Question about Emerson EWC27T3 27 in. TV/VCR/DVD Combo
SET UP MENU COMES WHEN TV IS TURNED ON BUT WILL SHUT OFF IN 5-10 SECONDS
  • 435 Answers
First, Check whether any auto timer option is activated...
If you are sure that this is not the problem, please revert back..
Posted on Dec 10, 2008
Tv comes of for 10 seconds then shut down with a blinking orange light
Do the self check this set has when it shuts off Menu and input (input is source) buttons on the set both held for five seconds or longer, then release both and look for the power light to blink a two digit error code like one blink, two blinks and pause then repeat it several times, let me know what error code you find.
Dec 20, 2012 | Mitsubishi WD-60737 60 in. HDTV
When I turn my TV on, it comes on and says 'no signal' then after about 5 seconds, automatically switches its self off... any idea why?
Most sets will shut down very fast if no signal at all.
If you can before it shuts off try to change input to one of the rear audio video inputs that has something connected to it and turned on.
Failing there and if using a box of some type for signal--unplug it and the set both for a while---plug back both and let each try to boot up.
A total loss of signal or a glitch with the set or a box can confuse the TV set's Microprocessor.
May 30, 2012 | AOC L32H961 32 in. TV
RCA 20V500T television. Inadvertently set FPA (parental control) to on. I shut TV off thinking it would reset. It is now in standby (in accordance with manual). It can only be turned on with remote. ...
Hello
You just try the following to open your TVs lock.
You must have its remote to unlock it.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Dec 23, 2010 | RCA 20V500T 20" TV
Tv shut off on its own
Replaing the lamp will fix this problem most of the time.If not count the blinks. This is an error code.
Apr 01, 2010 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Turns itself off after being turned on.
Here is what you do:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
LET me know what you find and I will tell you what it means and if possible how to fix it.
If this information helped you rate this solution as I do this here for free.
SD TECH
Dec 07, 2009 | Mitsubishi WS-48313 48" Rear Projection...
I have a Mitsubishi big screen tv model #WS-65857 and the picture went out as though the tv was turned off and when you turn it back the green light comes one for about 5 seconds the goes of there is no...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
if your set does not have a device button press Menu and Input together for 5 seconds and release. there will be a pause between blinks---2 blinks, a pause and two more blinks etc.
If you need help: etower.766@netzero.net
I do this here for free so if this has helped you give me a vote here.
Aug 18, 2009 | Televison & Video
TV turns on, then turns itself off about 2 seconds later.
set has a self diagnostic---after set does shut down press and hold MENU AND DEVICE(INPUT) buttons on front of set for 5 seconds----if 2 blinks, a pause and 2 more blinks: this is short protection error code---The set does use 2 Stk394-250 and each is protected by a pico fuse in the power supply---if either fuse is blown the set will shut down(it detects no voltage or missing voltage;) It is not uncommon for a shorted IC to cause this problem; if you locate the STK's look carefully at the resistors around them---if any are discolored or burnt---you have found your problem.
Aug 17, 2009 | Mitsubishi WS-65413 65" Rear Projection...
I was watching it and it just shut off when i turn it on 3 seconds later it shuts off again
this set has a self diagnostic feature:
If this has been helpful I would appreciate a vote from you here; if you need direct help:
Aug 14, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Standby light is on, but power switch does nothing
The FPA (Front Panel Access) lock is on. This allows you to prevent kids from using the set when you are not there and disables the buttons on the front of the TV. The set should turn on with the remote only, and then you can go back into the menu and turn off the FPA, also called child lock.
Aug 04, 2007 | RCA 27F530T 27" TV
JVC AV-27820 27" TV
probably some cold solder joints. take your time and check over whole circuit board and re-solder what looks bad.
Jun 10, 2006 | JVC AV-27820 27" TV
Emerson EWC27T3 27 in. TV/VCR/DVD Combo Logo
107 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
