Question about Fisher and Paykel AeroTech Double OD302 Electric Oven
Electric oven (Fisher & Paykel) won't heat up to set temperature.
Double wall oven, model OD302.
All control panel lights, clock and indicators work, no error code, but oven will not heat up to set temperature. For example, if temp is set at 350, after 10 minutes the oven temp is only 155. After 20 minutes it is still very slowly climbing but still under 200. After a considerable amount of time the oven might reach above 300 but then cannot get any hotter.
An authorized tech came out and turned the knobs and then declared it was "probably a burned out fuse or a loose wire." This "diagnosis" cost me $90 and they said they would have to order the fuses and study a wiring diagram and get back to me.
  • annsera Dec 28, 2008
    I have this same problem. I have had similar problems twice before, too, and so I'm not sure how to distinguish which solution might work this time (or if it's a new solution altogether).
    Did you run clean cycle just before getting this problem? Some people are saying that there is a known problem that blows out the microprocessor control with tihs unit after a clean cycle.
    Additionally, I have had a similar problem where I simply replaced the heating element and it started to work again.
  • 1170 Answers
SOURCE: Fisher Paykel electric oven doesn't heat in Bake mode
Electric Oven: Repairs and Maintenance Electricranges and ovens are generally easy to repair, because there's not muchto go wrong and there's not much you can do. Most repairs are actuallyreplacements, a matter of unplugging the old part and plugging in thenew. Most of the malfunctions that affect electric ranges involvefaulty heating elements.
Caution: Beforedoing any work on an electric range or oven, make sure it's unplugged,or turn off the power to the unit by removing one or more fuses ortripping one or more breakers at the main entrance panel or at aseparate panel. If the range is fused at a separate panel, this panelmay be located adjacent to the main panel or in a basement, crawlspace, or other location. If there is a grounding wire to the range,disconnect it. Make sure the power to the unit is off.
Servicing Fuses
Ifthe range or oven is receiving power but doesn't work, the unit mayhave its own fuse or circuit breaker assembly. This assembly is usuallylocated under the cooktop of the range. In some units, lift the top ofthe range to gain access to the fuse assembly; or lift the elements,remove the drip pans, and look on the sides of the cabinets. Inside theoven, look to the back to spot the fuse assembly.
Ifthe unit has this additional fuse or breaker system, components such asthe oven light, the range heating elements, the timer, and aself-cleaning feature may be separately fused.
If thesecomponents or features fail to work, don't overlook the possibilitythat the fuses have blown. To replace a blown fuse, unscrew the oldfuse and install a new one of the same type and electrical rating. Ifthe unit has circuit breakers, push the breaker or reset button, whichis usually located on the control panel.
Replacing Range Heating Elements
Whena range heating element burns out, it's easy to replace. But before youdisassemble the range to check or replace an element, make sure therange is receiving power. Here's what you can do:
Step 1:Check the power cord, the plug, and the outlet. Then look for blownfuses or tripped circuit breakers at the main entrance panel or at aseparate panel.
Step 2:Check the fusing system inside the range. If the circuit is broken,restore it. If the range is receiving power, go on to check the element.
Step 3:When the element is cool, remove it. In most ranges, each top heatingelement is connected to a terminal block in the side of the elementwell. To remove the terminal block, lift the element and remove themetal drip pan that rests below it. The element is held by tworetaining screws or is push-fit into the terminal block. To remove ascrew-type element, remove the screws holding the wires. To remove apush-type element, pull the element straight out of its connection.
©2006 Publications International, Ltd.
To remove a range heating element, remove the screws holding the terminal
wires, or pull the element straight out of its connection.Step 4:Test the element with a volt-ohm-milliammeter (VOM) set to the RX1scale. Disconnect one of the electrical leads to the element and clipone probe of the VOM to each element terminal. If the element isfunctioning properly, the meter will read between 40 and 125 ohms; ifthe meter reads extremely high, the element is faulty and should bereplaced.
To test a range element without using a VOM, remove aworking element from its terminal block and connect it to themalfunctioning element terminal. Don't let the test element overlap theedges of the element well; keep the element inside the well, even if itdoesn't fit perfectly. Turn on the power to the range. If the workingelement heats, the suspected element is bad and should be replaced. Ifthe working element doesn't heat, the terminal block wiring or theswitch that controls the element may be faulty. Call a professionalservice person.
Step 5:Replace a burned-out range element with a new one made specifically forthe range. Take the old element to the appliance-parts store; ifpossible, take the make and model information, too. This data willprobably be on a metal tag attached to the back service panel of therange. To install the new element, connect it the same way the old onewas connected.
Replacing Oven and Broiler Heating Elements
Electric oven and broiler elements are often even easier to test and replace than range elements. Here's how:
Step 1:If the oven element doesn't work, first check to see if the range isreceiving power. Don't overlook the fusing system inside the range.
Step 2: If the range is receiving power, set the timer on the range to the MANUAL position.
Step 3: If the element still doesn't heat, turn off the power to the range and test it with a VOM set to the RX1 scale.
Step 4:Remove the screws or plugs that connect the element to the power.Remove the retaining shield, which is usually held by two screws, andremove the element from the brackets that hold it in the oven. Theelement is usually held in these brackets by screws.
