Question about RCA R56WH76 Projection Television
Screen is pinching
Hi guys, I'm new here and I seem to have a problem with the screen "pinching". Basically, the screen will, for a split second, pinch in the middle and the colors will separate during this pinch and I will get the three RBG images. it will do this for a minute or two and then stop. usually it will do it every other second. It did this for a while about a year ago then stopped and now we are experiencing it again. I have an auto convergence and manual convergence option listed in the menu and also whenever I do an auto convergence it stops at the green square in the top right corner and says that it can't finish because a sensor isn't repsonding. Does anyone know what this could be? Thank you very much!
    Genius:
  • 1,030 Answers
You may still have a fl231 fuse type problem. I would first suggest resoldering the flyback connections. dince this happen ever so often it possible a connection problem. If i had it in the shop i woould chek the flat ribbon connectors also. convergence is controled by three board, convergence power, convergence amp and small signal board. since it pinches this is indication of interuption of convergence power supply. the auto convergence not working. is a symptom of small signal board issues. the small signal board requires specal interface equipment to download data off to place on new board. or the sensors arond the screen has failed.
Posted on Dec 10, 2008
Hi Guys I have an Starsound SSA-4495 series amp,
seems that the amp is fried, have it repaired.
Sep 16, 2013 | Car Audio & Video
I have an old Yamaha RX-V793. It works perfectly fine. Now I have a new LCD screen, a new DVD player and my new cable tv set top box. All 3 take and use HDMI. I'd like to be able to HEAR BOTH my DVD...
hi,
u can make connections only through digital inputs(optical and coaxial). u can connect the digital outputs of ur dvd and cable set top box to the receiver. no way to connect HDMI. HDMI is a high definition media interface. for using it u have to go for a av receiver that supports HDMI.
ok
Dec 23, 2010 | Yamaha RX-V793
Acer AL1917W blinks off in a split-second, twice
remove power to your monitor; then remove the monitor's back cover and, front cover;
when you can see the circuit board check for a buldged can capacitor or, two; replace these by unslodering them and, resoldering the new ones in place digikey.com sells the capacitors (don't forget the position of the capicitors they go in only one way
Jul 22, 2010 | Acer AL1917W LCD Monitor
Sirius XM mirge radio screen light is out; screen is basically black but radio is functioning properly.
This seems to be common problem for this model (google it). I found a guy on ebay that will replace screen for $49 if you send him the broken unit.
Jun 28, 2010 | Sirius Satellite Radio Receiver
My lg laptop screen seems to be split in 2 almost. It only shows three quarters of the screen and at the bottom the screen starts again
Try to turn off the pc and remove the cables and battery on the laptop. Press and hold the power button for 5 seconds, then reinsert the battery and the cables on the pc. Turn on your laptop and check if the screen will finally splits sucessfully...
May 15, 2010 | Computers & Internet
Samsung 931B Monitor Screen will not stay
jane657, Hi there. Will you stop pushing the On/Off button on your lcd/fpd. It's Broke. Period. End. Finito!!! You will not fix it. However there is one test that you should do to determine hoe bad the problem is. You will need to reconnect the 931B to a known good pc that has been fully booted and has the WIN-DESKTOP or IE fixya web page showing. quickly connect the931B to the wall outlet and the PC. Turn on the monitor!!! Yes, I know it will only come on for a second..After the screen goes to BLACK, Shine a bright flashlight onto the screen at different angles, 1-2 inches from the screen. Let me know if you see something even though the screen is black. Anyway here are your options as a consumer/user. 1. Check if unit is under warranty. 2. Check withh Samsung to see if they have a SWAPOUT program. You send them your monitor+$40-$90 and they return a refurbished same model to you with a 30 day warranty. 3. Trade in for new monitor. 4. Check with local TV/Monitor repair guy who knows all there is to know about cold-cathode-fluorescent-tubes, their power-source(inverter type) and lcd monitor power supplys (SMPS) 5. Repair on your own. Not recommended for amatures with no solid state troubleshooting skills and no instrumentation for support. Bye for now. I'm louie12fix on fixya or lmistyrel@ aim.com
May 14, 2009 | Samsung SyncMaster 931BF LCD Monitor
No power
I'm having a very similar problem, basically its a fuse that is blowing out, I think the transformer is sending too much power it's way.
Jun 14, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Open Questions:
RCA R56WH76 Projection Television Logo
52 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
