Question about Brother HL-2040 Laser Printer
My printer keep running paper without printing
No printing just paper kep running
Printer error 3533 CJX-1050W
too much paper being put into slot. paper it static so fan it beofre putting in
Feb 11, 2013 | Office Equipment & Supplies
Paper jam error without a paper jam
sometimes the printer keeps telling you one thing first you have to read again your instruction carefully or sometimes its just the position of your printer where the paper was
Apr 17, 2012 | Office Equipment & Supplies
Is it possible that my Epson R2400 will just consistently reject specific types of paper? That is do 1 or 2 prints, but then run the paper through without printing and then not take the paper at all (media...
I have the same problem, my printer has been sitting unused for over a year now because I cannot afford to keep getting it serviced just to make 3 prints before it malfunctions again. I beleive it is paper dust getting on a sensor somewhere - I wish I knew how to service the printer myself! So if a solution is given to you I will be very interested in it!
Nov 02, 2010 | Epson Stylus Photo R2400 InkJet Printer
Printer stopped working
When you removed the paper did you rip it? Maybe you still have a piece of paper inside printer. You can also try shutting down the printer and canceling the print job and retrying it again.
May 31, 2010 | HP DeskJet F4280 All In One Printer InkJet
Did something???? How do I cancel printing? Unplugging, Info I've been given will not stop printing, even when I press Delete or Cancel. It just wants to keep printing...
there is worm virus that will make a printer print until it runs out of paper and if you add more paper it will keep printing till it runs out again i would take the paper out of the machine and run an antivirus scan on your computer usually the print is not legible with this virus
Oct 04, 2009 | Office Equipment & Supplies
Cannons450 paper jam- removed paper but yellow light keps flashing and nothing prints
At the printer icon cancel/delete all print jobs.
Turn it off by unplug the power cable, and the then turn it on.
If its still blinking, push once the on/off button or if there is any paper feed button
Sep 06, 2009 | Canon Office Equipment & Supplies
Oki C9300 - paper keeps jamming in the 2 same places, reads either 383 paper jam or non paper sense error. All drums and tonners are new, paper is loaded.
your getting a 383 paper jam, find paper in two different places.
See if it's a duplex related problem. print single sided documents, if that works, try printing two sided documents (it'll be the duplexer) if it only fails while printing duplex.
Also, check the back door. Make sure the back exit tray is closed all the way.
You can also have a paper jam in the duplex unit (open the front door), the duplex unit slides out the front. You can easily remove the duplex unit and run the printer without it.
Oct 20, 2008 | Office Equipment & Supplies
HP4 and PC LOAD LETTER MSG (and there is paper)
Hi, I assume you can run paper thru the manual feed without any problems? If so the paper sensor that detects the paper in the tray has either broken or fallen off! If you take the paper tray out and tilt the printer a little bit on it's back you should see a sensor that will swing back and forth its' solid black/plastic . The sensor is very cheap and I'm pretty sure this is the problem> Good Luck!!
Nov 29, 2007 | HP : HP4 Laserjet Printer
Brother HL-2040 Laser Printer Logo
62 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
