Question about KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher
Kitchenaid dw won't go on
Hi, unit is only 2yrs. old and clean led blinks about 4-5 times. it won't go on. any suggestions?
  • nick fusco Feb 28, 2007
    Catrier, no good my arrangement in buttons/options are in this order- baked on cookware,normal,china,quick clean up,rinse only,high temp scrub,sani rinse,energy save dry,4hr. delay,start,cancel. Maybe we aren't lookin @ the same Mod#- kitchen-aid kuds01flss6. let me know, thanks, salvy
  • nick fusco Mar 02, 2007
    i cant remove the lower panel cause it's tiled in, i'm gonna have to call a repair man.
Try high temp scrub-sani-high temp-sani. If that's not it, remove the bottom toe panel and the tech sheet should be under there giving the sequence. Catriver
Posted on Feb 28, 2007
    President:
  • 878 Answers
Salvy, see if you can get out of that fault by pressing, in this order within 6 seconds. Heated dry-normal-heated dry-normal. If you don't have those keys try- high temp-air dry-high temp-air dry. This is the service cycle, all lights should light up and the unit should go into a self test and clear the fault. The test lasts for about 25 minutes. Let us know it this works, Catriver..post back.
Clean light blinking
If the clean light blinks four times and then pauses and then blinks four times again and repeats, the problem is your pump motor. If there is water under the DW the pump clamp has probably failed and sprayed water onto and inside the motor. Call a certified Kitchen Aid repair service.
Aug 13, 2014 | KitchenAid Dishwashers
CHH012CD-13B
This type of unit does not drain into the outside unit. It drains into a nearby interior drain, or just to the outside near Inside unit. If the unit is cooling properly, you're ok.
Jul 01, 2014 | ComfortStar CHH012CD-13B Wall Mounted Mini...
Kitchenaid DW KUDS30FXSS Cycle starts then I hear a solenoid actuate 4 times then unit goes into cancel drain cycle
Here's a link for the repair manual for your dishwasher:
http://www.appliancerepair.net/kitchenaid-dishwasher-repair.html
Concentration should be on Chapter 2 subsection 2-3 "No Fill"
Then go to Chapter 6; subsections 6-2, 6-3, 6-3a, 6-3b, 6-3c, and 6-3h for testing procedures on relays, actuator valves, etc.
Nov 30, 2013 | KitchenAid KUDS30FXSS Builtin Dishwasher
Clean light flashes on my KitchenAid KUDS01DJ and it wont run
My dishwasher did the same thing. The repair guy fixed it and told us how to reset next time it happens: press: Hi temp then Energy saver then Hi Temp then Energy saver do this quickly over 5 seconds all the lights should come on Then,turn off the breaker for one minute then, go back to the dishwasher and press cancel. All the lights should turn off. Start dishwasher as usual. If the cause was just a brain fart, the dishwasher should work.
Jun 03, 2010 | KitchenAid KUDS01DJ - Multiple Color...
My kenmore dw just stopped running thru cycles except drain
Hello, With the information you supplied I'm going to assume the light is blinking 7 times and pausing then blinking 7 times and so on. With the door cracked open hit the following button combination: -high temp wash
-heated dry
-high temp wash
-heated dry Then close the door and hit cancel. The pump will run for a few moments and then you should be all set. Hope this helps Mike
Nov 19, 2009 | Refrigerators
Clean light flashing 7 times. Can't start the machine
The cleam light blinking means that the unit was not able to reach a proper heated wash cycle. Either your heating element failed orthe actual sump/pump motor system has failed. Check the element in the botton and see if it looks broken anywhere. If you can see a broken spot, you will k now that is the trouble.
Good Luck!
Oct 20, 2008 | KitchenAid 24 in. KUDS02FRSS Stainless...
Clean led keeps blinking.
salvy, look for the lock symbol, it should be on the heated dry pad. Press and hold it until the lock led turns off. Catriver..post back.
Mar 14, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid dw clean light still blinking/ machine won't run...
I tried the following sequence, as recommended on a similar blog and it worked!
Open door
Quickly press :
Hi Temp Scrub
Energy Saver Dri or Heat Dri
Hi Temp Scrub
Energy Saver Dri or Heat Dry
Close door
All lights should come on
then clear and revert to cycle.
Feb 28, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher Logo
296 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
