Question about Creative Labs Zen MicroPhoto MP3 Player
My creative zen is stuck on a blank screen and wont turn off
All i did was put in a san disk memory card from my camera and tryed to view a photo and it just froze
    Problem Solver:
  • 7 Answers
Hey this happened to me try holding the reset button in for 10 seconds or plug it into your computer to reset it
Posted on Dec 10, 2008
San Disk Extreme 8GB with Images on but no images on computer
Check the camera's settings, the photos maybe stored in the camera's internal memory and not being stored on the memory card.
Apr 21, 2013 | Sony Alpha DSLR-A350 Digital Camera
When I put fully charged batteries in my camera and turn it on the screen works fine. However, when I install any picture card and turn the camera on it gets stuck at the Pentax Optio screen. I will stay...
I have to say that you are probably using the wrong SD card. Or the memory card is to big and the camera cant handle all that memory space. I recomend that you try a 512mb San Disk SD Card. Dont mistake this for any card. Dont use a San Disk SDHC card. Do this and make sure your batteries are charged and you should of solved your problem. Good-Luck.
Jun 13, 2011 | Pentax Optio E10 Digital Camera
Took a few photos, switch off, 5 minutes later switched back on, blank screen but can view playback and menus
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
Jun 10, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Service center for creative mp3 in kerala?
I had the same problem....ok here's what you do, make sure the ZEN is off first then switch it on my pushing the switch down (like usual).So switch it on and press the play/pause button at the same time. It may take a couple of tries but after you get it, the screen will say "Recovery Mode" at the top. Now go down to "Clean Up" and click it. It will then ask, "Disk cleanup will be performed. Continue?" Click yes. When it's done, turn off the ZEN and turn it back on. Does it work!? Ha I'm a 13 year old genius.
Jan 14, 2010 | Creative Labs Zen Digital Media Player
My 4gb san disk said card error on my camera, when i took it to 2 different photo places it could not view any images, now its as if my card was deleted and all pic of my kids for past 2yrs is gone, can i...
yes you can there are commercial experts that do recovery job, i suggest that you try new memory on your camera and see if your camera doesn't give error, you can also try to remove your disk from your camera and connect it to your pc using specific adaptor and view its content there
Oct 19, 2009 | SanDisk 2GB microSD Memory Card
My screen just went blank, now player does not work
I have the same problems sometimes. what you can do is to take a straight pin and at the bottom of your zen is a tiny hole. stick the pin in the hole to rest it. It should come back on. Upon coming back on it should say it is rebuliding info.
Jan 03, 2009 | Creative Labs Zen Digital Media Player
Frozen on start up
This sounds like it might be a hard drive problem. Have you tried to put it into Recovery Mode so you can troubleshoot it? Put a paperclip in the Reset hole while holding the power button in the On position. Then release the paperclip and continue to hold the power button until it goes to the Recovery Mode screen. You should at this point try Format and Scan Disk/Cleanup, then Reboot. If it still gets stuck at the same spot, then its going to be a hardware failure.
Click here to view my step-by-step troubleshooting guide.
Click here to send in your device for free diagnostic testing.
Sep 14, 2008 | Creative Labs ZEN Vision:M Digital Media...
San disk error
Replace the card
Oct 22, 2017 | Cameras
Photos onto creative zen
yes, first you need to download windows media player, then go to library at the top. Then go to add files. Add the pictures that you got to the sync list and sync to zen.
May 24, 2008 | Creative Labs Zen V MP3 Player
Frozen
if it keeps on rebuilding the library the disk had a bad spot on it try going in to recover mode and do a clean if that doesn't work do a format if that doesn't work download the latest firmware if that doesn't fix you will need a new hard drive or flash drive.
Nov 15, 2007 | Creative Labs Zen Micro MP3 Player
Creative Labs Zen MicroPhoto MP3 Player Logo
124 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
