Question about EliteGroup K7SOM Motherboard
Need the area on the motherboard
Were are the power sw &reset sw pluged in
  • pollypooper Dec 14, 2008
    I like to thankyou for your help I know that it well work ,I've just been to busy lately to get back to it.If you ever need some mig welding call me ,I'll give you a deal because I GO BY ONE HAND WASHES THE OTHER CONCEPT
    Thank's Wolfgang
  • 341 Answers
The SW1 Connector
This panel connector provides a set of switch and LED connectors found on
ATX case. Refer to the table below for information.
Device Pins
HD_LED_P 1
FP PWR/SLP 2, 4
HD_LED_N 3
RST_SW_N 5, 8
RST_SW_P 6, 7
KEY 9, 10
Pins 1-9 are closest to the edge of the board. Pins 2-10 are above 1-9. Number 10 is missing .
Posted on Dec 10, 2008
Where doe's power led,power sw,hdd led on my e-machine
You will need the user's manual for your machine to make sure that you are hooking the wires up correctly. However, most motherboards label these connections directly on the motherboard next to their pins.
Look for an area on the mother motherboard with two rows of six to eight pins. Next to them you should labels such as PWR_SW (power switch), RST_SW (reset switch), HDD_LED, PWR_LED, etc. You won't mess anything up connecting something to the wrong pins, but it isn't that hard to figure out as the wires are usually labeled in the same manner as the pins. So HDD_LED would plug into the HDD_LED pins, PWR_SW to PWR_SW, etc.
Jun 30, 2012 | E-Machines Computers & Internet
I have a emanchine W3622 that i need to find the power sw and power led pin for i pluged them out and dont know where to plug them back into, my computer hasnt started since then and not sure what to do!!!
As a rule, most mother bords are similar. Look for a row of connectors on the edge of of the board usually at the bottom right corner general area.
It may look like just another ribbon cable connector. Look closely for print next to the pins, may say PS for power switch. HD for activity light. LED for power light... etc.
The correct pins may be vertically or horizontally next to each other.
Dec 04, 2010 | Computers & Internet
Please I need a picture or pictures of how you connect the cables from the cabinet in this motherboard GA-G31M-ES2L. the office that I'm trying to enjoy the positive it has entered a msg on the board and...
> HDD LED == hard-disk drive Light Emitting Diode (a "lamp" that lights-up when you are reading/writing files to/from your disk-drive)
> RST SW == the (optional) "reset" switch/button on the face-plate
> SPK == the internal PC loudspeaker
> PW SW == the power on/off switch/button on the face-plate
First, connect the "PWR SW", so that the ON/OFF button works.
It's much less important that the other wires be connected.
For example, if you never press the RESET button on the face-plate, you don't need to connect that button to the motherboard.
Oct 22, 2010 | Gigabyte GA-G31M-ES2L Motherboard
I have a intel media series dp35dp motherboard. I have a power led cord, reset sw cord, power led cord, m/b sw cord and a speaker cord for the speaker on the chasis. When I plug them up I don't see a spot...
in newer generation motherboard the buzzer is built in in there is no need to connect an chasis speaker if built in buzzer is not there uwill find a four pin conecter near the power pannel you nedd to conect the pwer switch and reset switch in proper conector or the system wont powerup properly
Sep 25, 2010 | Intel Computers & Internet
Reset sw, power sw, and hdd led where do i put them on the motherboard
hello, your front panel connectors like reset sw, power sw, hdd led, you can search easily. a use of screw driver touch all front panel connectors, if any response of connectors connect it.
Aug 10, 2009 | MSI 745 Ultra (MS-6561-010) Motherboard
Number codes for giving connections to HDD led,Power led, Reset SW & Power SW to motherboard
Those are really tricky and always vary from motherboard to motherboard.
without the exact model no one will be able to tell you exactly. But I'd recommend that you start out with the power (pw) plug and try trial and error. The only ones really necessary are the pw and reset. the only 2 that are polarity sensitive are the HDD light and pw led.
Apr 18, 2009 | Intel Motherboard
Foxconn motherboard pinout
Please follow this link and download the manual.
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0002117
Don't be surprise that the manual name is 662M03, it is still the right manual becuase is made for both type of motherboards.
Jul 25, 2008 | Foxconn 661M03-G-6EL Motherboard
Foxcon Motherboard pinout
Hi bwalker24,
This is a pic of how to connect you're LED & switches.
f0649db.jpg Enjoy!
Mike
EliteGroup K7SOM Motherboard Logo
166 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
