My tv is on standby and won't stay powered on. The cable box is fine. It never had a problem before.
  • 60 Answers
There is an internal problem with your tv you need to go to authorized service because there are some component broken like final transistor from orizontal baleiaje etc..
Posted on Dec 10, 2008
Monitor standby won't stay on /pioneer 424mv
What is the source of the TV signal? I know many monitors have a "power-saving mode" that returns the unit to standby if there is no signal coming in.
Check that the signal cables are working (try swapping cables). Make sure the source is on before turning on the TV. Press the Input button to select a different source. Make sure that the source signal is not refreshing (or synching) at a rate that is incompatible with the TV. (If your source is a PC that was previously connected to a CRT monitor, the refresh rate should be reset to 60 Hz before connecting the computer the the Pioneer 424MV.)
I hope this helps.
(Pioneer TVs usually give a blink code if there is a hardware problem that prevents it from turning on.)
Mar 17, 2013 | Pioneer Televison & Video
Tv won't power up straight away
when lcd tv`s fail to power up, but stay on standby. It is usually because of bad capacitors on the power board. My 22" lcd monitor did the same. It would not come off of standby. It starts with them being slow to turn on. "Sound familiar"? I fixed mine by changing the bad caps. There were two of them.
Jan 31, 2013 | Wharfedale LP160DTRHDMI
TV won't turn on. Stays in Standby mode
Someone is going to have to go inside and check voltages and other things --no brand or model is indicated here so this is as much as I can suggest.
Dec 20, 2012 | Televison & Video
Won't power on
Sounds like a Zenith or LG TV. It is most probably the Y board, when you hear the clicking sound is usually that. I am sharing this with you because it happened to me with a Zenith (POS). The red light (on my TV) is in the bottom right corner. In my case it was the Y Board. Best of luck
May 14, 2017 | LG 50PA4500 50" 4500 Series Plasma HDTV
Tv stays on standby
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 25, 2012 | Orion TV 4200 42 in. Plasma TV
Daughter's TV was on during bad electrical storm. Screen went black and made high pitched sound. cable, internet and telephones all digital through Time Warner Cable. Now TV will not even turn on;...
Ur Main Fuses in the circuits breaker box must be to be restart it back.Turn off/on all the fuses on the main circuits breaker box to all the fuses in the box of the box to restart.All ur electical power outlets should work again.If not those power plug in outlets are shorted and dead must have to be replaced.
Aug 22, 2011 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
TEAC AG-V1200 receiver won't auto turn on when
No. It won't automatically turn on when power is present.
Aug 08, 2011 | Teac Audio Players & Recorders
TV won't stay on. Standby light flashes 5-10 seconds then shuts off. Just before this happened - it turned on , had good sound but the picture never lit up. Now it won't even turn on. I've...
Hello
Blinking of standby light in Sony sets are fault indication. You just count the exact number of blinks occur at on instance, say, after you switch On and OFF by its front panel power switch, not by remote control hanset. Just count it atleast 4 times, count it keenly and inform it to me, and let me reach to the nearest falult point; or sometimes to the exact point. OK.
Dec 06, 2010 | Sony FD Trinitron WEGA KV-34XBR910 34" TV
Magnavox 15MF237 LCD - stuck in standby
just one idea.. some set you may program to stay on in case you use cable box and when you turn on the box tv turn on same time but may be defective tv there is relay,transistor and the micro that may be bad so check your settings again ... Good luck
Apr 10, 2008 | Televison & Video
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