To remove an oven or broiler heating element, remove the screws or pull
the plugs that connect it. Remove a retaining shield and lift out the element.
Step 5:Clip the probes of the VOM to each element terminal. If the element isin working order, the meter will read from 15 to 30 ohms. If the meterreads higher than 30 ohms, the element is faulty and should bereplaced. If the element tests all right but doesn't work, the problemmay be at the terminals. Make sure the terminals are clean and tight atthe element connections.
Oven and broiler elements cannot betested without a VOM. If you don't have a VOM, take the element to aprofessional service person for testing. The problem is usually amalfunctioning element; however, you aren't risking much by replacingthe element without a professional test.
Step 6:Take the burned out element with you to the appliance-parts store tomake sure you get the right replacement part; if possible, take themake and model information, too.
To install the new element,place it in the same position as the old one. Connect it the same waythe old one was connected, using the same screws to hold it in place.Just about all the other components of an electric range or oven(including its door gasket, oven controls, and timer) are virtually thesame as the components used on gas ranges.
Most problems withgas and electric ovens or ranges are easier to fix than you think. Thekey is knowing how the various parts work and when to replace them.
Have a look at these websites to find parts and details :
http://www.appliancepartspros.com/appliance_range_oven.aspx
http://www.gallawa.com/microtech/dataselect.html
Posted on Mar 21, 2009
  • 4090 Answers
SOURCE: I have a F & P wall double oven model OD302,
The name F&P says it all! If there was any brand that gave the most problems, in products then F&P is the first on the list. With LG as the second
You say this is possibly a new installation of only 2 weeks. Don't dither around seeing if its a simple fix, get the installers/sellers back to fix it . It will probably need replacing as the control is faulty.
Thanks for using FIXYA
Posted on Dec 03, 2009
tbirdfan1
  • 3051 Answers
SOURCE: F3 fault code on fisher & paykel wall oven.
hELLO THERE:
on these ovens the f-3 can sometime be incorporated with the f-4 error code also so here is the code and the things to look for both ok ?
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Posted on Jul 14, 2010
SOURCE: I have a Fisher & Paykel double wall oven that
Google searches report that after running the self cleaning cycle this can happen. I am experiencing this issue with my Fisher&Paykel AeroTech Double OD302 but with the BOTTOM oven. I'm concerned as Thanksgiving is coming up and I need this baby working!
Posted on Nov 09, 2010
KevinWhite
  • 1902 Answers
SOURCE: Fisher & Paykel double wall
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Feb 03, 2011
Sets the Clock of the oven
why bother the main oven switch should be off every night anyway which turns the clock
Jun 18, 2014 | Fisher and Paykel AeroTech Double OD302...
Bottom oven not heating up and I replaced element behind rear panel.
U have a bad fuse witch is located in back of oven .its round and black .replace that first .if that don't work then your selector switch is bad .or your control board.what ever u.one u use to turn on the oven
Nov 08, 2011 | Fisher and Paykel AeroTech Double OD302...
Fisher & Paykel double wall oven, bottom oven will not heat to set temp. Stops a 75 degrees
Kevin
Feb 03, 2011 | Fisher and Paykel Titan OD301M Electric...
Bottom oven not heating. Both light and fan are working.
If fan is working o/k then it is usually the oven element that is faulty, this should be located at the rear of the oven compartment behind a removeable cover.
Dec 11, 2010 | Fisher and Paykel AeroTech Double OD302...
Error code f5, and inconsistent heating in top oven.
You need to replace the temperature sensor in the top oven cavity. I can't get you a part number or price because I can't find any service info without exact model number. Contact your local appliance parts store. It is easily replaceable with just a coupla' hand tools.
Dec 04, 2010 | Fisher and Paykel AeroTech Double OD302...
I have a Fisher & Paykel double wall oven that I purchased in 2005. The top oven which was used most often stopped heating up to temperature in normal time. What used to take 5 minutes to get up to 250...
Nov 08, 2010 | Fisher and Paykel AeroTech Double OD302...
Fisher Paykel oven model OS302M error code F7?
Check your lock on the oven for the door. It may be sticking out a bit:)
Oct 01, 2010 | Fisher and Paykel AeroTech Double OD302...
Oven not working
In this case, I would check the following:
  1. Make sure the oven is receiving power. Turn the power off and on at the circuit breaker.
  2. Pull the oven out of the wall and inspect the control boards. Look for burned areas. The power area could have burned out or the control card probably burned out.
  3. Personally, I think that in this case, the are that the whole computer card will need to be replaced. It runs over 100$ in parts.I think this because it's happened twice to me -- once when we had a power surge in the house, another time when I simply replaced a light bulb in the oven.
I hope you will post back what the actual solution was.
May 19, 2008 | Fisher and Paykel AeroTech Double OD302...
Open Questions:
See all Fisher and Paykel AeroTech Double OD302 Electric Questions
Fisher and Paykel AeroTech Double OD302 Electric Oven Logo
1,421 people viewed this question
Top Fisher and Paykel Ovens Experts
Dan Webster
Dan Webster
Joseph Hoffmann
Oloyede Monsuru
Are you a Fisher and Paykel Oven Expert? Answer questions, earn points and help others
