumer Microphone Logo
412 people viewed this question
Top LeadSinger Audio Players & Recorders Experts
Michial Gueffroy
Shehu Pro
Shehu Pro
johnny rebel
Are you a LeadSinger Audio Player and Recorder Expert? Answer questions, earn points and help others
